Question about MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX / Phenom X4 / Phenom X2 / Athlon X2 /AM2 Athlon 64 X2 / Ath... Motherboard
Bios Beeps during reboot
I just recently successfully flashed my Ami bios on my MSI K9A2-CF-F V2 motherboard. I just built this computer & didn't know I could not install more than 4 Gigs of memory (if that) on a windows XP Pro 32 bit OS. I was getting the initial one beep, than a 3 beeps on the logo screen after every restart. I noticed this after I attempted to overclock my system. In which was unsuccessful. I think I may have damaged my memory somewhat. However, the PC still boots successfully each time I restart, beeps and all. I never did register more than 3.5 gig of memory on Windows, but did register close to the 8 gigs of ram I installed in the bios. I'm using 4 memory sticks of Corsair Dominators, 2 gig a piece at 1600 Mhz, but only 800 Mhz registers in the Bios. I removed 3 of the sticks and left one in the first Dimm slot but still I get the beeps. I will try using one of the three I removed later, but was wondering if anybody knows if my motherboard is bad considering I can still reboot with no problems other than the (1)pause, (3) beeps? Any ideas? as I'm quite frustrated. Thanks.
  • 2 more comments
  • JamesSav1 Mar 04, 2009
    Thank you Ubelong,
    I appreciate your effort to help in my dilemma.However, the user manual specifically stated that in order to utilize the dual channel memory cards, you must use them in pairs & also you must use them in either slots 1&2 only, or 3&4 only, or all 4 slots at once. I know the slots are colored coded, but I am thinking that is for single channel memory cards. I did try your method of slots 1 & 3 out of frustration, but it only made my PC reboot over & over repeatedly without successfully booting to the operating system. So I put them back into slots 1&2. I am able to boot up to the OS without any problems except the two beeps. Yes, for some reason, today it is only beeping twice. Mmmmm I am beginning to think it's the Video card I'm using as it is as old as my Grandma. And also, I am going to try entering the correct voltage, timing, and MHz for the memory cards into the bios tomorrow. I am at my wits end. The board is new. I also did a Memtest86 on the cards over night, The test results were ok and the test reported no problems with the cards. I've built computers before & I've heard everyone say re-seat the memory, switch them around, etc, Well, that may help in some cases, but when a guy like me puts memory into the slots, there is hardly any mistakes. But I did check. I looked into turning off the ECC checking in the bios, but AMIBIOS's V1.8 settings don't even have the option nor is it listed. L2 cache & L1 cache is not even listed either. I tried looking for the previous version of 1.7 that I flashed into 1.8 but could not find a 1.7 download from MSI. Once you flash, you can't go back. :-) Or can you? Why would you? Mmmmmm.
  • JamesSav1 Mar 05, 2009
    Today after gathering some information on Ram timings, I was able to enter my memory timings manually in the Dram configuration setting in my bios. I also changed the default MHz of 800 to 1600 Mhz that Corsair recommended. My Ram timings for my dominators according to Corsair are 5-5-5-15. After rebooting and rebooting again to check the timings, my bios had changed the settings on me to 5-7-7-29. So Increased my memory voltage from 2.10v to 2.20v and I was able to keep my 5-5-5-15 settings. I also re-formatted my hard drive & re-installed windows xp-pro. Now I'm only getting one short beep on re-boot which is normal, and one short, lighter sounding beep on the logo screen right before it boots to windows. My question is; is this a two beep scenario still or just a one beep error? I am thinking it's just the one beep now, in which according to Amibios is a "refresh failure" can anyone tell me how to remedy this? and if anyone knows what "refresh failure" is? everything else is just fine now. except the one beep error. Well, at least I am still in the game and not asking for a RMA yet. Thank God!
  • JamesSav1 Mar 11, 2009
    Hey guys,
    After two long weeks of trial & error, a ton of questions, disappointment & uncertainty of the keeping of my MSI K9A2-CF-F model# 7388-v2.0 motherboard, Thinking it was my memory, I have finally found out why this board is beeping 3 short beeps at the post screen after the single initial normal beep after the bios screen after every boot or startup.
    I finally got a hold of someone down at MSI who knows what their doing. It beeps according to how many USB devices that are connected to the board. Can you believe that ****? Sure as the world, I unplugged my USB pen drive and I got only two beeps at post. I still have my Keyboard & Printer plugged into two of the other USB slots on the back of the PC.
    I am finally relieved and very happy with the board. All this time I was hearing the same o'l thing. 3 beeps = memory error in the first 64K of your memory. Somehow I knew this was not the problem as I was always able to boot successfully & run my operating system. My memory cas latency settings is set at Corsairs specs for my 4GB of TWIN2X2048-8500 Dominators 1600MHz at 5-5-5-15 respectively with my Memory voltage at 2.20 Volts instead of Corsair's recommendation of 2.1V.
