Question about Maytag Dryers
The LSE7806ACE is stacked in a very tight enclose.
The Maytag Stackable Washer/Dryer (LSE7806ACE) is stacked in a very tight enclose. It exhausts to the rea and to a roof vent. Apart from taking the unit apart, or going up on the roof is there any easy way to clean out?
  • 686 Answers
Not really
Posted on Mar 04, 2009
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Top Load Stacked Washer / Dryer Maytag lse7806ace -- washer will not run, except in spin cycle
I believe there is a fuse on the left side front under the front panel about a foot from the top of the washer.
Nov 20, 2010 | Maytag LSE7806A Top Load Stacked...
Washer won't drain or spin
YOU MIGHT BROKE THE DOOR SWITCH CHEC IT OUT FIRST... IT CAN BE BYPASS IF YOU WANT :) LET ME KNOW
Feb 21, 2010 | Maytag LSE7806A Top Load Stacked...
Matag stackable My Drier Squeals loud on start up
could be motor put oil on back baring aka rollers
Jan 29, 2009 | Maytag LSE7806A Top Load Stacked...
Washer won't agitate, drain or spin
quite possible that the fuse has gone bad again, if that s the case i would recommend replacing the fuse, and the lid switch.
Dec 08, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag stackable LSE7806ACE - dryer wont run...washer is fine..
I had the same problem, take the easy rout first and check for obstructions in your venting. Mine was clogged and it shut itself down (to protect itself?)
Jul 06, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Dryer makes a loud noise then stops
If it stops running when hot it may be the motor. The belt or drum rollers would not stop it from running.
Dec 23, 2007 | Maytag LSE7806A Top Load Stacked...
LSE7806ACE lint build up
Are you able to physically pull a section out in front of the filter? Or the filter itself? It may be held in by snap in style clamps?
Jan 03, 2007 | Maytag LSE7806A Top Load Stacked...
Dryers Logo
153 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
