Question about HP Color LaserJet 2600n Printer
57 Fan Error HP2600n How do I repair that?
I replaced the color toners and now get a message of "57 Fan error turn Off and turn On". I did that and the message stays. I see a small fan in the lower right. I turned it "gently" with a small screwdriver. I restarted the 2600 and it printed one page and stopped displaying the same 57 Fen error message. What's next?
  • Thomas F. Schneider May 11, 2010
    Did the fan stay running? If not replace the fan.
  • 98 Answers
SOURCE: pen failure message from utility
HP tech support suggests cleaning the ink cartridge contacts and the contacts inside the printer for the cartridges. If this does not clear the problem, try replacing both cartridges (color and b/w) with new ones.
Posted on Jul 27, 2007
  • 4 Answers
SOURCE: Printer HP ColorLaserJet displays Fuser Error
Try to check resistant in Fuser unit See more HERE
Posted on Jan 05, 2008
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
Posted on Oct 18, 2008
  • 58 Answers
SOURCE: printer displaying 49.2F80 error message
Author Subject: 49.2F80 SERVICE ERROR favorites_add.gif vanessa spinelli
Feb 14, 2008 00:50:36 GMT Hi,
I have an HP 2420d printer, and I keep getting the following error message:
How can I fix this? It usually goes away when I turn it off and back on, but it's annoying to have to do it so often.
Any suggestions?
Note: If you are the author of this question and wish to assign points to any of the answers, please login first.For more information on assigning points ,click here
Sort Answers By: Date or Points
Robert M. Stewart expert_small.gif Feb 15, 2008 22:36:20 GMT Unassigned 49 errors are the formatter. Network card? Swap it. Any extra memory recently? Remove it. razmat lighthouse.gif Feb 16, 2008 15:23:50 GMT Unassigned you could try to unplug from everything and just have it plugged by itself into the wall and maybe print some test pages to see if the error comes up at any of those points.then hook up via parallel and try to send some print jobs ,then hook via USB and send some print jobs and see if the error comes up at any of those points.this can can help narrow things down and point to the network or elsewhere.
like the previous poster said,sometimes something on the formatter can cause this issue,like a hard disk or network card,where removing these ,at least temporariliy to test can help.
if you have the internal network port(usually on the "n" model),then try a cold reset.if you have a hard disk you can also use a skip disk load option by holding the down arrow while powering on until all led's come on ,then use the arrows to scroll to "skip disk load".cold reset is similiar except,hold down the select(checkmark) button while powering on until all led's come on and the language option pops up on the display.then scroll to cold reset.
Posted on Dec 31, 2008
  • 114 Answers
SOURCE: printer won't print error message remove and check right cartridg
Take out the power cable from the back of the printer keep on tapping the power button for 30 secs ; then plug it back.
Take out the catridges clean them with a Lint free cloth (copper contacts); also clean the catridge slot of the printer; put in back the catridges ;
Unplug the power cable from the back of the printer; press and hol down the (#) and the (6) button simultaneously with one hand and with the other hand put in back the power cable; and then release the (#) and (6) button;
It will perform a reset on the printer
IF still then it doesn't work then the catridge slot's copper contacts has gone bad and need to replace
Posted on Sep 16, 2009
How do I fix the error 57 fan error in a HP LaserJet Pro 200 color Printer M251nw
Turn the product power off, wait at least 30 seconds, and then turn the product power on and wait for
it to initialize.
If you are using a surge protector, remove it. Plug the product directly into the wall socket. Turn the
product power on
Replace the fan
if mot fixed
Replace the board
Aug 28, 2017 | HP Office Equipment & Supplies
59.9 Error turn off then on
1. Turn the printer off, and then turn the printer on.
2. Check and reseat the fuser and toner cartridge to make sure they are not hindering gear movement in the drive train.
3. Check the main motor's cable to ensure that it is seated properly.
4. Replace the main motor.
More Info... Hp Error Code 59 Service Repair Errors 59 Fix Codes Message And...HP Printer Support
Jul 10, 2014 | HP LaserJet Pro 100 color MFP M175nw -...
