Question about Philips 42MF130A 42 in. Plasma EDTV
Magnavox 42MF130A/37, no picture
Unit turns on normally (power relays close). All votages off the PDC Board are normal for a few seconds. LED 8001, 8002 and 8003 all come on. A few seconds later, LED 8001 then 8002 goes out, power relays open and Red LED 8004 comes on steady.
  • P.S.S.Electronic Repair
    can you be more spacific on the location of the 3 legged transistors mounted on heat sinks here is what you said in you fix a while back the tv is a 42mf130a/37 "I'm not sure about the specific problem solution,but I can point you in a good direction, look for 3 legged transistors mounted on heat sinks,they are usually called output IC's or driver ic's. There are 2 in particular that control x and y axis visuals and if they read 0,then they are shorted and need to be replaced. if they are near a metal coil,then ignore the above statement. also,try unplugging the LVDS cable,it's a cable with many tiny wires that goes from the small signal (scaler to other manufacturers) board to the display panel,if it lights,its either the logic board or SSB.
IF your not getting sound and its shutting down it could be a the main board, or the power supply (huge board in there.) I just got done parting one of these tvs that was in a vacation rental. the tv met with an unfortunate accident so the screen was cracked and so on. Anyhow if your intrested i have the main board and the power supply board for that exact model. I was listing them on ebay and saw this post. Listing here. I am going to probaly get about 25 buck a board (very cheap) plus shipping. IF your intrested let me know and I list that power supply board as well. I can't guarentee it will fix it but its worth the shot for 50 plus shipping. form my experience with mostly LCD tvs if your not getting sound odds are its the main board. I also listed what was refered to as the signal scaler (logic board)
Posted on Sep 19, 2009
    Scholar:
  • 70 Answers
Posted on Jul 07, 2009
My Magnavox tv 42mf130a/37 went out will not come on
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Oct 25, 2016 | Philips 42MF130A 42 in. Plasma EDTV
Vizio intermittent backlight
You have to check the power supply of the tv. Normally led TVs power suppy is integrated with the led driver. If the led driver is faulty then this type of problems can occur.
If you wish to get some more details then check the following link.
http://electro-medical.blogspot.com/
Jul 21, 2016 | Vizio E601I-A3 60-inch Class Razor LED...
Tv has no picture but has sound
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Dec 01, 2015 | Televison & Video
My Panasonic split air conditioner has stopped cooling - model:CU-W18DKR. The internal unit and internal fan operate normally. The external unit fan does not run like normal and no compressor sounds f
Sounds like a faulty outdoor controller board. If you are in Australia, call Prime Electronics or Statewide Appliances for spares.
Part number: NPCWA743383
• To make a diagnosis
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
8. The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
Or better yet, get a tech to check first.
Feb 10, 2015 | Panasonic Single Split System - Wall...
Plasma screen does not come on and power supply board is bad
When the Plasma TV is plugged in, there're a fewindications of normal operation. Knowing this will help usunderstand what's going on with the unit when anabnormality occurs.1.There is a click from the relaysRL402andRL403when they are activated.2.The LED in the Optical Jack inside the DT board turns on for approx. 4seconds.3.Immediately after that, one of the Tuner LEDs (Right) turns on(Solid Red)for approximately 20 seconds.4.The LED in the Optical Jack inside the DT board turns on again for approx.1 second and both LEDs (tuner and optical jack) turn off.5.Then you will hear another click from the relaysRL402andRL403indicating that they are no-longer engaged. (Note: At this time the Tunerand the Optical Jack LED turn off.)5
Feb 06, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Hi, i have here a mitsubishi WD-57733. once the unit is switch ON, green LED light and a few seconds the status LED light then shuts off. I think light engines good since i just replaced a new lamp.
hello i've just checked the manual for here is some information
None TV is powered off. Normal operation.
Green TV is powered on. Normal operation.
Green 1. TV just plugged into AC outlet.
Wait until blinking stops before turning on (approximately 1
minute). Normal operation.
2. AC just restored after power failure.
3. TV Rebooting after System Reset was
used.
4. TV Rebooting after power fluctuation
or receiving abnormal digital signals
from digital channel, or digital device.
5. You have begun the procedure to
update software from an authorized
flash memory device.
For detailed information, see the instructions that accompany
the authorized software update. IMPORTANT: Do not
use unauthorized software at any time.
Green TV just powered off and lamp is
cooling.
Starts to blink 30 seconds after turning off TV. TV can be turned
on before blinking starts or after blinking stops, but not while the
indicator is blinking. Normal operation. hope it helps regards shaun
Green TV powered off and auto-on timer is set. Normal operation. TV can be turned on at any time.
Dec 06, 2010 | Mitsubishi Televison & Video
Philips 42MF130A 42 in. Plasma EDTV Logo
819 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
