Question about Samsung TS-H492 (TSH492AWRBH) CD-RW/DVD-ROM (Combo) Burner
I have a question, I install a Hard Disk as a slave with the CD ROOM data buss, but when I turn on the pc the cd room wont be recognized, What would you recommended
    Scholar:
  • 56 Answers
Do you have both a primary & secondary IDE controller? Make each Master on its own controller. Or make the hard drive master with the DVD as the slave on the same controller.
Posted on Mar 04, 2009
Dvr not recognized by pc
check the pin on your dvr with the pin on your hard disk is master or slave if hard disk is master then make the dvr slave or check the pc bios
Jan 20, 2014 | Computers & Internet
Hi, I have a Sony Vaio Desktop Serial #PCV-RS100. I just recently got a new hard drive so I re-installed windows and needed to update all my drivers. Alfter updating everything, I am having problems with...
Shut down and unplug your system if already running. Opencasing and disconnection CD/DVD and remove it out. Check its all connectors, isthere all pins exists. Check jumper setting. If both hard disk and CD/DVD areattached with the same DATA CABLE (ALSO CALLED RIBBON CABLE) then jumpersetting of the CD/DVD must be at SL (SLAVE). AND if they are connection withthe different DATA CABLES they must set at MA (MASTER). NOW start your systemonce without CD/DVD and again shut down it properly. Attach again CD/DVD andwatch it. If all efforts have been done, then you should check DATA CABLE maybe it broken some where. Change the DATA cable and you will done INSHALLAH.
Sep 23, 2010 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
If i put in a cd, it doesnt load or install or anything. nothing comes up. can you please help?
Please check if the CD/DVD driver is installed properly:
To check:
1. Click Start - Right-click My Computer Choose Properties
2. Click Hardware then Device manager
3. Check if there is a yellow question mark on CD/DVD
If Yes - Reinstall CD/DVD using WINDOWS UPDATE
Alternative:
1. Try to check for loose connection between your IDE cable and IDE Socket
2. Check if the 12V Cord from the Power supply is properly connected to device
3. Check MASTER or SLAVE setting:
Normally the IDE Hard disk will be your PRIMARY and the CD/DVD will be your secondary/slave -----
MORE DETAILS ARE DESCRIBE THOROUGHLY IN THIS SITE:
http://www.ehow.com/video_4444761_setting-pins-cd_dvd-hard-drives.html
Please Rate. Thanks.Cheers!
Apr 22, 2010 | Samsung SM-352F CD-RW/DVD-ROM (Combo)...
Ch08ls10 lg wont recognize dvd+r
Click the Windows "Start" button, and open "My Computer" -- if you don't see an icon for the CD/DVD drive, it's not correctly connected:
* no electrical power
* no data-cable
* jumpers on drive (MAster, SLave, CableSelect) improperly set
* just a "defective" drive
Does the drive-tray open/close when you push the button? If so, you do have electrical power.
Do you hear the drive spinning, or feel it vibrating,
when you insert a disk?
Best guess: shutdown your computer, move the "jumper" (MA, SL, CS) on the "back" of the drive to a different position, and restart.
Jan 27, 2010 | LG Black 8X Blu-ray/HD DVD-Rom LightScribe...
SLIM portable USB2 otical drive
Hmmm sounds like corrupt install or possibly the bad drive....or the disk you are trying to read is bad
Sep 11, 2009 | Samsung External Slim DVD-W USB Compatible...
Clip on back of drive?
CS: cable selector
SL: slave
MA; master
if ur installing this drive as a main drive put it in master if justa secondary drive put it in slave
if ur ide cable ve one more room for one drive it will select automaticly slave or drive
rate me as fix ya!!XD
Aug 19, 2008 | Apple Genuine Pioneer "SuperDrive"...
Samsung TS-H492 Jumper
hai
if u have two seperate data cable to hard disk and dvd rw,there is no big changes to made in jumpers,but u have only one data cable u should select jumper as a master to hard disk and slave to dvd rw,
basic identification to master jumper is that ,it place is close to data cables ,and slave is next pin,in typical models
also u se the detail in hdd and dvd rw's jumper locations
thanks
prasanna
Mar 01, 2008 | Samsung TS-H492 (TSH492AWRBH)...
KHCRW 52 24 52 CD-ReWriter not recognized
Change the Jumper To Master Or Slave.
CS Is cable Select, your computer may not support this Option.
If installing on a cable with a drive, already connected. i.e hard-disk. if the hard-disk is slave set the cd rom to master.
Enabling both channels, is the 2 individual slots on your motherboard. Primary And Secondary. Or IDE 1 And IDE 2.
This will solve your Problem.
Mike @ compurepair.
Feb 20, 2008 | KHypermedia (KHCRW522452) (20326452) CD-RW...
Dvd rom drive
is cable on master jumpers or slave ?
Feb 07, 2008 | NexxTech (COB6V5216) Burner
Wont recognize burned disks
This does sound like a defective drive, most likely a laser / reader issue, because the refractive properties of the CDR is different from a "pressed" disk it looks like thia failed TOC seek issue, the head starts at the center of the disk and reads outwards, the click noise is most likeley the head reaching the terminus (the outer limit of the motorised movement), the drive then unable to find the TOC gives up and decides the disk is unreadable. if this drive is within the manufacturer's Warrantee period I would reccommend sending it back.
Apr 25, 2007 | NEC NR 7900A (NR7900) CD-RW Burner
Samsung TS-H492 (TSH492AWRBH) CD-RW/DVD-ROM (Combo) Burner Logo
74 people viewed this question
Top Samsung Computers & Internet Experts
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
