Question about E-Machines eMachines Desktop PC
Emachines computer problem
Computer monitor says self test, check your pc and signal cable monitor is working
  • 3 Answers
Happens quite often to me also. My best guess for you is plug the monitor into the other jack it fits into. It will work with a reset. Also make sure that all cords are tightly plugged in.
Posted on Mar 04, 2009
  • 75 Answers
Have you checked the cord and connection to the video card?also you could try resetting the bios.unplug the power cord on the pc.remove the batterie on the motherboard.power it back up.remove power cord again and replace batterie and restart pc.
The screen reads no signal
eMachines flat-screen monitors offer high quality at low cost.
eMachines flat-screen monitors are compatible with most brands of PCs.
Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings.
These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet.
Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power.
Plug the eMachines monitor's power cable into a working AC outlet.
Press the monitor's power button.
Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power.
Orange or blinking LEDs indicate low power or no signal.
Green LEDs denote a working connection..
Perform a monitor self-test.
Switch off the monitor.
Unplug the video cable from the monitor.
Press the eMachines monitor's power button.
An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly.
Plug the eMachines monitor's video cable into the video port on the computer.
Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot).
Press the eMachines monitor's input button to change the monitor's setting to match the computer port used.
Set your monitor to DVI if connected to your computer's DVI port.
Set your monitor to VGA if connected to your computer's VGA port.
Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved.
Jul 15, 2013 | Acer eMachines Black EL1850G-42w Desktop...
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
The monitor i see selt test G check your
Connect the monitor to a different computer, e.g., a laptop, to see if the monitor works at all.
Connect a different monitor to your computer, to see if your video-card is outputting any signals.
May 10, 2011 | E-Machines eMachines Desktop PC
Computer not booting up
Could be one of two things:
1. Signal cable from monitor isn't hooked up. (either monitor end or computer case end)
2. Video card in the computer is damaged and not putting out signal. This is unlikely though as usually this will trip the motherboard into beeping when you turn the computer is turned on.
3.
Jan 15, 2009 | E-Machines eMachines Desktop PC
Dell172fpb 17" monitor
Self-Test Feature Check (STFC) Your monitor provides a self-test feature that allows you to check whether your monitor is functioning properly. If your monitor and computer are properly connected but the monitor screen remains dark, run the monitor self-test by performing the following steps:
  1. Turn off both your computer and the monitor.
  2. Unplug the video cable from the back of the computer. To ensure proper Self-Test operation, remove Analog (blue connector) cables from the back of computer.
  3. Turn on the monitor. The floating 'Dell - self-test Feature Check' dialog box should appear on-screen (against a black background) if the monitor cannot sense a video signal and is working correctly. While in self-test mode, the power LED remains green and the self-test pattern will scroll through the screen continually.
  4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after you use the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Thanks
proton
Oct 26, 2008 | Dell E171FPb 17" Flat Panel LCD Monitor
You asked for more info
I think you're Emachine is just using the internal video output that came with it, better get this GeForce 7100 GS Video Card ..
Good luck............
Aug 26, 2008 | E-Machines eMachines Desktop PC
I have a old emachine desktop and whenever i turn the monitor on it just says self test check your pc and signal cable monitor working. i have everything set up correctly and it still doesn't work.
replace the little watch battery thats in it open the case and you will see it $2.35 at wal mart. mine was doing the same thing fixed it in about 15 min. open the case and you will see it
Aug 02, 2008 | Computers & Internet
No picture
have you tried clening out the conetor end or unpluging it the pluging it back in
Jun 09, 2008 | E-Machines eMachines Monitor E15T4
E-Machines eMachines Desktop PC Logo
212 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
