Question about Water Heaters
Whirlpool electric smart water heater not heating all the time
  • Anonymous Mar 17, 2014
    electric water heater with energy smart diagnostic control flashes 3 times and says and says sencor failer
    electric water heater with energy smart has no power at heating element
DO YOU HAVE A MANUAL FOR AN 80 GALLON
ENERGY SMART ELECTRIC WATER HEATER?
THE MODEL # IS EE3Z80HD055V
I HOOKED EVERYTHING UP, THE GREEN LIGHT IS ON BUT I DONT HAVE HOT WATER YET.
Posted on Mar 18, 2009
  • 88 Answers
Could have one faulty element.
Posted on Apr 18, 2009
  • Bati99
    Bati99 Apr 18, 2009
  • Bati99
    Bati99 Apr 18, 2009
5 Suggested Answers
gary1121
  • 332 Answers
SOURCE: I have a electric whirlpool 50 gal. energy saver
the thermostat should be replaced it only has one on the upper eloement, it has the dial on it to set the temp, but if it is only 3 months old it comes with a 1 year parts 6 year tank warranty, if you call whirlpool and tell them about this problem they will have there own teck or sub contractor that they use to come out and fix it for free,,, first go to there web site and put in your serial number and it will tell you how old the unit is, sometimes they sit for a while and are actually out of warranty before it is installed,, also did you install it your self?? if you did di you fill it with water all the way till the water came out of the hot side on your faucet full force before turning on the electric,, if not you have fried the whole unit, you will need to replace both elements and the thermostat, the elements must be completely submerged in water before they have the power turned on,,,
Posted on Jun 27, 2009
SOURCE: HOOKED UP WATER HEATER CANNOT GET HOT WATER
recently got a new water heater, we are not getting very much hot water and I think it is hooked up wrong. Cold water coming to the tank is in (H) spot on the heater and?? will this keep us from getting very much water???
Posted on Jan 03, 2010
puertobori
  • 7733 Answers
SOURCE: The water is not heating.
If you know a little on mechanics try to disassemble the unit in order to clean it inside.Or get an Electrician to repair it.Those unit works like the electric ranges.The heating sys of the water has inside electric parts that with the time get burn.
Posted on Oct 12, 2010
ultrat
  • 500 Answers
SOURCE: I replaced the heating element
Does it have a reset on control ..check breaker .. use a volt meter on high setting check power at element work your way back find where power stoppes..
Posted on Apr 21, 2011
I have a whirlpool water heater model 333j50rd045v no green light on control box and no hot water do have 220 into the unit the unit is about 12 yrs old
You have energy-smart electric water heater?
Control box might be bad.
Copy following link for troubleshoot manual, and whirlpool phone number for replacement parts etc:
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Gene
Aug 22, 2013 | Water Heaters
Water heater heats water and then cuts off. I replaced the lower element with a guaranteed for life element. It still heats up and cuts off. There is a control box on top that allows for an easy reset. ...
1) Bad thermostat or thermistor depending on model.
Whirlpool/Craftmaster/American energy smart has control box on top, and you can order parts from Whirlpool.
2) Copy following links to help identify product.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Add a comment with more detailed information:
You have electric water heater.
Unknown brand, possibly energy-smart.
Unknown control box.
Cut off? Do you mean 'reset' is tripped?
4) Whirlpool energy smart requires 10 gauge wire and 30 amp breaker.
Control panel may not function with undersized electric supply.
Control panel has blinking-light errors ... if no error code then maybe the control box is bad.
Jan 18, 2013 | Water Heaters
Troubleshooting whirlpool ee2h50rd045v water heater
1) Copy following links for whirlpool energy smart resources:
http://waterheatertimer.org/pdf/Energy-Smart-troubleshooting-guide.pdf
2) Control box is probably bad.
There are 2 types of control boxes for older-style energy smart water heaters.
You will need model number and serial number from label on side of tank to order from Whirlpool.
3) This older-type energy smart water heater is probably discontinued by AO-Smith, American, State, Craftmaster, Reliance water heater group that makes Whirlpool and Kenmore water heaters.
New generation energy smart offers interface with home automation and/or non-existent smart grid.
Older energy smart only offered potential interface with non-existent smart grid.
Dec 23, 2012 | Whirlpool Water Heaters
Energy saving devise light blinking and no hot water
Water heater is not identified.
Add a comment with information that appears on label on side of tank for possible help.
You might be talking about Whirlpool energy smart electric.
The error diagnostic lights flash a code: the code decipher is printed on the diagnostic control box on top of heater.
Call Whirlpool: you need model number and serial number from label located on side of tank.
1-877-817-6750
Open following links for energy-smart resources and typical manual:
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
Aug 04, 2011 | Whirlpool Water Heaters
Hello - I have a 6-7 yr old Whirlpool EnergySmart 50 gallon 5500 watt water heater. (Two control boards fried and were replaced free). Symptom now is not enough hot water. No 'error codes' are blinking...
1) Residential water heaters are non-simultaneous. Only one element works at a time.
Upper element comes on until top of tank is heated, and then lower element is switched on until lower part of tank is heated. Lower element keeps tank hot during standby hours
http://waterheatertimer.org/How-it-works.html
2) Typical Whirlpool energy smart has 4500Watt elements. Look at label on side of tank
If both elements were ON, that would draw 9000Watts or 37.5 amps, requiring 50 amp breaker and 8 gauge wire. V x A = Watts.
All dual-element tanks are 240V.
Whirlpool energy smart requires 10 gauge wire and 30 amp breaker so electronics are not starved during operation. If your wire or breaker are undersized, that is suspect for repeated failure.
3) Typical electric water heater heats 21 gallons per hour. First hour delivery is higher since elements heat water as you use it. Overall however, electric water heater cannot re-heat as fast as gas because gas water heater burner carries more BTU punch per minute than electric element. Gas heats about 41 gallons per minute, with higher first hour delivery.
4) IF YOU HAVE OLDER energy smart and installed newer board, then you could have non-simultaneous operation is reversed so that lower element comes on first.
Read following post at Fixya:
http://www.fixya.com/support/t8263226-our_water_heater_doing
Contact Whirlpool 1-877-817-6750
5) Another potential problem is that you have sediment inside tank and that is reducing efficiency of lower element.
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 09, 2011 | Water Heaters
Whirlpool Energy Smart Water heater - light is solid green then every now and then blink a couple of times then go solid again.What does this mean?
2 flashes = high water temperature (the water heater comes set at 120, and you can set it lower or higher)
3 flashes = sensor failure (temperature sensor similar to a thermostat on regular water heater)
4 flashes = upper element
5 flashes = lower element
Links below are for Whirlpool manuals
http://www.whirlpoolwaterheaters.com/support/Manuals.aspx
The water heater is working right now.
If the elements go out, they are available at any hardware store.
The temperature sensor is easily replaced and can be ordered from Whirlpool.
You might want an extra temperature sensor on-hand so repairs are not delayed.
Link below shows the product in detail.
Let the water heater do its job until it fails.
Oct 22, 2010 | Water Heaters
Water Heaters Logo
1,436 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
