Question about Dewalt D25330K 2KG Sds Plus Demolition Hammer 240V
I need a repair manual for a Kango 900 demolition hammer, might anyone have a copy . the wheel above the piston has the offset bolt broken off. motor runs perfect6 but of course the chiesel bit does not move! wayne finner mwf01@a0l.com or on this bullitin board
  • 2 more comments
  • phy8dop Apr 01, 2009
    I also have a kango hammer. The motor is running, but the chisel has got no force behind it, it is just vibrating slightly. It sounds like it might be the same problem. Is this issue common?
  • Andrew Sheedy Jun 12, 2013
    Hi mine was similar put general purpose high heat grease on tool and it worked to a degree
    Hi did you get manual if so can you forward it on
    Add a CommentCheers
Hi
It could need more grease around the piston or it could be the teeth on the gears are stripped
Den
Posted on Feb 24, 2010
Kango 900 manual
Could be brushes, switch or wiring. Use a meter to see.
Nov 25, 2013 | Hammering
Need diagram for kango 900 concrete hammer drill
Hi Vicki
Is it the old all silver one or the new one with the red motor housing?
May 19, 2012 | Milwaukee Tool Hammering
Kango 900 hammer:\r\nDon't know how to greace the
Milwaukee K900K or the English Kango 900K Blue old or Red some younger handle it differs very much English Kango was using a thick brown grease in 2 chrome colored plastic bags . the Milwaukee K900K has a lubrication grease also not oil but be aware of the operating hours i f you have a K900K model from Brand Milwaukee tools replace also a service kit and the bearings on the armature is important also Its neccesary to protect you from damage
if you have a English Kango its hard and expensive to get a spare parts and most times the tools are worn in the front of the chisel stroke bolds do not get right close and the piston pins are worn it was a good tool about 20 years ago i have serviced much of them . but the first thing thats important that its air-tight in front of the chisel and everywhere thats having a mechanic/pneumatic duty
Milwaukee Services and fill k900k with (IMPORTANT) the right number
Jun 05, 2010 | Electric Demolition Jackhammer
Demolition tool or breaker
The shaft from the motor to the drive gear is likely not working the action of the hammer. There is a gear which spins the gears to achieve the hammer action, suspect the gear is either stripped, broken or both.
Jan 17, 2010 | Dewalt D25330K 2KG Sds Plus Demolition...
I need an schematic diagram for repair a kango demolition 900 bv where i get parts for it
they went out of business a few years ago,i have some parts no manual i need one also
Sep 23, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
Kango 900 demo hammer on off switch needs replacement were can i purchase parts.
what country are you in? in australia atlas copco are the distrbutors. i`m sure you can find out on the internet
Aug 11, 2009 | Hammering
No hammer
i have 900 kango jack hammer motor work but don't jack in sacramento any repair dose work on the jack hammer can you give info who work in sac thanks jim
Jul 01, 2009 | Dewalt D25330K 2KG Sds Plus Demolition...
LOOKING FOR A MANUAL & INFO
Milwaukee now owns Kango, unfortunately I believe the 950sv is the old style. Parts are no longer avail. I have about 20 of the breakers. It is really too bad, they were great machines.
Jan 15, 2009 | Electric Demolition Jackhammer
Dewalt D25330K 2KG Sds Plus Demolition Hammer 240V Logo
3,118 people viewed this question
Top Dewalt Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
richie46
Are you a Dewalt Hammering Expert? Answer questions, earn points and help others
