Question about Samsung RS2630WW Side by Side Refrigerator
FILTER NOT WORKING
HAVE HAD FRIDGE FOR 6 YEARS JUST REALIZED THAT WATER DOESN'T GO THROUGH THE FILTER BUT STILL RUNS WATER TO THE DOOR AND ICE MAKER .  INSTRUCTIONS SAY WATER DOESN'T RUN WITHOUT FILTER IN BUT IT DOES.
    President:
  • 2,976 Answers
Water will run through a filter until it's clogged. Check the filter by removing the end that goes into the refrigerator. If it flows, it's still open. It should be replaced after 6 years though. If water doesn't come out of the filter but still floew through the refrigerator, it's connected wrong.
Posted on Mar 04, 2009
What would cause the airflow to stop to fridge when freezer door is closed? (kenmore model 106)
Ice in the path of air flow to fridge. The freezer also kkeps the fridge cold via a fan that blows the cold air from feezer to fridge.
Aug 21, 2011 | Kenmore Refrigerators
Built-in side by side. The in-freezer ice maker is not working properly. makes one row of ice every 10-2 hours. i have checked temp, water filter and water line...all is fine. had the ice maker replaced...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Kitchen Ranges
Refrigerator does not produce ice or water. Kenmore Elite Refrigerator Model Number: 795-775-69600
If you have both ice and water stopping you have a water supply issue.
Water enters under city pressure through an eighth inch supply line.
Start simple and work from there.
If the fridge was moved the line can get kinked. Slide the fridge out and check you have water to it. You can loosen the supply line connection just a little and you should see water leaking. If not it is a plumbing issue in the house. Most likely a the supply line is kinked or possibly someone closed the shutoff valve to the fridge.
OK so we have water to the fridge.
Water comes in and connects to a water filter and then to the door.
If the filter is badly clogged it can cause low pressure to the door and that would cause the problem. Check the filter.
If no go still then check where the water is stopping.
Remove the from cover from under the unit. That is the plastic grate at the bottom of the fridge. It will just pull off but be gentle and take your time so as not to break anything.
Water supply will run through a clear plastic hose. It runs to the filter then to the bottom of the freezer door and up through the door.
You can sometimes see where the water has stopped and clear or replace parts as needed.
There is a connection just before entering the door from the filter. You can loosen that to see if you have water to that point.
If you have water past the filter the problem is in the ice maker and water supply inside the freezer door. Water can leak here, expand, and crack plastic parts easily.
If there is water to the door then you need to dig into that. This gets a little more complex to describe but in short take the ice maker out and check for water supply or broken parts. The problem is probably before the ice maker as your water in the door is not working. This indicates it is not just the ice maker.
Hope this helps.
Mar 12, 2010 | Kenmore Refrigerators
RANGEMASTER FRIDGE /FREEZER WATER FILTER WARNING LIGHT
Hi i have a rangemaster s x s fridge freezer and the ice maker has stopped and now the whole fridge freezer has stopped. its 2 years old and out of warrenty can anyone help please with a suggestions as to whats wrong.
Sep 18, 2009 | GE PDS22LBN Bottom Freezer French Door...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
I Have a FRS22ZRGD1 Double door fridge freezer combo , the ice does not get any water . I have water to door to fill glass. I replaced water filter a pure souce type. I replaced solinoid valve still no...
For all of you having problem of not getting any water to ice maker the water line running from solinoid valve to ice maker , mine was plugged solid with ice- try blowing through it once you have line removed from solinoid valve. I know they say you can removed the ice with a blow dryer but I tried that the ice was too far down to melt it .I took the line loose from the back of the fridge and un attached retaining screw and pulled plastic insert through cavity of fridge and ran hot water through it. Now it works fine.
Apr 17, 2009 | Frigidaire FRS26ZSG
Q: Does the water for the ice maker go thru the in-fridge filter?
the water should go thru the filter first then to everything else.
Jan 02, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Sep 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
ICE MAKER...NO WATER IN ICE PAN
do you have water thru the door? you may have air in the line. filter incorrectly installed / or a bad water valve
let me know
Apr 04, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
Samsung RS2630WW Side by Side Refrigerator Logo
173 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
