Question about Acer Audio Players & Recorders
Itouch will not respond
Well, I got water on my Itouch (8g) about a week ago. When you look inside where the headphone jack goes it is pink not white so apparently it has some slight water damage. Apple will not replace. I have plugged it into the ipod charger that can be plugged into the wall hopping that it will heat up and dry the excess water up. I finally got the image on the screen that shows the (when its charging) battery charging and says slide to unlock. I try to slide the little bar but my Itouch is not responding to me. HELP!
Get over it.
Posted on Mar 11, 2009
Speakers not working
Try restoring the ipod or cleaning the ipod jack first. Usually it is caused by the dirt accumulated inside the jack. The ipod thinks there is a headphone inserted even when there is none.
Feb 19, 2014 | Apple iPod Touch 8GB 32GB 64GB 3rd...
On deaf ear
sounds like headphone jack is either dirty or loose in the unit or a possible blown fuse.
if still under warrenty I would get it serviced if not then if you feel comfortable opening it up and looking around the inside of the unit around the sounds output jack then you can try that and see if you can find any blown or burnt problems around there loose connections.
Aug 13, 2008 | Apple iPod touch
How can I connect my itouch to my pioneer VSX-52TX receiver
You can use the RCA jack and an RCA cable to your aux in on your receiver.
Oct 16, 2013 | Pioneer Audio Players & Recorders
Itouch player not responding
Have you tried resetting the iTouch? How to reset Apple iTouch Apple also has an Express Lane Support with more help options for your device; just enter your serial number. Express Lane Apple Support You might have to backup you iTouch Music in iTunes and reset your device to factory settings. But first try the soft and hard reset before restoring the iTouch to factory. More reset resources And furthermore: Apple's instruction site for restoring the iTouch
Nov 15, 2011 | Apple iPod touch
They work on my itouch but not on my computer
if the jack on the headphone fits firmly in the audio jack it should work unless you have 2.5mm headphones with a 3.5mm jack on the computer which would make you have to buy a new jack. Also try updating the sound driver on your computer.
Apr 25, 2010 | Computers & Internet
I cant get any sound when i plug in the 8GB iTouch
Chances are it's the docking module... try pulling the ipod forward and see if you get some sound.
One can slip something in behind the ipod to prop it so it will give sound sometimes but overtime the problem gets worse in my experience.
There's the Auxillary input as well in the back... i.e. running an adapter from the headphone jack to the back. For an Ipod Classic one can leave it in the docking station re-charging - for the nano, with the headphone jack on the bottom it can't be placed in the docking station (though can be - recharged when not plugged in)
Don't forget to switch the selection to Auxiliary rather than Ipod
That being said, in terms of sound quality, the quality is much better (highs are higher) when plugged into the docking station compared to the Auxiliary input
Oct 22, 2009 | Altec Lansing Inmotion-IM600...
My apple itouch had water fall on it the other day, and I quickly took a blow drier to it. It won't work though. Does apple have water sensors in the iTouch to know if I take it in and say its not wor
well de iTouch doesnt have nything like that..as I too have one..and I dont think they ll suspect you..I think they ll replace it for you..all the best..ok
May 25, 2009 | Apple iPod touch
ITouch 2nd g only plays music throuhg left side of all headphones
Try playing with the headphone plug, until you can also hear the right
channel and also try a different set of headphones as it is probably a
matter of an intermittent headphone jack, or plug, owing to sudden
snatching of the headphone plug from same, a very common problem.
Eliminate this cause before submitting your Touch for much more
expensive remedies
Apr 16, 2009 | Apple iPod touch
Jack on headphones broke off in my iTouch
You might be able to get it looked at under warranty if it's less than a year old.
Otherwise, have a look at this:http://www.ifixit.com/Guide/First-Look/iPod/iPod-Touch You'll need some tools to do it, but they can be bought from the iFixIt site.
If it's jammed in there really badly you might need to replace the headphone jack itself, which may be part of the logic board. Could be a pretty expensive repair job if you choose to DIY. I'd definitely see if Apple will fix it either under warranty or for a fee. Much easier.
Anyway, iFixIt has all the parts for the iPod Touch here: http://www.ifixit.com/Products/Touch-1st-Gen/132
Dec 08, 2008 | Apple iPod touch
Itouch
Just restore ur ipod it should still work, but restore it to factory settings not a backup
Oct 18, 2008 | Apple iPod touch
203 people viewed this question
Top Acer Audio Players & Recorders Experts
NOEL
NOEL
Are you an Acer Audio Player and Recorder Expert? Answer questions, earn points and help others
