Question about True T-49 Side by Side Refrigerator Commercial
Evap fans not running after power loss and restart
The evaporator fans didnt run upon restart after a loss of power. Now the system runs at about 1 psi suction and 160 lbs head afetr i wired the fans hot all the time. Any help?
  • 400 Answers
It sounds like you could be stuck on a defrost cycle? The system is in a pump down cycle, check solenoid valve is off but compressor is not cutting on pressure switch.
Posted on Mar 05, 2009
Hi, I have True T49F. When I plug in the system runs, but the evap fans was run. Then for a minute the Compressor frost up. So what do I need to check? Please help......
The compressor will appear to freeze up if the evaporator fan stops running while the compressor is running. I would look for a defective evaporator fan if I understand you correctly. Fans will sometimes stop when they should be running. Defective fan does not always stop running when they go bad
Appliance 911 Sea Breeze
Mar 14, 2017 | True Refrigerators
Refrigerator not cooling.
No the evaporator fan not running has nothing to do with the compressor. I would suspect that you are freezing up over the evaporator because the fan is not running and when it ices up the air can not flow through properly therefore causing the refrigerator side to get warmer. Replace the fan and you should be fine. Take the back panel inside the freezer off and see if you are all iced up. If you bare then I would replace the fan . You also said the defrost heater did not come on. That will also cause a freeze up. Possible replacement of the defrost heater may be needed. Good Luck!
Jul 25, 2015 | Amana Refrigerators
Code po456 on my 2006 mustang 6 cyl. is there an easy fix
This elaborates more on the code.
P0456 - Evaporative Emission System Leak Detected (Very Small Leak)
Description:
The powertrain control module (PCM) monitors the complete evaporative emission (EVAP) control system for the presence of a very small fuel vapor leak. The system failure occurs when a fuel vapor leak from an opening as small as 0.508 mm (0.020 inch) is detected by the EVAP running loss monitor test.
Possible Causes:
• Very small holes or cuts in the fuel vapor hoses/tubes
• Loose fuel vapor hose/tube connections to the EVAP system components
• EVAP system component seals leaking. See the Possible Causes for DTC P0442
Diagnostic Aids:
Check for a missing fuel filler cap or the integrity of the cap.
Check for loose or damaged vapor hoses. Visually inspect the EVAP canister inlet port, CV solenoid filter, and canister vent hose assembly for contamination or debris.
Application Key On Engine Off Key On Engine Running Continuous
Nov 21, 2013 | 2006 Ford Mustang V6
Code po456 on a 2006 mustang 6 cylinder. any suggestions?
Description:
Possible Causes:
Diagnostic Aids:
Voltage to evap fan 94v not working runs slow @ 120v
Hi, I deal with evaporator motors on a day to day basis.If the motor is running but not up to full speed, the inner windings of the motor are going out. If the motor runs as you say, is it getting only 94 volts to it? If this is the case, check the incoming voltage to the unit itself. Check to see on the schematics what is between the motor where you may be loosing your voltage. Defrost thermostat, or timer. Check power to the timer first and get back to me. The defrost thermostat supplies power to the fan when the evaporator temperature gets cold enough and the contacts will close and send power to one side of the motor. If it is going bad, it will cause you to loose part or all of the voltage. If you have a meter, check this. It is round and sealed with 2 terminals on it. If it is cold enough, you can check the leads to ground and see if you are getting less then 120 volts coming out the motor side. If so, replace the thermostat. Please keep me posted.
Sincerely,
Shastalaker7
PS Be safe around electricity. Also, this defrost stat snaps around a evap. line.
Dec 28, 2009 | Amana Refrigerators
Refrigerator has a clicking sound and does not run
Replace the motherboard (part # WR55X10942) but be careful to check that the evaporator fan (inside the freezer) turns on when you power up the refrig again. A bad evaporator fan motor can take out the motherboard. If compressor starts with new board but not evap fan, unplug immeadiatelly and replace the evap fan motor to save new board.
Sep 11, 2009 | Refrigerators
New evaporator fan not running smoothly
Great ! ! Usually the main control board is the problem , when the evap fan doesn't run .
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
Check engine light is on for emission evaporator failure-large
P0455 - EVAP Control System Leak Detected (No Purge Flow or Large Leak) The PCM monitors the complete EVAP control system for no purge flow, the presence of a large fuel vapor leak or multiple small fuel vapor leaks. The system failure occurs when no purge flow (attributed to fuel vapor blockages or restrictions), a large fuel vapor leak or multiple fuel vapor leaks are detected by the EVAP running loss monitor test with the engine running (but not at idle).
