Mould inside the rubber surround due to fabric softener build up. Unsure what to use to clean the rubber in case it effects it.
  • 188 Answers
You can use bleach and a rag or a soft bristle brush but once the mold has penetrated the rubber it's pretty hard to remove.
Posted on Mar 04, 2009
How to get rid of black mould?
Do a long hot wash, add bleach. Stop using fabric softener. If the rubber boot on the door (Front loaders) has been stained with black mould, you wont get the stains out. It will need a new gasket.
Mar 20, 2017 | Washing Machines
Fabric softener drawer water residue after washer completed cycle
This is probably due to a build up of residue of softener. Remove the drawer, strip the bits off, and clean with a toothbrush. Then replace, and this should solve the problem.
Apr 11, 2015 | Zanussi ZWF1430W Front Load Washer
It leaves holes and looks like black rubber on it
the black rubber is most likely fabric softener build up. The hose are the marks of the bowl perforations. Once this black 'stuff' builds up from the over use of fabric softener it could mean the end of the machine. The way to try and get rid of it is to wash an empty load in hot water with Epsom salts. This will loosen the black grease but be careful as some loads further on, large amounts could release and mark you clothes. If the bowls can be removed from the machine they could be scrubbed clean but this is a costly exercise. Tip from now on do not ever use fabric softener. end of story. Use low sudsing soap in your washer whether it be a top or front loader. www.thewashingmachineman.webs.com good luck
Feb 23, 2011 | Washing Machines
I have really bad smells coming from the filter part at the bottom when i take it out and their is oalot of water coming from the filter end
A few tablespoons of vinegar in the middle (fabric softener) compartment of the soaps drawer every few loads should help with any smells.
You could add some diluted bleach to the soap and fabric softener compartments and wash something you don't mind getting bleached. It should kill off any mould or mildew that may have build up in the nooks and crannies. Open the button trap door and clean it out as well (front lower right corner - says push and has a large screw plug inside. Close really tightly after or it will leak)
Nov 06, 2010 | Haier HWD1000
Stains on clothes after washing. Appears to possibly be oil residue. Is there a rubber seal or part that may be leaking inside the drum?
This could be a couple of things
1....oil from the transmission.
this is not common so lets leave this one
2.....the use of fabric softener causes greasy marks on clothing after a while
Fabric softener reacts with soap and can form a greasy jell. it can be yellow oily color or black.
You will know if you have been using fabric softener.
Stop using it straight away.
To clean oty the machine if it were mine I would put a packet of epson salts in with hot water and let the comp[lete cycly go.
Foe awhile use the machine with caution as this may release build up of grease which can stain further clothing until it is all gone.
The make and model of the washer is needed for an accurate diagnosis.
Aug 01, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Siemens XL 1400 washing machine and recently the fabric softener is not being taken from the drawer. I am unsure if this is because the fabric conditioner ( Comfort Concentrate Aloe Vera ) is too...
Siemens
WXLP1460 Front Load
Thisvideo will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question..
Mar 08, 2010 | Siemens WXLP1460 Front Load
My Ge Adora washer fabric softner dispenser
You have low water pressure which wont reach the dispenser drawer during rinse cycle. Clean the feed pipe in case there's dirt in the feed gauze located at the back of the machine. The mould on the rubber is dirt in the machinme. A mixture of 1 cap of bleach and 1 small tub of Swarfega mixed with water and put into the drum on an empty wash will stop it geting worse but it cant be removed.
Dec 09, 2009 | GE WSXH208A Front Load Washer
I have a dirty rubber inner Bosch Maxx 1200 Front Loading Washing
First clean around the rubber with some mould and mildew cleaner for bathrooms - available from most supermarkets.
This is a natural accumulation of waste detergent, fabric softener, fibres and dirt build up that is being attacked by bacteria and eventually decomposes into a sludge / goo and then eventually starts smelling bad as well.
To keep the machine clean of waste build up and to keep any bad odours away:
1. Remove all items from the washer.
2. Open the dispenser drawer and 2/3 cup (160 mL) of liquid chlorine bleach to the bleach compartment. DO NOT use more than 2/3 cup (160mL) of bleach per cycle as this will lead to product damage.
3. Close the washer door and dispenser drawer.
4. Select the Clean Washer cycle or a full wash cotton 104 F wash (40 C). DO NOT use any higher temperature as this will cause unnecessary fumes
5. Press Start and allow cycle to complete.
6. After the cycle is complete, leave the door open slightly to allow ventilation and drying of the washer interior.
7. Repeat the cleaning procedure monthly
Oct 02, 2009 | Bosch Washing Machines
Fabric softener dispenser
If you cannot get the dispenser cap opened, submerge and soak it in some hot water. Liquid fabric softener is a type of wax that, over a period of time, will harden and clog the dispenser (as you well know by now). In many cases you do not have to take it apart if you just use the hot water method. You may have to rinse and repeat several times. Try this and let me know if you have any luck. If you require further assistance, please post back with your complete model number, so I can see what type of dispenser cap we are talking about. I hope this helps you.
Aug 14, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
167 people viewed this question
Top Washing Machines Experts
