Question about Refrigerators
Bulb does not light on refrig side. When it happened it popped out the two control knobs. Reset control knobs and replaced bulb but the bulb will not light. After resetting the knobs the refrigerator started cooling again. Manual does not show any fuses, so I'm not sure what to try next. Whirlpool GD5SHAXNS00 side by side.
  • Ken Bledsoe May 11, 2010
    Have you made sure the light bulb is still good. Sometimes when the light bulb gets bumped around the filaments break.
    President:
  • Refrigerators Master
  • 2,651 Answers
I would alssume(knowing about this refrig) that the leectronic control board hasgone bad. the board is located behind the unit next to the compressor, inside a white housing, if you rmeove this board yull probably see a "burn" on one or more ofthe resistors, this is what controls the lighting in refrig sect, not affecting the cooling but only lights
Posted on Mar 04, 2009
No lighting on my climate control knobs. how do I replace the light bulbs?
General advise:Before removing anything check the fuses.For reacing the bulb:Must pull off the panel,remove the knobs by gently force them out,under must have some screw/clips to allow remove the panel.The panel may need help to pop from sides,don't force it,use plastic card/tool.Exersize on a old radio removing the control knobs.Some cars u have to unscrew the down side usually the ashtray.The bulb may be hard to identify,exersize removing bulbs on a wasted dashboard from a car/scooter...
Oct 22, 2013 | 2005 Kia Optima
Lights in refrigerator compartment flickering
You have a bad electronic control board . This part is mounted on the back of the refrig , at the lower left corner , inside a plastic holder . The part number is W10135090 . It costs about $ 100.00 . This board , also controls the 2 control knob lighting .
Apr 21, 2010 | Refrigerators
2007 pontiac vibe gear shift light replacement. How do I get console apart to replace bulb.
On the 2004 Pontiac Vibe that I owned, I ended up taking it to the dealer. Perhaps this advice can avoid having you end up at the same place!
Remove the middle environmental control knob (fan blower speed, I think) by tugging on it until it comes off. Underneath you will find a single Phillips screw. Remove the screw and gently (so you don't mar it), pull at the plastic trim surrounding the environmental control area. It should pop out. You may also want to remove the two-prong AC outlet by prying it gently out with a small slotted screwdriver before attempting to pry out the trim panel.
After that panel is out of the way, you are ready to tackle the plastic trim surrounding the shift knob. Begin by removing the small holding compartment at the base of the shift knob. There is a single Philips screw holding the plastic piece to a supporting brace on the lower end. Four additional screws on the upper end are revealed by the removal of the environmental control trim piece as previously described.
Okay, from there, you're ready to gently pry loose the trim panel surrounding the shift knob.
The bulb can be located on the driver's side. It's a 'funny' looking bulb that is integrated into a two wire bundle. You may end up having to replace the bulb+wire bundle as a unit. The electrical connector is on the opposite side of the shift knob.
Feb 20, 2010 | 2004 Pontiac Vibe
Light and temperature indicator on refregirator do no operate. Wife heard a pop when she opened refrig. door.
If the refrig light AND the temp adjustment knob lights , went out , you need to replace the electronic board . Pt # W10135090 . This part is located behind the refrig , at the bottom left , with 2 screws , inside a white box . The board runs about $ 80.00 , and is easily replaceable .
Nov 22, 2009 | Whirlpool GS6SHEXNS Side by Side...
I have a GSS25KGMD fridge. I opened the Fridge compartment top part was very warm and the bottom was cooler. Upon investigating more I noticed that the fridge bulb was very hot. So I pushed the fridge...
Your refrig light switch does control the freezer fan and the refrig light bulb . Replace the refrig light switch .
Open the refrig door , freezer fan goes off and the refrig light comes on .
Nov 03, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
It was working fine yesterday. When I got home I
Try unplugging refrig for a few min , then plugging back in . This will reset the adaptive timer and at least get the refrig working . The adaptive timer , is located in the control panel . Pt # 4388932 . To replace this board , remove the knobs and pro the top of the panel outwards . Remove the 4 screws holding the panel ( 2 are on the inside by the light bulb ) . You should now have access to the board .
Sep 30, 2009 | Whirlpool ED5VHGXM Side by Side...
Bulb replacement
Look inside the trunk for the back side of the light module housing. Unscrew the large black knob. Before unscrewing it all the way push on the knob to pop out the light module housing from the outside fender, or place your fingers under the lip and gently pull on the housing once the knob is removed. Once pulled out of the housing the bulb sockets will be visible outside of the trunk. replace the l;amps and reverse the procedure to put the light module back into the socket. Screw back on the black knob.
The front lights are similar but have tension springs instead of knobs.
Jul 03, 2009 | 2000 Volkswagen Beetle
Bulb went uot new bulb not working
...will need to check power at socket. using a multimeter.
Jun 17, 2009 | Whirlpool Gold GS6SHEXNQ 25.6 Cu. Ft....
How do I replace a fog lamp in my 2003 GMC Sierra hd
are you talikn about just the bulb? or the whole light?
For the bulb just unplug wiring from the back of the bulb and twist bulb and pull, do not touch the bulb of the new light the oils from your fingure will and can cause the bulb to burn out premature
the entire ligh has two pop rivets one on each side remove those. there is also an adjuster knob remove the knob and the spring pull the light off and replace with new.. you may want to mark the location of the adjuster knob so that on reassembly you know where the adjustment was for proper light position
Mar 04, 2009 | 2003 GMC Sierra 1500
Refrigerators Logo
159 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
