Question about Dishwashers
Maytag MDBTT79AWW dishwasher fills and nothing else. Once filled you hear a click, followed by a humming sound for 3-5 seconds, then silence. This will happen two or three more times, and then unit will shut off. Motor doesn't start. Repairman says he thinks control board is bad, but he sounds like he is guessing. I performed a field service test , which indicated a fault in the high current motor circuit. Unit is seven years old. Don't know whether to attempt repair, or replace.
  • 318 Answers
That sounds like the motor trying to start but being jammed it is shutting off via an internal breaker. Check for something in the bootom of dishwasher that might have gotten down there that could do this. You might have to take the sprayer off and some things below that.
Posted on Mar 07, 2009
Washer will fill with water but will do nothing else
Hello & Welcome to FixYa
When the dishwasher fills then it means that the control and the water inlet valve are fine, try to hear a different sound like a hum/buzz/click sound. If it is like a hum sound from the bottom panel then it indicates that the motor is bad and needs replacement and if the hum/click comes from the control then it is the timer that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
Dec 13, 2010 | Magic Chef Dishwashers
Problem with candy dishwasher model CSF 456M.
hi it may need a new inlet valve,can you hear a humming sound when its due to fill.or is it doing nothing.if its not humming change the valve,also these dishwashers are well known for overheating and sticking on cycle.
Jun 01, 2010 | Dishwashers
I have a Maytag MDB4651AWW3 dishwasher that stops during cycle
is it making a humming sound ,then the pump is blocked see if any thing is stuck under spray arm, worst could be is the motor unplug before working on it. thanks
Dec 01, 2009 | Maytag 24 in. MDBH950AWS Built-in...
I have a maytag washer (model -dependable care) and when we start the wash the motor just hums, the water does not fill, if we move the timer switch to rinse the motor engages and the unit works entire the...
Check your fill tubes remove the hoses and see if the filters are plugged, you are not hearing the motor humming. You are hearing the watervalve humming, the motor will not start until the tube is full of water.
Jul 16, 2009 | Maytag MDB6650A Built-in Dishwasher
Dishwasher fills up and then stops
the cycle for all dishwashers is 1/pump out for approx ! minute 2/ fill. 3/circulation motor, so the problem is the motor is jammed(can you hear a humming sound? or the motor is faulty and will require replacing
Jul 08, 2009 | Dishwashers
No water running through cycle once filled....making humming noise once clicks into cycle
pump should be checked for restriction of movement,is there something blocking it?does the capacitor smell?if it does its blown(or meter check-more accurate),hope this helps
May 27, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
My carlton dishwasher fill and drains but does not wash
sounds as though the wash motor/pump is jammed or has seized therefore no wash.
Mar 16, 2009 | Maytag 24 in. MDBH965AW Built-in...
Fills with water, sounds like it starts to pump water then stops, then start again. It attempts to start pumping water 3 or 4 times them turns off leaving the water in the tub. I have read about the water...
you have a wash pump problem. can be 1 of 3 things. most likely something is caught in the pump impelor if not the wash pump motor may be faulty or ceized or it could be the capacitor for the wash pump motor is faulty. you can try removing the wash pump yourself and check the impelor if it spins freely then you will have a motor problem.
hope this helped
Feb 18, 2008 | Maytag MDB7100AWB Dishwasher
Dishwasher not working
Nothing by the sound of it. The humming may mean the main pump is stuck. If you are able, remove the pump & turn the impellor by hand (or screwdriver) just to make sure its free moving. Put it back into machine & see what you get. Could also mean that the capacitor on the main pump (if it is a capacitor start motor) has failed.
Jul 19, 2007 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
330 people viewed this question
Top Dishwashers Experts