  • After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
  • Disconnected or cracked fuel EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube
  • EVAP canister purge valve stuck closed
  • Damaged EVAP canister
  • Damaged or missing fuel filler cap
  • Insufficient fuel filler cap installation
  • Loose fuel vapor hose/tube connections to EVAP system components
  • Blockages or restrictions in fuel vapor hoses/tubes (items also listed under disconnections or cracks)
  • Fuel vapor control valve tube assembly or fuel vapor vent valve assembly blocked
  • Canister vent (CV) solenoid stuck open
  • Mechanically inoperative fuel tank pressure (FTP) sensor
Check for audible vacuum noise or significant fuel odor in the engine compartment or near the EVAP canister and fuel tank. ----------------------------------------------------------------------------- HX43 DTC P0457: CHECK FOR MISSING OR LEAKING FUEL FILLER CAP
  • Check for missing fuel filler cap.
  • Check for loose fuel filler cap.
  • Check for possible cross-thread fuel filler cap condition.
Is a fault present concerning the proper installation of the fuel filler cap? Yes No REPLACE cross-threaded or damaged fuel filler cap. RECONNECT and TIGHTEN the fuel filler cap only one eighth turn so that the cap initially clicks by sound or touch. CLEAR Continuous Memory DTCs. COMPLETE an Evaporative Emission Running Loss Monitor Repair Verification Drive Cycle (refer to Section 2 , Drive Cycles). RERUN Quick Test . If DTC P0455 or P0457 is present, Go to HX44 . CLEAR Continuous Memory DTCs. COMPLETE an Evaporative Emission Running Loss Monitor Repair Verification Drive Cycle (refer to Section 2 , Drive Cycles). RERUN Quick Test .
For DTC P0455 still present: Go to HX44 .
Otherwise, INFORM the vehicle owner that it is important and necessary to immediately install the fuel filler cap after every refueling event. HX44 DTC P0455: VISUAL INSPECTION FOR SUBSTANTIAL EVAPORATIVE EMISSION SYSTEM LEAKS
  • Check for missing fuel filler cap. If the cap is loose DO NOT DISTURB EVAP system.
  • Verify that both the input port vacuum hose and EVAP return tube are attached to the EVAP canister purge valve. Note: If the EVAP canister-CV solenoid assembly is not accessible during this pinpoint test step, GO to Evaporative Emissions, Section 303-13 in the Workshop Manual for removal and installation instructions.
  • Verify that the CV solenoid is properly seated on the EVAP canister (if possible).
  • Visually inspect for disconnected or cracked fuel vapor hoses/tubes between the intake manifold, the EVAP canister purge valve, the EVAP canister, the fuel vapor vent valve assembly and if applicable the fuel vapor control valve tube assembly.
  • Check for damage to the fuel filler pipe and the fuel tank.
Is a fault indicated? Yes No CONNECT or REPLACE fuel vapor hoses/tubes as required. REPLACE damaged EVAP system components (fuel filler pipe, fuel vapor vent valve assembly, fuel vapor control valve tube assembly, EVAP canister purge valve, FTP sensor and EVAP canister-CV solenoid assembly) as necessary. REFER to Evaporative Emissions, Section 303-13 in the Workshop Manual for removal and installation instructions. GO to HX45 . GO to HX45 . HX45 DTC P1443 and P0455: CHECK FOR EVAPORATIVE EMISSION SYSTEM LEAKS
    Note: When checking for leaks or blockages in the EVAP system, energize (close) the canister vent (CV) solenoid through the scan tool for a maximum of nine minutes per pinpoint test step. Then de-energize the CV solenoid prior to performing the subsequent pinpoint test step. This is done to assure proper closing of the solenoid.
  • Disconnect and plug the EVAP return tube (EVAP canister purge valve to intake manifold) at the intake manifold vacuum source.
  • Connect scan tool.
  • Key on, engine off.
  • Access VPWR PID. If the voltage is not 12 volts or greater, GO to HX61 .
  • Locate evaporative test port [marked EVAPORATIVE SERVICE PORT DO NOT USE UNREGULATED PRESSURE ABOVE 6.89 kPa (1 PSI)] near EVAP canister purge valve or EVAP canister.
  • If vehicle is not equipped with the evaporative test port, GO to HX50 .
  • Install the Rotunda Evaporative Emission System Leak Tester 310-F007 (134-00056) or equivalent at the evaporative test port.
  • Close CV solenoid by accessing Output Test Mode on the scan tool.
  • Select ALL OFF mode and push START button.
  • Regulate the nitrogen or argon gas pressure on the tester to 3.48 kPa (14 in-H 2 O).
  • Follow the instructions that come with the EVAP System Leak Tester and pressurize the EVAP system.
  • Perform the EVAP system leak test.
Does the pressure on the EVAP system stay above 1.99 kPa (8 in-H 2 O) and pass the leak test? Yes No GO to HX46 . REMOVE the EVAP System Leak Tester from the evaporative test port and REINSTALL the test port cap. GO to HX50 .
Apr 15, 2009 | 1999 Lincoln Town Car
True T-49 Side by Side Refrigerator Commercial Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
