Question about Pioneer VSX-D811S Receiver
I have a Pioneer VSX-4900S that when first turned on (cold) the right channel doesn't work unless I turn the volume up loud or let it warm up and roll the volume knob up and down. From then on it works fine till I turn it off then the problem reoccurs the next time I turn it on.
    Scholar:
  • 56 Answers
Hmmm, that almost sounds like a bad solder. As things heat up, they expand. When there is a bad solder (even if you can't see it) as the unit heats up and the pieces expand, the contacts at the solder point will meet and allow the circuit to complete, thus producing sound through the right channel.
Take a large magnifying glass, and with it, examine the bottom side of each of the circuit boards, looking for a solder point that is not well formed.
Posted on Mar 04, 2009
VSX-1122 Pioneer Receiver keeps turning off randomly
Sounds like one or more of your speakers are bad.
Jun 04, 2013 | Audio Players & Recorders
My pioneer pl-200 doesn't play loud enough through my pioneer vsx-521-k receiver
The PL-200 has no pre amp and your VSX-521 has no phono input. You need an RIAA preamp.
Jul 11, 2017 | Pioneer Vsx-521-k 5.1 Channel A/v Home...
I am in need of the codes to program my EPB fiber optic tv remote to control my Pioneer vsx-4900s. Can you help me?
my epb fiber optics remote wont program my ilo tv set, the installers were able to make it work, the remote had to be replaced and i cant program it
Apr 24, 2011 | Pioneer Audio Players & Recorders
My pioneer VSX-1016 shuts itself off during loud portions of a movie. I have checked the speaker wiring and have clean connections. Any other ideas?
Yes, evaluate the load presented to its amplifiers by the speakers. If you have any speakers running parallel on the amps instead of one per amp channel you could be experiencing temporary unacceptable drops in impedance.
and
From page 57 in the manual...
• Turn down the volume.
• Lower the 40 Hz and 125 Hz equalizer levels in the Manual MCACC setup on page 34.
• Try switching on the digital safety feature (put the receiver into standby, hold down the SYSTEM SETUP button on the front panel and press STANDBY/ON to switch between SAFETY ON and SAFETY OFF
. If the power switches off even with SAFETY ON selected, turn down the volume.
Dec 29, 2010 | Pioneer VSX-1016 Receiver
Have a pioneer VSX-D603S and just added bose 100 watt speakers. As i turn up the volume the speakers keep cutting out. Not very loud before it cuts out. What can I do?
What model of Bose, how connected on what channels? Do you know the impedance? If they came from one of their all-in-one systems you're playing with fire (almost literally) mixing them with non-Bose amplifiers.
Feb 04, 2010 | Pioneer VSX-D903S Receiver
I have a VSX D710S and it flashes poweroff then
Im having this same problem. It happened after I had the music up really loud for about 3 hours. Also, where it has the volume all i see is -- instead of a number when i try to turn it on
Nov 29, 2009 | Pioneer VSX-D906S Receiver
Volume problem with VSX-D409
Had the same problem. I had to replace the volume contol. It was inside the receiver behind the knob. It has a part# on it. Mine was part# AWX7386 (control assembly) from Pioneer.com. If you can figure out how to open the case than you can change this piece. Good luck
Dec 23, 2008 | Pioneer VSX-D409
Pioneer VSX-4900S Receiver Connections
I know this is an old post but run front speaker outputs to the inputs on the sub then from the sub to the front speakers. bam!! it should work
Jan 23, 2008 | Audio Players & Recorders
VSX-D512
The best way to do this (if you haven't done this already) is to enable the Dynamic Range Control. This neat little setting makes the difference between loud and soft to be not so much, making soft sounds (like talking in your case) louder and something like explosions not so loud. This is also called Midnight Mode on some receivers. To enable this setting, grab your remote and turn the receiver on. Press the "Receiver" button, then hit the left arrow on the remote until you see something along the lines of "Dynamic range control" pop up on the LCD (should be the 8th setting). You probably want to set this to "Max", but you can also select "Mid" if you find that Max does too much.
If this still does not work, you can bump up the relative volume of the center channel a bit (or a lot of bit). Hit the "Standard" button on your remote, then "Test Tone" until "C" or "Center" comes up on the LCD. Then hit the "Level +" button a few times, making the center channel a little louder. Listen to it a while and adjust it to your liking.
The combination of these two settings should get you where you want to be. By the way, do a search on your favorite search engine for something like "manual Pioneer VSX-D512" and you should be able to download a manual from somewhere (it looks like Pioneer no longer hosts the manual on their site). Hope this helps!
Dec 19, 2007 | Pioneer VSX-D511 Receiver
Pioneer VSX-D811S Receiver Logo
334 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
