Question about Canon PowerShot A70 Digital Camera
When I turn on my PowerShot A70, it comes on and immediately shuts itself off and the Error E18 appears on the screen.
    Sergeant:
  • 306 Answers
Crunchy lens moving sounds are mostly dirt inside. I stuck my M1033 inside the hose of a wet vac and operated the lens several times. Problem solved. Now I keep it in a cloth bag.
Posted on Jan 28, 2012
    Novelist:
  • 98 Answers
Canon Powershot's error E18 has to do with the lens:
If it appears on a black LCD with E18 written on the corner, it is mostly due to the lens getting stuck while trying to extend. The camera will beep a few times and the LCD will display a little E18 in the lower-left corner. The lens gets stuck in the extended position, and refuses to move either to focus the lens or to retract when powered off.
I am giving below a link which will help you with E18 problem.
http://www.e18error.com/repair.html
Hope this helps, let me know if you have a proble.
Please do rate and thanks for using FixYa and Best fo luck to get you camera out of E18!
Posted on Mar 04, 2009
SOURCE:
When i power my canon powershot A70 the display on the screen will illuminate for 3 seconds then a error will come on the screen E18
Hello there,
The E18 error is related to the LENS not able to retract fully. If it is still under warranty, I would advise you bring it to the nearest service center. This is to avoid further damages. Otherwise, you can try a few things below.
There are a couple of things you can do.
1. Turn it on and then off. Spray canned air around the lens.
If trick 1 will not work out, try this.
2. Make sure the battery is fully charged. Turn on the camera and then give it a couple of firm whacks on the side. Make sure nothing is blocking the lens and wait for it to fully retract.
Let me know how it goes.
Nov 18, 2009 | Canon PowerShot A70 Digital Camera
My camra has E18 on the screen
E18 is an internal error, the lens drive mechanism.
Canon has to fix it. If it is not under warranty, it will cost you around $160.
Apr 10, 2009 | Canon PowerShot A75 Digital Camera
Canon powershot sd400 error code E18
Yes !! I wacked it a couple of times on a hard surface and it started working again after I dropped it and got the dreaded E18 error mesage in the middle of a Jewelry shoot. wm
Oct 14, 2008 | Canon PowerShot A80 Digital Camera
Cannon A70 lens stuck in middle causing it to keep powering off
The E18 error is fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for about 50% of lens errors, but if the camera is out of warranty they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 06, 2008 | Canon PowerShot A70 Digital Camera
Cannon power shot a70
Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Nov 24, 2007 | Canon PowerShot A70 Digital Camera
E18
The E18 error is fairly common. Here's some things that you can do to try to correct it. Have already fixed several cameras with this problem by using these methods:
Nov 04, 2007 | Canon PowerShot A75 Digital Camera
Canon Powershot A510...
The a70 drops a screw in to the mechanism.
you will need to take the unit apart carefully as it is intricate.
I used a web site to show me but have lost the link.
try looking for cannon A70 problems / erors Etc.
Oct 15, 2007 | Canon PowerShot A510 Digital Camera
PowerShot A70
This comes up when the lens sticks. Try removing the colar around the lens, then turn the camera on/off and give it a "little help" to open or close, it's probably just a little stuck
Dec 14, 2006 | Canon PowerShot A70 Digital Camera
Lens won't open/flashes E18 on screen
i got my camera a couple of mounths, but i have not used it alot. When i turn it on, the start up screen wold come on but e18 would come up on the screen and nothing would happen after. i desperately need your help to fix my camera. thank you.
Sep 24, 2006 | Canon PowerShot A70 Digital Camera
Canon PowerShot A70 Digital Camera Logo
205 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
sathish kumar
sathish kumar
Are you a Canon Camera Expert? Answer questions, earn points and help others
