Question about Samsung L200 Digital Camera
My samsung l200 wont turn on
Well my camera is brand new it worked the first few days then we put it to charge then wen i try to turn it on the little green power button flashes for a second then goes off but the blue button stays on and wont turn off i have to take the batery out and the screen wont show up
HELP HELP HELP!!!
  • Mo3kiki May 21, 2009
    Yoo i have the Same problem Like i had mines for 8 months and im trying to turn it on it the blue an green light keeps blinking when i hold it down it wont turn on at all ;__; im very mad
SOURCE: Camera Wont Turn on
Is there anything that sounds like a "beeping" noise when it extends? A lot of times the focus motor gears are knocked out of place. This causes a lens error, even if the lens extends fine. The camera has the "external" zoom lens, and an internal focus lens. This can be only fixed with disassembly of the lens, if indeed this is the problem you're talking about.
Posted on Oct 30, 2007
SOURCE: Samsung camera not turning on.
First make sure you batteries are strong.
Then this is not a great solution, but try this. 1) Remove the battery. 2) Hold down the power button and wait 30 seconds...but keep holding the button. 3) After 30 seconds and while holding the button down insert the batteries and then close the compartment. It should come on.
I managed to duplicate the problem by opening the battery compartment with the camera turn on and then if I put them back it would turn on and the lense does not retract.
Good Luck
Posted on Dec 29, 2007
SOURCE: samsung L730 won't come on...
how about give us our money back!
Posted on Jan 09, 2009
  • 26 Answers
SOURCE: charging battery samsung l200
it should be off...and if this will be the first time you're going to charge it, you should charge it for 8 hours straight
Posted on Feb 16, 2009
  • 148 Answers
SOURCE: samsung L100 wont turn on
Samsung's have notorious problems with their lens-cap shutters malfunctioning. This seems to be the case with yours. It will have to be serviced, I'm afraid.
Posted on Apr 02, 2009
LCD problem with Sony DCR-SR200
O& ..)& '''ho 7... 007 I see his movies are old and so is your battery. Break down and buy a new and charge it to full capacity replace the battery
Buy the heavy duty isf there is. and when you store it when not in use ut the battery in the freezer. When you want it thaw it out and put a charge to it for a good practice and install
Jul 27, 2009 | Sony Handycam DCR-SR200 Camcorder
Problems with my samsung L200 digital camera
How old are the batteries? They could be toast, so check with new ones...can you power it with an AC adapter to make sure the camera works? If not check the manuel for any settings you could have actuated like a timer or sleep mode.
Check what "mode" its in...some cameras can be switched to different modes that will affect functions...including taking pictures.
Has it gone from cold to hot temp or vice versa in this time period? If so...it could have condensation inside and shut down for self protection...open whatever can be opened on the camera and let it sit indoors at room temp for a few hours.
If none of that works....take it back to where you bought it if possible and talk to the manager.
Apr 16, 2009 | Samsung L200 Digital Camera
USB Cord
try changing the USB cord to avoid purchasing one, bring your camera to your retailer and ask them if you can try to charge it there, if it does you have to purchase a new USB cable through myaccessorymall.com if the camera is still in warranty, you can try to call samsung and ask them for a new USB cable
Mar 19, 2009 | Samsung L200 Digital Camera
Charging battery samsung l200
Feb 15, 2009 | Samsung L200 Digital Camera
'File error' message on samsung L200 camera when viewing a photo
Possible solution:
I had/have the same problem using L200 and SDHC memory card, called Samsung. Can't view certain pictures on camera or computer, camera freezes when viewing those certain pictures, green light flashing.
Samsung support told me that I needed to copy my (good) pictures to a computer first because a memory format will erase everything. Then format (menu->settings->format->yes) my memory card. Tried this just now and took some new pictures, so far so good.
Jan 15, 2009 | Samsung L200 Digital Camera
Samsung L200 10.2
I called 1-800-samsung, and they sent me a new battery. After the problem insisted, they asked me to ship the camera back to them (still under warranty). The concluded that the cable was defective, and they shipped me a new one within 1 week. That was fast!!!
Aug 20, 2008 | Samsung L200 Digital Camera
I have a Samsung P800 camera. I'm currently trying to charge it but the light on the charger chord is flashing orange and it doesn't seem to be charging. Please help.
Ok. I have the samsung l200 but the cameras are very similar. I had the issue as well. When I plug it in it flashes red once, green once, then orange consistently. It would not charge the battery.
The fix was really quite unexpected. I did two things not sure which fixed it.
1. slide the cable into the camera slowly until the light turned red once, then pulled it gently in and out a few times.
2. as i plugged it in, I tried to angle the plug side to side sliding it to the left and right on a diagonal. I was hoping the pins would be touched differently when I did this which might reset something.
not sure which of these two things corrected the problem, but the camera is now charging.
Aug 12, 2008 | Samsung L200 Digital Camera
Samsung L200 Digital Camera Logo
332 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
