Question about Sanyo DP32746 32 in. LCD Television
How can I tell how old my Sanyo TV is. I bought it used.
With the new digital broadcasting, I cannot get this. I bought a digital converter box and a terk inside antenna. What do I do; it still does not work. Did I hook it up wrong.
  • Eve Hill Mar 04, 2009
    This still did not work. I have a message on the screen that says, "no signal." I put my TV on channel 3.
    Hi Clarkco2002,
    I finally got this to work; don't ask me how. I programed the converter box (Zenith) from Channel 2-49. The Terk Antenna Company said I could program up to 69. Do you know anything about this. It said to lengthen the other antenna to its full length. I did that. Than did nothing. Thanks though; without your help, I probably would have not got anything. At least now I can have my cable shut off and use the converter box and antenna. I will keep trying to get the other channels. I like 44 and 66 alot. Thanks again.
  • 360 Answers
Antenna to converter converter to tv tv on ch3 (analog)
Posted on Mar 04, 2009
  • clarkco2002 Mar 04, 2009
    the converter may be set to ch4, try with the tv on ch4.
    let me know what happens
We have a Sanyo CE32DFN2-B digital television. Our region has completed the digital switchover today and now we cannot tune the TV into any channels at all. Is this because our TV is too old to cope with...
Ur tv have a big back like hunt back creature?Yes?This tv it is not a Digital tv.It is an old CRT tv-tube analogue design tv.This tv still will work and have a broadcasting incomming signal if it is hook up to a pay services tv like Satalites tv like Direct Tv,Dish Network tv,Timewarner or Cox Cables services and ATT U verise or Verizon Fio digital hook up.If u wanted to watch a switch over FREE OVER THE AIR DIGITAL incomming broadcasting signal for this tv it will not work alone,the tv must have be to hook up to a BOX that call a DIGITAL CONVERTER BOX than this tv will work for a FREE OVER THE AIR DIGITAL broadcasting tv channels stantions.This DIGITAL CONVERTER BOX are no longer on sale on regular Stores.Tries websites like Amazon.com,Ebay.com will able to buy these BOXES so call DIGITAL CONVERTER BOX.
Aug 17, 2011 | Sanyo Televison & Video
Message says, "No signal."
try the tv on ch 4 in case the converter box outputs on that channel. let me know what happens and we can get this working
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
Sanyo TV, older model, tv converter box, terk antenna, will not p
DP models are already digital there is no need of a converter box. connect a outdoor antenna to the tv directly.
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Trouble receiving local channels on TV using new Magnavox converter box
Your digital converter box probably does not have an analog pass through that allows the old analog channels to go through to the tv's analog tuner.
Jun 27, 2008 | Sanyo DS27910 27" TV
Digital or not digital
this tv has no digital tuner built in to it. In order to recieve a digital broadcast the tuner must be atsc compliant. The best solution is to get a converter box to decode digital to analog signal.
Apr 03, 2008 | Televison & Video
Sanyo DS31590 and converter box
I just checked the owners manual online. Looks like this model only has an NTSC analog tuner. No ATSC digital tuner built in.
If you use cable or satellite TV services, the digital converters won't help you. The coupon-eligible ones are strictly for use with a traditional antenna. If this is your situation, ignore the remainder of this message.
If you use a regular TV antenna with this TV, then, yes, you will need a converter box. FYI, the Insignia model at Best Buy and the Zenith at Circuit City, and elsewhere (radio shack) have gotten good reviews from early purchasers. More converter box models will be available in a few months time.
If your current reception with your antenna is poor (snowy), you may have problems receiving the new DTV signals. If not, you should be pleasantly surprised with the quality of the DTV signals - and the extra "virtual" channels. Try the converter box using the RCA video and audio inputs, for a slightly better picture than with the coaxial cable inputs.
Good Luck
Feb 29, 2008 | Sanyo DS31590 31" TV
Digital signal conversion
If you have cable TV, satellite TV, or FIOS, the coupon eligible converter boxes aren't needed and aren't useful with those services.
They gov't coupon converter boxes are only good for reception with a regular TV antenna or rabbit ears.
According to the specs on epinions.com, no, this TV does not have a digital tuner. So, if you use a rooftop TV antenna (not satellite dish) or an indoor TV antenna, you WILL need an ATSC to NTSC converter box. You need not wait until next year, however, as most U.S. TV stations are also broadcasting digital (ATSC) now.
Feb 23, 2008 | Sanyo DS27820 27" TV
No real problem yet
yes,,,ur TV is a digital one...
Jan 28, 2008 | Sanyo DS25390 TV
Sanyo DP32746 32 in. LCD Television Logo
160 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
