Question about Maytag MDE3706 Electric Dryer
Timer wiring order
Alright I was changing a bearing on the dryer and had taken pictures of the wiring order on my phone. Well just my luck as I was putting it back together I dropped the phone and broke it so now no idea of the order.
I need help laundry is piling up and now the dryer only blows cold air.
I have the yellow wire on YL, The gray wires on GY, The red on RD, The RD/WH wire on PK, The orange and one black on the OR, The yellow/black wire on the S, One white and black wire on WH, On the M I have the other black wire and the other white and black wire.
  • 3 more comments
  • charlie_5970 Mar 04, 2009
    Yeah it has a diagram, but I am not the best with this stuff. I did my best to read it. I did try to put both the whites on the same one, but when I do the signal won't stop going off.
    Alright if both the whites and a black go on M. Orange and gray goes on OR then where does the other black wire go?
    Here is a drawing of the timer.
    http://img7.imageshack.us/my.php?image=d...
    Here is the actual timer I just figured the drawing would help see the Letters.
    http://img3.imageshack.us/my.php?image=i...
    Two black wires coming off the timer and a gray one is also coming off the timer right below the two black ones.
    http://www.apwagner.com/index.php?main_p...
    That is the timer itself....
    If that does not come up it is Maytag Part # 37001240.
    1 yellow wire
    2 black wires(coming off timer)
    1Gray wire also attached to timer
    1Orange wire
    1Yellow and Black wire
    1Red wire
    1 Red/white wire
    1 Gray wire( coming up from dryer)
    1 White/Black wire(coming from little box next to timer)
    1 White/Black wire (coming up from Dryer)
    Hope this helps and thanks in advance for taking time everyone.
  • charlie_5970 Mar 05, 2009
    Did not get it fixed yet. I have a pic of the timer without wires and a couple others in the comments above.
    President:
  • Maytag Master
  • 2,651 Answers
There should be a diagram within the control panel, if but by looking at your post, you should NOT put the black and whites to one nad a vlac and white top another, they shouldbe on same terminal(s), whites are used for neutral, and blacks for line voltage.
Posted on Mar 04, 2009
  • Ron Coons
    Ron Coons Mar 04, 2009
    found a diag, lets see if this works
    http://www.servicematters.com/maytag_lib...
    1=yellow (power in)
    1a=orange, grey
    3=grey
    4=pink,red
    S= yellow(s)
    M= black, white/black,white/black
    looks like a black and orange wire leave the small round "timer motor"withthe black to the M terminal and teh orange to the 1a
    hopefully this helps
  • Ron Coons
    sorry but did you ever figurethis out??? perhaps a pic the timer without any wires so i can see the terminal lettering, or perhaps just tell me what terminal numbers you have?
The dryer in the picture isn't mine I'll upload picture later if I can timer has abc but it's lettered back to front ie 1-5 an there is nine pin connectors for timer then other wires for front panel did...
Email ernesto cuadra Fixya with a request for a schematic. He has one for a similar model. His email address is: ercupa@netscape.net
And, this information was found here:
Indesit tumble dryer
Hope that helps.
Oct 19, 2014 | Dryers
SCHEMATIC FOR AMANA DRIER NED7200TW
Hi ,
You cannot jus change the timer.You need to change the user console and display board fully.
Here is the part.Can order online.
http://www.repairclinic.com/PartDetail/User-Control-and-Display-Board/35001269/1185581?modelNumber=NED7200TW10
Here is the parts manual
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dryer-Parts/Model-NED7200TW10/1268/0151200
Thank You
Nov 28, 2012 | Dryers
How do i change my timer
Please make sure that the wiring is not tampered and taken out. Purchase the same type of timer and connect the wires after you have a sketch diagram with the wire codes so that no terminal wiring mistake is done while changing the timer.
Use the colour codes or use wire codes on the wire so that a wrong wiring is not possible.
Mar 11, 2011 | Dryers
My daughter's dryer comes on by itself ....came on last night at 1140 PM by itself...and ran by itself thru the night until 600 AM this morning. i'm thinking maybe the timing switch/mechnism is...
you are correct. The timer has to be turning on your dryer. You can change out the timer or have your daughter leave the door open to the dryer this will disconnect the power to the element and the motor. You can use the door permanently or just until you get a chance to replace the timer. When replacing the timer you will need to disconnect the power to the dryer. Then remove the back plate behind the timer and selector switches. This plate is held on with 5/16 hex screws. Then remove the wires to the timer it will be a multiwire plug. Pull the knobs off the front of the timer they can be stubborn just take your time and use a piece of cloth between the flat blade screwdriver and the knob/dryer if needed. After removing the knobs you will see 2 or 3 usually phillips screws under the cap. Remove these screws andthe timer will come out. You can order a new timer on line or a good supply center is Marcone Appliance in St Louis Missouri. I used them for 30 years and was pleased with the prices and prompt service. When you open the panel look for frayed or burnt wires there is a chance of this but normally the dryers timer is the problem. You can trim and repair wires with **** connectors you can get these in a kit with the stripper/crimper pliers at any hardware store. Good luck and the door thing is so you can order the part and have the time to get to your daughters home.
Sep 16, 2010 | Kenmore 67082 Electric Dryer
Two year old kenmore dryer has loose drum
Your problem sounds like drum rollers that are worn very badly.
If you have a front loading machine,
Remove the electrical box that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers to see if they are worn or the bearing area is worn or flat spots, if they are worn in the bearing area or have flat spots on them replace them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck,
I hope this helps
Oct 29, 2009 | Kenmore 62602 Electric Dryer
Trying to replace timer 8299771. Can't find my
On the new timer , you have 2 wires comming of the timer motor . The blue wire should go to one of these terminals on the timer itself . The place where there is ONLY a timer motor wire going to , is where it should go .
Sep 04, 2009 | Dryers
TIMER WIRE DIAGRAM
Just attach the green wire to any screw closeby. Nothing could be simpler. Look closely and you will find a small male terminal to connect the green wire in some models.
Feb 19, 2009 | GE DBL333EA Electric Dryer
Kenmore model number 110-66912692
It is fairly simple .The older style you yank the knob straight off and get the hex head screws out (2) The newer style you release a locking tab in the rear and twist the timer 1/4th a turn. So easy you won't believe it.
Jan 19, 2009 | Kenmore 62802 Electric Dryer
LEA30AW AMANA DRYER TIMER SWITCH CONNECTION PROBLEM..
I don't have a diagram but it is possible the the first letter of many of the colors is on the plastic around the screw connectors. Have a look. Good luck.
Dec 21, 2007 | Amana DLE330RAW Electric Dryer
Maytag MDE3706 Electric Dryer Logo
218 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
