FixYa.com
Tags:
D-Link AirPlus DI-714P+  802.11b
Need D-Link router
By Bomber - usenet poster
I am trying to find a D-Link DI 714 Access router. Its the one with 4 net
ports and 1 serial port. Does anyone know of another manufacture of routers
which have both 10 base T and serial ports?
Thanks
Frank
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
paulrmc
paulrmc - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The DI-713P had both a serial and a parallel port. As someone has
mentioned, the serial port may be used to network a standalone modem
with a DB9 connector so you can share a dialup connection without ICS.
The DI-713P is not compatible with the range extender. That's one
problem. The other problem I had with mine was that its signal was
off more than it was on. It took me several calls and emails to
persuade D-Link that the unit was defective. I'm in the process of
sending it in for replacement.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Gary10
Gary10 - usenet poster
Rating: 0%, 0 votes
Well, maybe I posted too soon. I see there is an old DI-714
model which does have a serial port for a backup modem. Oh
well...
The old Orinoco RG-1000 has a built-in modem. Works great if you
don't have DSL or cable and still need to use dialup. And yes, I
do have an old one that I never bothered to sell (but would love
to get rid of) :-).
Bill
Solution #3
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
Are you sure you're not confusing your terminology? The DI-714P
has a parallel port, not serial. Printers connect to parallel
ports, and that's what the DI-714P has support for. What do you
want to network with a serial port?
Bill
Solution #4
Not Rated (0)
pawa
pawa - usenet poster
Rating: 0%, 0 votes
I have been to Fry,s CC,Comp USA and none had a router with serial i/0.
Finally found a US Robotics one that had ser and par as well as eathernet.
Thanks
Frank
Solution #5
Not Rated (0)
Peter1
Peter1 - usenet poster
Rating: 0%, 0 votes
Most all of them do.
Linksys.
Siemens.
(even Microsoft is in this hardware market now...overpriced, though)
You might consider going to, say, Circuit City, or whatever is near you.
They
will have at least 4 different vendor's products, and you can chat with
person there,
or just read the boxes. These products are much more THE SAME than
different.
Cheers...
Dave
Can you Help with these Wireless Access Points problems?
Radius Server Work Around
Hello, we currently have a... Answer This...
How do I connect 3 wireless...
I have 3 wireless routers... Answer This...
REset button on WH-5400 CPE
Hi I have the same problem as... Answer This...
sierra aircard 875u connect to...
Hi, I have a sierra aircard and... Answer This...
Wirless Router with Du...
I Have Du Connection in Dubai... Answer This...
Repair Service
Find Wireless Acc. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
