Question about Dryers
Wascomat td50 dryer e08 error code
Td50 e08 error code
4 Suggested Answers
SOURCE: ELECTROLUX DRYER T4190, error code E08
E08 flashing on panel. have tried turning
power on and off, but still flashing. problem?
How to solve this problem
Posted on Sep 07, 2010
richroth
  • 9472 Answers
SOURCE: ELECTROLUX DRYER T4130, error code E08 show on
Dryer had been overheated (clogged or damaged air filter). Reset 3 thermo-fuses (small red buttons): 2 under top cover and 1 under back side round cover
Posted on Jan 02, 2011
  • 74 Answers
SOURCE: wascomat dryer error codes
Check the following link: http://www.laundrynation.com/manuals/wp-content/uploads/2011/05/wascomat_dryer_selecta_control_programming_manual.pdf
On page 13 it identifies the E 08 error as overheating air (inlet or outlet). Chances are, it is the outlet that has gotten gunked up from lint or other material. Pull the vent tube off, vacuum out lint traps, clean the outlet tube, reset the machine. If the dryer is linked with other dryers on a multiple-link vent system, cleaning the vent lines may be necessary to avoid the problem.
Posted on Feb 06, 2014
Dryer shows error 8-overheating in or out air. I run thru the reset sequence but it continues to show the error code.
Your thermocouple is reading high, which could be a multitude of factors. We'll go through them from easy to hard:
First, check your dryer vents and make sure they are clean and that you have proper air flow coming in and out of the dryer.
Next, make sure that your motors in your dryer aren't running too hard (check for how easy it is to rotate the drum and the fans when the dryer is off).
If you're still facing problems, try cleaning your heating element, and finally replace the temperature sensor. If none of those things work, you're facing an internal computer issue which isn't likely user serviceable.
Nov 02, 2015 | Wascomat Parts Wascomat 986918 Washer...
Tip
Xbox 360 RROD E08 / error code 0020
x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020x 360 RROD E08 / error code 0020
on Mar 25, 2010 | Microsoft Xbox 360 Console
E08 on my dryer
Search online for "error code E08 + your make & model"
Aug 23, 2015 | Hoover Dryers
My Wascomat TD77 dryer keeps shutting down after 5 minutes and shows E 14. What is wrong with it.
Taken from the following: https://www.wascomat.net/pdfs/487032981.pdf
This is for a different model, but the codes are likely the same.
It is related to non-ignition of gas. You may need to switch on your gas supply, or service your ignition coil.
Resetting gas error
When the ignition control fails to detect a flame a error code E14 is displayed. When this condition occurs, the gas valve is shut off and the ignition control must be reset manually.
Resetting
Open the operating panel and press the gas reset button on the back of the user module board for one second.
See the picture of the gas reset button section 21
NOTE! When resetting the system the dryer must operate on a program with heat and when the heat indicator is on.
Error code
Error code 14 is a normal occurrence when first starting up a dryer, since air in the gas line must be purged.
Aug 26, 2014 | Dryers
Td 50 can,t change programming mode
try turning off at wall first for about 30 sec , if still the same it might be sticking buttons or the programer
Apr 15, 2014 | Wascomat Parts Wascomat 169535 Dryer...
Wascomat dryer error codes
Feb 06, 2014 | Dryers
What do I do when error code reads E 15 . Dryer runs for a few seconds than shuts down. I've tested micro switch and i'ts fine.
Post some pictures of your pilot assembly. I think this might be one of them spark sensor deals where the pilot lights and then detects flame then relays that back to the control for igniton verification. OR just try and clean up the electrode with steel wool and see if the flames stays lit is what I would try.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jan 07, 2013 | Wascomat Parts Wascomat 231754 Dryer...
ELECTROLUX DRYER T4130, error code E08 show on panel. have tried turning power on and off, but still the error code E08.
Jan 02, 2011 | Electrolux Dryers
ELECTROLUX DRYER T4190, error code E08 flashing on panel. have tried turning power on and off, but still flashing. problem?
Aug 14, 2010 | Electrolux Dryers
Dryers Logo
2,191 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
