Question about Sony Televison & Video
My 10 year old KV-27V22 turned off by itself and won't turn back on. No fault code(standby light) no nothing. Power to set is good.
  • skitowniron Mar 04, 2009
    Dogey , thanks for your response. The fuse has continuity (its good). Its a 6.3A 125V. Do you have any other ideas?
    Thanks , Josh
  • 74 Answers
Take the back off of the set and check the fuse if it is bad replace it be sure to uuplug your tv before you take the back off of it after you replace fuse if it is bad plug it up and see if it will come on if the fuse blows again then you have a deeper problem like the bridge shorted or transistor, restors in the power supply of the set.
Posted on Mar 04, 2009
  • vic richards Mar 04, 2009
    let me see if i can find this set in my book or one close to it so i can give you some referance numbers on the board to check. In the mean time you could look on the bottom of the board for bad solder conections that develope form heat some you can see and some it is hard to see with out a strong looking glass. If you do look at the board remember there can be high voltage on it even if it is unpluged from ac line. I will get back with you tonight some time earley i hope.
  • vic richards Mar 05, 2009
    Ok the first thing you should do is unplug tv then take a flat tip screw driver bare a peace of insulated wire on the ends warp one end around the mental; part of the screw driver and the other end attach the other end to a cable that goes around the tube this cable is silver in color, now slide the screw driver up under the gray rubber cup that is at the top center of tube that the big red wire is in. You may or may not hear a snap be sure and hold onto the handle of the screw driver so you dont get shocked. The red wire that is going through the gray cup has a spring like hook on it that i s in a hole you can see what i mean by lifting up the cup with the screw driver need to pull the red wire out of the hole cup and all.
    Now that you get that done you can remove the board from the tv set the board that is on the back of the tv tube will unplug the wires that come down off of the yoke which is the big bunch of copper wire around the neck of the tube, should be a red green yellow and blue wire going into the board in one plug, also unplug the speaker wires be sure to note where you unplug everything at so you can put it back togather. now you acan look the board over on the solder side for bad solder joints resolder any that you think is bad.
    Now you need to check Q601and Q602 which are a transistor that is atached to a small heat sinks also check R which is a resister 0.1 ohm 1/2 watt in value it should be white in color about as big around as a pencil and 1/2 inch long or less also there could be a transformer open may be marked T 605 on the board in the same area. Now if you have not a clue as to what im talking about or how to check these parts then i would take to a shop to get fixed but the tv is 10 years old and only a 27 inch and i probley woul by me a new one becouse the tv is realey not worth it in my way of thinking. Oh by the way the 2 transters i told you about they crose to number 2SC4834 if you order them from a parts outlet like MCM. They do make a kit with these parts in it not the transformer though. Hope this helps.
TV keeps turning on and off by itself.
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Apr 30, 2015 | Sony KV-27V22 TV
What does it mean when the standby light flashes four times on a Sony TV Model # KV-24FV12 ?
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 22, 2014 | Televison & Video
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
KV-24FS100 TV shutting off
How many times the standby light flashes in between switch ON and going OFF?
For more details about this fault, visit this site, and call older posts.
Type in this link address, [without brackets] either to Google Search Box or into the Address Bar to your browser and press Enter. It has all the details about blinking codes of Sony Sets.
electronicshelponline(.)blogspot(.)com
In name [Electro-Help]
Apr 16, 2012 | Sony FD Trinitron KV-32HV600 32" TV
No picture or sound when powered up. Red Standby light flashes continually. My Sony KV 36 XBR250 Wega Trinitron XBR is about 10 years old and has worked perfectly up to this point. What could be the...
Did you get your set fixed or did you replace it? My same set did the same thing. Turned it off for 2-3hrs after watching it and when I tried to power it up- nothing but the sound it would normally make just before the major power up, sort of a relay click sound. No picture or sound but the red light blinks non-stop.
Jan 20, 2010 | Sony KV-36XBR250 TV
My tv turned itself off this morning, then when i tried turning it back on, its making a buzzing sound, and i can smell burning, any ideas? its not turning on still, just the red standby lights on.
i have forgotten my parental control pin after five times pin then it has blocked how to unblock it. which codes should i use to unblock
Jun 29, 2009 | Sony KV-27V22 TV
Blank Picture, Sound OK on Sony TV
Hello, there can be a contact problem in power supply, deflection or RGB stage. Please ask the tech to repair it for you. Best regards, Arpi
Apr 22, 2007 | Sony KV-27V22 TV
No picture, sound works on Sony TV
Hello, maybe there is a contact error in power supply or the deflection stage. If the resoldering does not help- here are some possible solutions: remedy Replace flyback location LP04. Entered for KV32S22 /SONY (Chassis) remedy 2 Replace IC351, Q602, Q601 (2SC4834M), R607 (1R/0.5W), R622 (10R), IC641 (SI3090CA) and Q502 (2SC5148). remedy 3 Replace tuner. remedy 4 Replace R607, Q502 and IC601. Entered for KV32S22 /SONY (Chassis) remedy 5 Replace regulator IC, R607, check C609, C610 (0.68pF) and C613 (0.0022pF/500V). remedy 6 Replace horizontal output transistor (2SC5148), IC601 (MX0841) and R607 (0.1R). remedy 7 Replace IC1701 and IC601. remedy 8 Replace Q501 (2SC5148), R607 and resolder horizontal driver transformer. remedy 9 Check and replace horizontal output transistor Q502 (2SC5148) and IC601 (MXD8411AB-F). remedy 10 Replace shorted R607. Also check T501 and Q501 for dry joints. remedy 11 Replace C608. remedy 12 Replace Q602 and D648. remedy 13 Replace Q502, Q601, Q602 and R602. Entered for KV32S22 /SONY (Chassis) remedy 14 Replace D626 (6.2V). remedy 15 Replace IC801 and R607. remedy 16 Replace horizontal output transistor and the associated damping capacitor. Check flyback transformer and SMD microprocessor as well. remedy 17 Replace R639 (4.7R/0.250W) located on G board in standby power circuit. remedy 18 Replace D600. remedy 19 Replace C502 (0.47uF/50V). remedy 20 Check D655(1N4937), D657 (1S1834) and Q601 (2SC4423). remedy 21 Check D606 for leakage. remedy 22 Check yoke between vertical and horizontal windings for S/C. remedy 23 Replace Q601 (2SC4834MNP), R607 (0.1R) and C517 (2.2uF/250V). remedy 24 Replace R611.
Sound, but no picture
Locate vertical output IC = solder all pins = two off-set rows,
then try again................part location IC301 , or 401 ?
2) possible bad CRT = turn up screen voltage slightly = did pix pop back on ?..................................T.
Please rate this solution.........................
Feb 09, 2007 | Sony KV-27V22 TV
Sony KV-32S40 32" TV problem
intermittent problems can usuall be liked to bad solder connections. And sony typically has some that will develop after a few years in the power supply. so check for bad sodler connections throught the main board & give a close look to the power supply & check you work after to make sure you have no shorted pins. good luck.
Dec 27, 2006 | Sony KV-32S40 32" TV
Televison & Video Logo
52 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
