Question about Gateway MT3422 RTL Notebook
Model mt3422 laptop overheats,and shuts down
When i use the laptop for videodisc burning ,the unit shuts down.i have tried cooling pads, and keeeping unit elevated, to no avail
  • 1 more comment
  • BJ1957 May 11, 2010
    Does this happen for DVDs only, or for CDs, too?
  • Thomas F. Schneider May 11, 2010
    I don;t think any Note book computers really do well,buring  w/o overheating?
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    Make sure where your cpu fan is in the laptop that it has not dust or dirt built up otherwise that will cause your laptop to shut down regardless of any cooling pads cause the CPU will overheat.
    Find the vents where the cpu fan would be blowing out the hot air.
    Problem Solver:
  • 8 Answers
Use an external usb burner
Posted on Mar 10, 2009
Gateway mt3422 black screen
GPU needs to be re-balled. It is because cooling pad on GPU is not efficient and GPU overheats, melting ball contacts. There are some re-balling services on ebay that will reball GPU and install a more efficient cooling contact on the GPU.
Feb 16, 2014 | Gateway MT3705 Notebook
I have a compaq cq61 laptop , before few days my laptop fan stopped working nd my laptop back side getting verry hot after using 30 minutes ..bt laptop nt getting shuts off bt laptop is getting verry slow...
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit dust causes static to build up in a computer causing it to overheat any many other problems
also you could buy a laptop usb cooling pad 3-LED FAN USB NOTEBOOK LAPTOP COOLING COOLER PAD STAND or something similiar the cooling pads are very cheap and very good thing for your laptop
hope this helps
May 23, 2011 | Compaq Presario Fan
My dv9000 locks up after it gets hot. What can I do?
A laptop locks up or shuts down when it get very hot. The CPU shuts down (thermal overload) when it overheats and will not boot up until it has cooled down. If this problem is not fixed, eventually the CPU will fail.
This problem could be caused be a faulty CPU fan and/or the CPU and heat sink assemble is clogged with dust.
Check the CPU fan to see if the fan blade spins freely (it may have a seized bearing), if not replace the fan. If the fan and heatsink is clogged with dust, clean and remove the dust.
If additional cooling is required and there are ventilation grills on the bottom of the laptop, then purchase a laptop cooling pad. Place the laptop on the cooling pad, these pads have fans that direct air into the grills at the bottom of the laptop.
Jul 21, 2010 | HP Pavilion dv9000z Notebook
Overheats easily
games make system hot coz they use mor memory ,power and processer units so use cool pad for cooling lap
Jun 25, 2010 | Gateway MX6445 Notebook
Running very hot and shutting down
You are running into a CPU overheat issue.
1. can you feel or hear the cooling fan come on at all? If so try and use compressed air can to clean it out.. they get tremendously dirty. You can also try a vacuum hose, but cover nozzle with hand and only hold next to cooling fan outlet and nowehre else with laptop off and unplugged. Dont get near keys or other parts as will damage. Dont use SHOP VAC either.
2. If Cooling fan is NOT Coming on you can try a laptop cooling pad. these are external units by Targus and other companies that have cooling fans to supplement a laptop units cooling fan. You can try this to see if airflow is your problem.
3. If you recently ran encryption software, a new antivirus program, or upgraded to Windows 7 it is possible that your culprit is the unit is not cycling. Meaning the hard drive is continuously being accessed and the CPU is in constant service... this can cause overheating as well.
Jun 02, 2010 | Toshiba Satellite A135-S2276 Notebook
Vaio computer problem
You could have a faulty fan and/or dust clogging the fan and heat-sink assemble. This is the most likely cause of the laptop shutting down. When the CPU overheats it goes into thermal shutdown and if this problem is not fixed, eventually the CPU will fail.
Check the fan to see it it spins freely and check if the fan works when the laptop is powered up.
If the fan and heat-sink is ok, then to give the laptop addition cooling then purchase a laptop cooling pad and place the laptop in this pad (These pads have cooling fans and helps cool the laptop).
Jan 29, 2010 | Sony VAIO VGN-CS110E/W NoteBook
Cooler Problem ?
There are devices you can purchase which aids in pulling more air through the system and keeping it cooler. One which I purchased and am quite pleased with is by Antec. It is a dual fan unit that is powered by one of your USB ports. You place your laptop on top of the unit, power it on, and it works wonders at keeping your system free from damaging heat buildup and those annoying shutdowns!
There are other units made by other manufacturers available as well. Some more expensive, some less. I have always had good luck with products from Antec and their price was reasonable as well.
Jan 24, 2010 | Gateway MT3422 RTL Notebook
LAPTOP OVERHEATS AND COMPLETELY SHUTS OFF
Have you cleaned it lately? If not that's what they sell those cans of compressed air for. With your computer off bloe the air through all of the vents you can locate to get all of tha accumulated dust that is blocking the airflow out of there!
May 25, 2009 | Sony VAIO VGN-FJ170/B Notebook
Gateway Laptop overheated and stopped working.
Usually when the laptop overheats the CPU shuts down, and after it cools down you may be able to power it up again, unless the CPU has failed.
If you are able to get the laptop working, get the fan replaced, if it laptop doesn't boot up then there is a serious problem (most likely a costly one).
Jan 01, 2009 | Gateway Computers & Internet
ACER Aspire 5050 Overheats
You can do it yourself, but I do not recommend it,
I would first try buying a cooling pad for your laptop to see if that resolves the problem.
Mar 14, 2008 | Acer Aspire 5500 5570-2609 Laptop
Gateway MT3422 RTL Notebook Logo
510 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
