Question about Canon PowerShot SD1100 IS Digital Camera
Can't download images from Canon SD1100 to computer
I installed the download softerware. The appropriate icons appear under programs, etc. However nothing happens when I connect the camera to the computer via the usb cable. I set the mode switch to playback and press the power button. After that nothing happens.
  • 1 more comment
  • mjlarkin Mar 05, 2009
    Thanks for answering. I though I had gotten an answer to you earlier this afternoon, It's twirling in space somewhere. I followed the directions and there was now apparent indication that anyting had happened. However, I actually did find the pictures in "My Pictures." So, it worked. I was expecting to see something.
    I appreciate your help. (I may be back!)
    MJ
    No problem at all! Hope this gets to you.
  • larry335 Apr 03, 2009
    just got the camera. Installed the software. Took pictures. Hooked up usb cable...my laptop says it does not recognize the camera....please help.
  • 423 Answers
Hi and welcome to FixYa.
Sounds like your reading right from the manual. <grin>
Try this.
Connect the camera to the computer via the usb cable. Set the mode switch to playback and press the power button, then:
on your pc go to Start>All Programs (or Programs)>Canon Utilities and find Canon Window. Double click on it and it should fire the program. Let me know if you have any problems. If not, feel free to rate my solution.
Rob
Posted on Mar 04, 2009
  • Rob
    Rob Mar 04, 2009
    You didn't leave me a comment. What happened when I advised you to click on the program from the start menu?
    Rob
  • Rob
    Rob Mar 05, 2009
    Hi MJ, If you won't mind, would you consider changing the rating to at least a "helpfull". Thanks I would appreciate it.
    Rob
Digital camera solution software download for sd1100 IS
You may download the software from here.
You don't need to use Canon's software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Nov 09, 2012 | Canon PowerShot SD1100 IS Digital Camera
How to download images from camer to computer?
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Canon ZoomBrowser or any other photo cataloging program.
Aug 14, 2011 | Canon PowerShot SD1100 IS Digital Camera
I am transferring images to my computer, which I have done before. Now I am getting the message "Save folder not found?" Have I moved it? Do I need to create it? How? Where? Please help....
My solution is to unistall your current canon software that holds 15 canon components in your computer. You will find them under system task and select remove programs. After you have uninstalled the program, reinstall your "Canon Digital Camera Disk" and follow their prompts. Now you should be able to transfer images again as per normal.
I have answered this question in detail under another question postered by "whitecar631" under canon "save folder not found" canon sd1100.
This worked for me, but I don"t know how to prevent it happening again. I do know the day I lost all "my pictures", I had previously deleted a large file in my documents. I also experienced "save folder not found" when I tried to transfer images from my canon ixus 100.
I was lucky enough that I had all of my original SD Flash Media Cards, so could transfer all my photos again. I have since put all my photos into labelled folders instead of dates and images.
Hope this helps, it appears to be a problem in the canon program. Joyce
Mar 02, 2011 | Canon PowerShot A470 Digital Camera
I dont have my install cd for my canon PowerShot SD1100 IS digital camera&gt; how can i get around this issue?
Consider NOT connecting the camera to the computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
You can download Canon software for your operating system from
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_sd_series/powershot_sd1100_is#DriversAndSoftware
Nov 02, 2010 | Canon PowerShot SD1100 IS Digital Camera
I lost the installation cd of my camera canon sd1100 and i need to install in my new computer
You don't need to install anything.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as Picasa.
Oct 11, 2010 | Canon PowerShot SD1100 IS Digital Camera
PowerShot SD1100 IS Digital Camera: sd1100 wont connect to mac...
Try NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
May 17, 2010 | Canon PowerShot SD1100 IS Digital Camera
Unable to upload pictures on to my computer
Solve your problem by using a card reader to download your pics to a folder you create on your desktop.
Apr 09, 2010 | Canon PowerShot SD1000 Digital Camera
Canon PowerShot SD1100 IS not being recognized by my computer
Consider NOT connecting your camera to your computer.
Oct 11, 2009 | Canon PowerShot SD1100 IS Digital Camera
I CANT DOWNLOAD THE PHOTOS ON MY PC!
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Jan 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Error 2738 when attempting to install HP F4180 printer software
Hi Stargateforg,
Try the solution from HP.
Solution one: Restart the computer
  1. Turn off the product.
  2. Restart the computer.
  3. Turn on the product.
  4. Use the HP software CD or the downloaded software file to install the HP Software.
Solution two: Register VBSCRIPT.DLL
  1. Search for the VBSCRIPT.DLL file on the computer. It is usually located in the C:\Windows\System32 folder.
  2. Click the Start icon (c01319360.gif ) , click All Programs , and then click Accessories .
  3. Right-click Command Prompt , then click Run as Administrator .
  4. In the command prompt, type CD C:\WINDOWS\SYSTEM32 . If the VBSCRIPT.DLL file is located in a different folder, use the appropriate folder location.
  5. Press the Enter key.
  6. Click Continue in the window that appears on the computer.
  7. Type REGSVR32 VBSCRIPT.DLL in the command prompt and press Enter . A message appears on the computer indicating that VBSCRIPT has been installed successfully.
  8. Use the HP software CD or the downloaded software file to install the HP Software.
Solution three: Download and install the latest version of the software
  1. Click here to go to the software download page on the HP Web site.
  2. Type the product model name in the text box and click the gray arrow button.
  3. Select the appropriate product model from the list that appears on the computer, then select the appropriate operating system from the list that appears on the computer.
  4. Under the Drivers section, click Full Feature Software and Drivers .
  5. Follow the on-screen instructions to download and install the HP software.
Solution four: Custom Install Use Custom Install to install the basic print drivers only.
  1. Use the HP software CD or the downloaded software file to start installing the HP Software.
  2. When prompted, click Custom Install .
  3. Clear all the entries in the list of software to install except Photosmart Officejet and Deskjet Drivers and Imaging Device Functions . Click Next to continue.
  4. Follow the on-screen instructions to install the basic print drivers.
Dec 22, 2008 | HP Office Equipment & Supplies
Canon PowerShot SD1100 IS Digital Camera Logo
493 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