    I also did the memtest86 on my sticks and I never got any errors. I even overclocked this board into a crash and had to clear the bios but I never damaged a single thing. It was the USB devices all along.
    So there you have it! believe it or not, something so simple. So I hope all of you who have this board or another board from MSI, don't jump to conclusions, ask a lot of questions, and if all else fails, get a hold of the companies support staff or technician.
    I have yet to do any bench marks, but I can reboot in just half a minute. Mmmmmm.
    JamesSav1
    BTW, My system is as follows:
    Normal
    0
    false
    false
    false
    MicrosoftInternetExplorer4
    st1\:*{behavior:url(#ieooui) }
    /* Style Definitions */
    table.MsoNormalTable
    {mso-style-name:"Table Normal";
    mso-tstyle-rowband-size:0;
    mso-tstyle-colband-size:0;
    mso-style-noshow:yes;
    mso-style-parent:"";
    mso-padding-alt:0in 5.4pt 0in 5.4pt;
    mso-para-margin:0in;
    mso-para-margin-bottom:.0001pt;
    mso-pagination:widow-orphan;
    font-size:10.0pt;
    font-family:"Times New Roman";
    mso-ansi-language:#0400;
    mso-fareast-language:#0400;
    mso-bidi-language:#0400;}
    MOBO
    MSI K9A2-CF-F 7388/v2
    CPU
    AMD 9500 PHENOM 2.20 GHz – 4X512KB CACHE – 1800 MHz – AM2+
    MEMORY
    8 GB - CORSAIR DOMINATORS – TWIN2X4096-8500C5DF 1066 MHz
    HDD’s
    Qty 2 - SEAGATE BARRACUDA – 7200.10 – 250GB – 16MB – Serial ATA 300 –
    OEM
    OPTICAL
    Qty 2 – SONY – DRU V200 S – DVD/DVDR – SATA
    PSU
    LOGISYS – 550 WATT ATX – ACRYLIC
    CASE
    ENERMAX – HUBER CHAKRA – FULL
    ATX TOWER
    COOLING
    NOCTUA NH C12P CPU COOLER COPPER HEATPIPE – Qty 2 120 mm Fans – 125 mm
    Fan
    MONITOR
    ACER – 21” Flat LCD
    GRAPHICS
    PONY TNT64 – 32 MB = **** but I’m getting a PCIE soon!
    Scholar:
  • 67 Answers
According to the information at:
http://www.pchell.com/hardware/beepcodes.shtml
AMI beep codes of 1 long and 3 short are, in fact, correctly identified as memory errors. One thing to note is if this memory is Dual Channel, you can only install the memory in groups of two. You must first fill DIMM slot 1 and 3 before filling DIMM slots 2 and 4.
The below website has much more information about your particular motherboard and there's a note about some JEDEC setting for memory that you might want to watch out for or disable to see if it improves stability.
http://www.msicomputer.com/product/p_spec.asp?model=K9A2_CF-F_V2&class=mb
As for Windows XP 32-bit not recognizing more than 3.5 (at most) memory, this is unavoidable. To see all 8 GB, you would need a 64-bit version of Windows. This is something that cannot be altered by BIOS or memory choices, unfortunately. Feel lucky in the fact that you have XP Pro as XP Home will only recognize up to 2.5GB. You'll never utilize all 8GB unless you upgrade your OS, so keep that in mind!
Posted on Mar 04, 2009
Please insert usb flash disk with BIOS file
You need to use a computer with Internet access, then go to the MSI WEB site to download the BIOS file for you model motherboard and then copy this BIOS file to an USB memory stick.
You and then insert this USB memory stick into your MSI computer and boot up the computer.
May 14, 2013 | MSI K8N Neo4-F Motherboard
BIOS update on MSI KT6 Delta (MS-6590 v2 5.0)
You should be able to get it from here.
http://www.motherboard.cz/driver/msi.htm
Apr 26, 2010 | MSI Microstar KT6 Delta (MS-6590)...
I have recently purchased a new HDD (I now have 2 Hitachi P7K500 HDDs) and built it into my system. I have first formatted the HDD I already had, then configured my BIOS for use of RAID 0. My mobo (MSI...
1. If you are just setting up your computer to have an a regular HDD and Backup HDD, i would think you should be able to set that up by booting onto your computer regularly, go to start, then into My Computer and right clicking on the HDD you want to set as Raid 1.
But if just want that other HDD for Space on your computer, all you had to do was plug it in and there you go... extra space.
Now if your installing windows 7 on the other drive i would find that pointless because you already have it on your first drive unless your putting 2 operating systems onto your computer.
Hope this helps.
