Question about DEI Python 1400XP Remote Start/Keyless Entry System
Newly installed 1400xp remotes do not work
The doors look when started they unlock when turned off and if I push the start button twice it starts but none of it works with the remotes. I call tech support and got yelled at for installing myself, I did not know I was not supposed to. Any help would be fantastic.
  • 2 more comments
  • krm7988 Mar 05, 2009
    yup everything works except the remotes. I have been told to find someone with bitwriter and they could fix it. Does that sound right?
    The remotes do not work at all with the system and I can not seem to program them either. I was told it maybe locked and you need bitwriter to unlock it? Maybe it is just a bad unit it was a circuit city out of business open box buy.
  • Dallas Konecny May 11, 2010
    Ya they tend to be you know whats if your'e not a "qualified installer" but I do see there reason as someone can really do some damage in some vehicles. Sorry now i got your message but not understanding the "bitwriter" part.
    So the remotes do not work? Sorry just need clarification as to your problem.
  • 43 Answers
I don't know where you live but i would recommend that you either go to best buy or a dealer that sells and install viper alarms and purchase a remote they should have a bitwriter to unlock the remote start brain if indeed it is locked.
Posted on Mar 29, 2009
An 08 prius keyless entry doesn't work, changed the batteries, pushed the disable button and reset it, still no go. Any ideas?
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition and Pull key out twice (Do NOT Turn)
3. Perform these steps within 40 seconds.
A. Close then open the drivers door twice.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
B. Insert the key into ignition and leave it in ignition.
C. Close the drivers door.
D. Turn the ignition to ON (Do NOT Start) then back to OFF.
E. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Jul 17, 2014 | 2008 Toyota Prius
Have no idea what this is
Depending on the "brain box" used, this fob can lock/unlock doors, unlock trunk, and remotely start the car. the * button is used for the remote start....OR can be used to arm/disarm a security system. Only way to tell is to try the buttons and see.
Also, some are wired so that first you must hit the door lock button, then the remote start * button. Also may need to push * button twice to get the remote start to engage.
Somewhere - likely under the dash near steering column or ignition switch is the brain box. Give us the model numbers off that box and I can tell you a lot more about what it does.
Dec 13, 2013 | 473L TX 3-Button Replacement TX Remote
On the remote I will push the unlock button, then the car's horn honks and unlocks the doors. It also honks when I want to lock it. I am only pushing the lock or unlock button once. I'm not in the...
You can disable the chirp confirmation by using the following procedure
1. Turn the ignition on
2. Turn the ignition off
3. Press the valet switch 5 times, wait for the Status Light to flash twice, the parking lights to flash twice and the horn to chirp twice.
4. Press the valet switch 4 times, the MARS unit will respond with 4 Status Light flashes and horn chirps
5. Press the transmitter START button, the MARS unit will respond with 3 Status Light flashes and horn chirps
6. Turn thr ignition on to exit program mode
May 08, 2011 | Omega MARS-22 Remote Vehicle Starter with...
Remote car starter worked last week but this week it won't start. Changed battery in the remote and still won't start. It will unlock and lock the doors but just won't start.
It probably needs to be re-programed
I have a viper model 5101 and this is how you program it Hope it helps !
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in IGN to the on position but don
Jan 05, 2011 | Remote Start System
Remote control has stopped working. Have tried changing the battery of the remote control but that did not work.
Does the red light on the remote light up when you push any of the button
if no, replace remote
if yes, then try repograming the remote to the car again.
-Have remotes' ready. if you have two then fob#1 and fob#2 (doesn't matter which one is #1 or #2)
-each step has to be done within 5 sec or it will not work, but don't do it super fast.
1.turn key just to the "on" position (not starting) and push "lock button " on fob#1 once and release
2.turn key off
3.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
4.turn key off
5.turn key just to the "on" position (not starting)and push "lock button " on fob#1 once and release
6turn key off
7.turn key just to the "on" position (not starting) and push "lock button " on fob#1 twice (if you only have one fob, then stop here and go to step 8)and push the "lock button" on fob#2 twice.
8.turn key off and remove key from ignition.
if you did it right, remotes' should work again.
good luck
Dec 17, 2010 | 2003 Honda Accord
Remote auto start will not start a 2007 chevy suburban ltz
If the keyless remote works to unlock and lock the doors, then it should start the engine. In order to use this feature, you have to lock the doors (make sure that all door lock by pushing the lock button twice) with the remote by pushing the lock button, then you hold down the start button on the remote for 2 to 3 seconds and it should start. You can start and stop the engine with the remote 2 or 3 times with the remote, after that it will no longer let you use the remote start until you physically get in the car and start the engine to reset the system. Check your driver information center options using the steering wheel controls. There is an option to enable and disable the remote start option.
May 10, 2010 | Cars & Trucks
Keyless entry not working
Remote control added or replaced. System malfunction.
Obtain all remote controls. Remove key from ignition switch. Close all doors. Open driver's door. Carry out the following within 24 seconds: Turn ignition switch ON and back to LOCK position 3 times. Remove key. Press and release driver's door courtesy light switch 3 times. Ensure doors lock and unlock. If not, wait 40 seconds and repeat procedure starting with driver's door already open. Press each remote control lock or unlock button twice. Ensure doors lock and unlock after each remote control operation. If not, proceed as follows: Press and release driver's door courtesy light switch once. Ensure doors lock and unlock twice. Repeat procedure starting with driver's door already open.
NOTE: A maximum of 3 remote controls can be programmed.
Mar 29, 2010 | 2004 Mazda 6
My alarm wont turn off. my car wont start. its a 2004 tiburon.
With alarm activated your ignition is disabled.Find the combination to disable it.With GM's you hold opposing buttons on the fob till it beeps twice. The dealer should help for no charge.
Feb 28, 2010 | 2004 Hyundai Tiburon
I can't disable my anti theft device on my chevy malibu 2004 and my car will not start
This usually works.Lock the doors with the remote.Press lock twice sounding the alarm.Then press the unlock button twice.Your car should start now.If that doesnt work try this,Lock the car again with the remote once.Go over to the passenger side door and use the key to unlock the door then press in the door unlock all doors.Hopefully by now it worked.Now if none of these work your security probably malfunctioned and theres only two things that will work,One is disconnecting the battery for 5 mins then reconnecting.unlock doors.the start.If that doesnt work you'll have to take it to the dealer to get the security reset or replaced.The steps I have wrot you are the diagnostics to reset it.I hope these work for you and good luck.See ya had have a great day..
Mar 31, 2009 | 2004 Chevrolet Malibu
DEI Python 1400XP Remote Start/Keyless Entry System Logo
229 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
