Question about Roper REX4634KQ Electric Dryer
GOT A SQUEAK AND NEED TO REPLACE DOOR GASKET NEED TO LOOK AT BOOK ROPER DRYER MOD.REX4634JQO
  • 653 Answers
The Roper is manufactured by Whirlpool. Your REX4634JQO should be identical to the Whirlpool LER 4634 J. Go to Roper's website at www.roperappliances.com/support to see about getting a manual. If you want to get at the problem without waiting for a manual, take a putty knife and slide it under the top of the dryer at the two retaining clips to pop it open and tilt the top back exposing the top of the drum. Then open the bottom panel and take the belt off the motor pulley. You should then be able to lift the drum out of the enclosure. Clean off the ball and socket at the back of the drum and apply fresh grease. Clean the lint off the idle rollers at the front of the enclosure and make sure they turn freely. Clean the surface where the belt rides and clean off the belt, then reassemble. If the belt is glazed, frayed, cracked, or shows any other wear or damage, do yourself a big favor and replace it now. I think the last one I bought was about $12 and will save you the trouble of doing all this again when the belt does finally fail.
Posted on Mar 04, 2009
  • Fahr Quad Mar 07, 2009
    Did that work for you???
Kenmore mod 110 62932100 dryer won t start
First thing to check is the breakers on the building. Then unplug it and check the door switch. They go bad or get loose because of constant use
Jun 26, 2014 | Roper REX3614KW Electric Dryer
Model# RT18DKXEW05 parts
Repair clinic has booth door gaskets
the refrigerator gasket is $91.60
The freezer door gasket is $72.95
If the unit is working good it might be worth it to replace the gaskets if unit is in good shape and you only need one of the 2 gaskets I would replace it. if needs both you need to see what a replacement unit costs and make a decision
http://www.repairclinic.com/Roper-Refrigerator-Model-RT18DKXEW05-ID-114014-Gasket-Seal-Parts
Jan 29, 2013 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
High pitch squeak
This is typical when the drive belt becomes worn and slips more than it grabs. This causes the squeaking noise you are describing. Below is a short but helpful video which shows the location andl how to replace the belt on a Roper dryer. Best of luck!
Greg
Jan 05, 2012 | Roper Dryers
I have a Roper Mod:REX4634JQO Electric Dryer. The Dryer does not fully heat up on any of the cycles. I have to run the cycle twice, sometimes 3 times (50 minutes each time) to dry my cloths. Any ideas of...
either your heating coil is damaged or you have a bad resistor in the back of the panel ...any tech can take a look and tell...the resistors run about 20.00 the coils on the other hand may turn out to be as high as 200.00 plus labor..hopefully it is the resistor..GOD bless
Sep 18, 2017 | Roper REX4634KQ Electric Dryer
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
Repair book for Belt replacement Roper REX5634PQO
1. unplug dryer
2. popoff the top off
3. take front off (unscrew)
now you can get access to the belt look in bottom of dryer there is a giude wheel for the belt
4. place belt around drum and pulley make sure you add tenstion
5. replace front and top
Thank you for useing Fixya
Feb 12, 2009 | Roper REX5635E Dryer
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
Dryer
Your machine uses a belt tensioner of the type that the belt 'glides' on, creating a squeak noise that #1 will get worse and #2 is wearing out the belt. Replace the old tensioner with the one pictured here. The squeak will go away and the belt will last longer.
If you need further assistance, or instruction on disassembly, let me know
Regards,
reg501
Jun 27, 2008 | Roper RGX4634KQ Gas Dryer
Roper REX4634KQ Electric Dryer Logo
108 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
