Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
Ge armoire style condensation on freezer door
GE Profile armoire style, condensation on the top of the freezer door. Brand new, set freezer to zero and the fridge to 37.
These are factory specs.
  • 10,865 Answers
The condensation is due to a small amount of cold freezer air getting past the gasket. Warm the entire gasket up for a few minutes with a hair dryer and then close the door and keep it closed for 30 minutes. That will reshape your gasket and solve your problem.
please rate this answer as a fixya!
Posted on Mar 04, 2009
GE Profile Arctica PSS26MG freezer thawed fridge not cold sounds like running rubber on fridge door hot as where it closes between freezer & fridge
The door frame has a heater in it to stop condensation and the freezer door sticking shut with ice.
As both freezer and fridge have failed, you need to call a refrigeration engineer, as it either needs more refrigerant gas or a new thermostat, or (hopefully not), a new compressor.
Oct 23, 2015 | GE Refrigerators
I have a freezer on top GE profile arctic fridge. It heated up for 24 hour then went back down and is now hovering at 7 freezer and 42 fridge. What is wrong?
This is a common problem with the GE Artica and Profile. The mother board=> WR55X10942 Main Control Board Compressor start components and condenser or evaporator fans must also be considered in the diagnostics. If you would like to do this yourself let me know and I will be glad to help you go throgh with the testing, Thanks Sea Breeze
7_10_2012_2_44_57_am.jpgWR55X10942 Main Control Board
Jul 09, 2012 | GE Profile Arctica Stainless Steel Top...
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Coil fan will not run.
Replace the master control circuit board on the rear of the fridge.
Jun 22, 2009 | GE Profile Bottom-Freezer Refrigerator...
16 month old GE Profile refrigerator with bottom freezer can no longer maintain freezer temp. With control set at zero degrees, freezer temp varies from twenty down to six degrees. Both sides of cabinet...
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Nov 25, 2008 | Pds GE Profile Energy Star 22.2 Cu. Ft....
Brand new GE wont get cold
Sounds like the installers had to remove the doors when the unit was delivered. If they did they might not of hooked the wire harness up at the top of the door hinge or damaged the room thermisters at the top of the door hinge system. Also there is 2 magnetic switches under the top of the doors, you might check the wires on them as well.
Jun 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge refrig
I have a ge profile side by side. when it auto defrosts the water runs to the bottom and out the freezer door instead of down the drian??
May 31, 2008 | GE Profile Arctica Stainless Steel Top...
Does not stop cooling down
Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
May 03, 2008 | GE Profile¿ Arctica® Energy...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
195 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