Feb 27, 2010 | Microsoft Windows 7 Ultimate for PC
I try update my bio on my ao0751h netbook acer, and doesn't successfully, now my netbook doesn't turn on. How i recovery a bios?
Solution 1: Boot-block BIOS
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive.If you have a PCI video card,you won't see anything on the screen because the boot-block BIOs only supports an ISA videocard.
Award: The boot-block BIOS will execute an AUTOEXEC.BAT file on a bootable diskette. Copy an Award flasher & the correct BIOS *.bin file on the floppy and execute it automaticly by putting awdflash *.bin in the AUTOEXEC.BAT file.
AMI: The AMI boot-block BIOS will look for a AMIBOOT.ROM file on a diskette. Copy and rename the correct BIOS file on the floppy and power up the PC. The floppy doesn't need to be bootable. You will see the PC read the floppy, after about 4 minutes you will hear 4 beeps, this means the transfer is done. Reboot the PC and modify the CMOS for your configuration.
Solution 2: Get a new BIOS chip
  1. Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufactures send them for free.
  2. Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or Bios World
Solution 3: Hot-swapping
Note: I'm not responsible for any damage this method may do to you or your computer !
  1. Replace the corrupt chip by a working one. The best option is to take the working BIOS chip from a motherboard which has the same chipset although that's not absolutely necessary. It just has to give you a chance of booting into DOS. Before pulling the working BIOS chip out of it's original motherboard, set the System BIOS cacheable option in the BIOS to enabled.
  2. After you have put the working BIOS in the motherboard with the corrupt BIOS boot the system to DOS (with a floppy or HD).
  3. Now replace (while the computer is powered on) the working BIOS chip with the corrupt one.
  4. Flash an appropriate BIOS to the corrupt BIOS and reboot.
Solution 4: (for Intel motherboards)
  1. Change Flash Recovery jumper to the recovery mode position (not all products have this feature)
  2. Install the bootable upgrade diskette into drive A:
  3. Reboot the system
  4. Because of the small amount of code available in the non-erasable boot block area, no video is available to direct the procedure. The procedure can be monitored by listening to the speaker and looking at the floppy drive LED. When the system beeps and the floppy drive LED is lit, the system is copying the recovery code into the FLASH device. As soon as the drive LED goes off, the recovery is complete.
  5. Turn the system off
  6. Change the Flash Recovery jumper back to the default position
  7. Leave the upgrade floppy in drive A: and turn the system on
  8. Continue with the original upgrade
Feb 03, 2010 | Computers & Internet
Emachines notebook m5310 corrupted bios recovery
Modern motherboards have a boot-block BIOS. This is small area of the BIOS that doesn't get overwritten when you flash a BIOS. The boot-block BIOS only has support for the floppy drive. If you have a PCI video card you won't see anything on the screen because the boot-block BIOS only supports an ISA videocard.
Contact your motherboard manufacturer to see if they sell BIOS chips. Some motherboard manufacturers send them for free.
Contact a company that sells pre-flashed chips, like Unicore Software, FlashBIOS.ORG, BadFlash or BiosWorld
Note: Use a flasher from MRBIOS. They are known to work best. You can find them at ftp://ftp.mrbios.com
Reboot the system
Turn the system off
Oct 14, 2009 | Computers & Internet
MSI K9A2 CF motherboard powers up, but nothing happens
try to get into the bios and see if the function of the power switch assigned differently. there are MB that use the a hotkey in the keyboard to power-up the system. It should be there in bios. Read the MB's manual too. On OFF state, try typing "O" and "N" then hit enter
Aug 10, 2009 | MSI K9MM-V Motherboard
Problem with MSi K9A2CF mother board
More info on what happens from powering up your system and some of the devices listed you are using
Jul 22, 2009 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
How do i get rid of a blaster bug located in the bios , MSI k9a2 cf board without going on the internet with this computer,phenom 3 core proc, tried a antivirse software , nothing found, formated HD
Try using a good Antivirus software like McAfee, PCCilline, Norton Antivirus, NOD32 etc. First download the Antivirus and install then update it. In most cases such problems are solved. (ehteshamhusain@gmail.com)
Apr 21, 2009 | Computers & Internet
New Motherboard Problem
I believe you have a driver conflict
Check your BIOS is set for CPU etc.
And Uninstall all drivers And see if computer start with only the windows drivers present.
As if you have just installed windows and no M/board drivers.
And reinstall M/board drivers one at a time Should fix your problem
Nov 03, 2008 | Intel Motherboard
Detecting hard drives
try bios settings it may be set for a particular hard drive not yours and not on auto detect set for auto detect
Aug 02, 2008 | MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX /...
MSI K9A2 CF-F V2 AMD 790X AM2+ Phenom FX / Phenom X4 / Phenom X2 / Athlon X2 /AM2 Athlon 64 X2 / Ath... Motherboard Logo
581 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