Unit switches off and displays error code 02-57
According to:
From the manual
02-57 Fan lock
This code is output when fan locking (over 30 seconds) is detected.
After the error message is displayed, the power turns off.
Perhaps opening the unit with the power unplugged (of course!) and clearing/cleaning the fan would help. It may be that the fan is just clogged with dust/debris.
Nov 29, 2013 | Televison & Video
Toshiba dvd recorder error code
According to:
From the manual
02-57 Fan lock
I get an HP error message on 2600n printer saying "57 Fan Error". Is it fixable?
57 Fan Error
Turn off then on
The device has experienced a problem with its internal fan.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.The fan is not replaceable. Replace the engine.
Jul 11, 2011 | HP Color LaserJet 2600n Printer
57 service error message. Wht does that mean? We
A fan failure was detected.Printer fan or Duplex fan.
1. Check the fan’s connector and make sure the fan is not blocked.
2. Replace the fan.
On older style printers this is often caused by a bad main motor. (Older style printer being printers with halogen heating elements in the fuser - 4, 4+, 5, 4si, 5si, etc).
Oct 19, 2009 | HP LaserJet 4 plus Printer
57.03 error
57.x FAN FAILURE CALL SERVICE Control Panel Message 57.x FAN FAILURE CALL SERVICE Event Log Error Service Messages: 57.01.00 57.02.00 57.03.00 57.04.00 Required Action
  1. A fan motor failure occurred. All fans are enabled to low speed operation at printer power-on. Fans will go into high-speed operation during the print cycle. All fans are disabled during PowerSave Mode.
    • x = 1: FM1 (Laser/Scanner Fan)
    • x = 2: FM2 (Power Supply Cooling Fan)
    • x = 3: FM3 (Formatter Fan)
    • x = 4: FM4 (Face Down Deliver Fan)
  2. Cycle power. It the message continues, check and reseat cabling between the fan motor(s) and the DC Controller PCA.
    • Fan 1 J208
    • Fan 2 J216
    • Fan 3 J210
    • Fan 4 J225
  3. Replace the faulty fan motor.
Aug 20, 2009 | HP Media Center m7250n (ED842AA) PC...
Merroy error 100.10.10
There isn't a known error of 100.10.10 on an HP2600n. The is an extremely rare 101.000 which is color plane registration but I'm guessing your not getting that.
I'm assuming your actually having one of the following:
10.0000, 10.0001, 10.0002, or 10.0003
10.1000, 10.1001, 10.1002, or 10.1003
These are supply errors (toner cartridge). The toner cartridges have a smart chip on them and if it's not reading correctly you can get one of the errors I mentioned above in the "10" errors. In that case look at the last number in the string to isolate it. "0"=Black, "1"'Cyan, "2" =Magenta, "3" = Yellow. Simply replace the identified cartridge.
We have seen a lot of refilled or self refilled cartridges that the supplier or user didn't put a new smart replacement chip on the cartridge, pulled the chip without replacing or actually put the wrong one on the cartridge. This would cause the "10" errors. In some rare cases a surge in power can knock out a chip on the cartridge.
Here's a photo of the chip on the black cartridge to help you locate it.
If you are getting a "10" error identify the last number to identify the color and replace the cartridge.
If you are ACTUALLY GETTING AN ERROR 100.10.10, contact HP as it is an undocumented error and likely only HP may be able to resolve it. I have even researched the error through Canon (they make they base machine for HP) and Canon has no record of this error either.
I hope this helps you. If so hit it with a FIXYA. Thanks.
Aug 28, 2008 | HP Color LaserJet 2600n Printer
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
HP Color LaserJet 2600n Printer Logo
523 people viewed this question
Ben Johnson
