Question about Insignia 42" LCD Flat-Panel HDTV
I touched the side of my TV and sent a static charge to the TV. Now I have no screen The green power light just blinks off and on like its on standby.
  • 1 more comment
  • msawyer400 Nov 07, 2009
    My son bought it 2 christmas's ago. He set it up. It was plugged into a surge protector. My wife turned it off on the tv itself and had the shock. Our house is dry as this happed in the winter last year. I'm just now getting around to trying to get it fixed. Money has been tight. What if anything could of been done to ground the TV?
    I touched the side of my TV and sent a staticI touched the side of my TV and sent a static charge to the TV. Now I have no screen The green power light just blinks off and on like its on standby. MoreI touched the side of my TV and sent a static charge to the TV. Now I have no screen The green power light just blinks off and on like its on standby.
    Comments:
    Nov 07, 2009 - My
    Thank you for a more precise answer and not have the guy come back and fix it. I couldnt believe he offered that as a solution. I will try and find some tech support somehere and try powering it agian. Thanks agian for your help.
  • 466 Answers
Try disconnecting the unit from the wall power outlet and let it sit for some minutes - or fifteen. Depending on what exactly happened inside the TV, this might be enough to clear the error.
If there's a permanent shutdown mechanism in the TV, you might be able to clear it by resetting the unit: this usually involves some "secret move" which the technical support will have to tell you. On most units it's no great secret, and involves powering on while keeping the standby button pressed or keeping the ON/OFF button pressed for 7 seconds, things like that.
Finally, it is unfortunately possible that the static charge sent an overvoltage straight into some core IC chip. If this happened, the IC is gone and needs identification and replacement.
Normally it should NEVER happen because the external part of the TV should be electrically insulated. You only get static hazards from OPEN devices and this must be labeled ("No user serviceable parts inside / Risk of electric shock"). If a static charge can get from you to the device's innards, the same way you could get an electric shock from the power lines inside the device.
An "ungrounded" device should simply not give any static shock, because there's no path to ground through the device's insulation and shield. If it does give a shock, the path exists - and security regulations mandate that it should run well clear of internal circuitry for obvious reasons.
That's why I think you triggered some sort of "last line of defense" circuit which essentially disabled the TV to weather the storm, and you only need to reset the circuit. Otherwise, you have a potentially serious design flaw in the device which should be reported to the firm.
Under these conditions you may be able to recover repair expenses or even get a new unit, depending on your local law.
Posted on Nov 07, 2009
  • 484 Answers
Whomever set this unit up did not ground it properly. Have them come back and be sure that it works before they leave the house. Even try the static charge zip again, to ensure that they have it grounded properly.
If they cannot make it work, demand that they repolace this unit. You paid a lot of money for it, and it should work first time out.
Just because they sell these things doesn't make them experts on setting them up under various circumstances.
Repair Sony nsx-40gt1 tv, no picture, 2 red blinking lights where normally green. Is the power supply board bad, t-con bad or main board bad. Who sells repair manual?
Hello Eric,
shopjimmy has the circuit boards and gives live support..
Check out the URL below.
Also consider getting an anti-static wrist band... so you don't destroy good semi-conductors with tiny static sparks.
Further information on that is under "ESD"
(Electro-static Discharge)
TV Parts Universal TV Stands DLP Chips ShopJimmy
Sep 14, 2016 | Sony NSX40GT1 40 Inch Internet TV powered...
My panasonic th-42pwd8uk tv wont power on. When I press power it clicks to turn on then clicks again and the screen never shows up. No red lights no blinking lights just a solid green light.
Check the capacitors and replace the power components. It is an easy fix if handy with soldering electronics. Tv Repairman may charge less than $100.00 bucks to fix it !
Good luck
Sep 21, 2012 | Panasonic TH-42PWD8UK 42 in. EDTV-Ready...
I have a Sharp LC-46E77UN TV. Remote will start TV green light on. No picture, just stays black. PVR is on and connected to TV via HDMI cable. Cannot turn off green light. Must use power button on TV and...
THe problem is in the set top box. Or common called the tuner box. IT looses the 5 volts to the main display and thus the monitor will go into a shut down state. THESE boxes are factory repair only and must be sent off to repair.
Feb 20, 2011 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
My Hitachi P50x01au plasma TV screen goes blank suddently, and the power indicator green light blinking. TV cannot be turn off by the remote. I switched off the power manually, and turn it on, but the...
I would open back and check all boards for cracks, this is a problem with these sets.Then count the blinks on the set and see if it stops for a moment and starts back.
Jan 19, 2011 | Hitachi Televison & Video
Tv turns on green light blinks three times then TV turns off
Ur power supply board is dead.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 07, 2010 | LG 42LC2D 42 in. LCD HDTV
47LC7DF, Green light comes on, blinks with remote
When you say that you have replaced the main board i assume you mean the power board? If the green light comes on and blinks when the remote is touched it was never a issue with the mainboard, if it was you wouldnt have any signs of power. In most lcd tvs you have the main board which is normally the power board, the signal board which recieves signal and hold settings of the tv which can be all in one, the other is the inverter board, which scrambles the signal to what you see on the screen, and next we have the back light which lights the screen so you can see the picture, sometimes in certain models as i have learned you can have power/inverter boards which means the inverter and power are all on the same board, in your case i pressume the inverter board is seperate board and probably the issue you need to address, you can buy these online probably the same place you got your new mainboard from. Hope this helps pls post bach what happens.
Feb 01, 2010 | LG 47LC7DF 47 in. LCD HDTV
I have sharp 37 inch LC-37D44U MY PS3 is not working with it it green lights keep blinking power light and OPC. BUT THE HDMi ports work beacause i checked it with other devices. so i dont know why its not...
Does this happen when you input certain signals to the HDMI2_bing.gif ports? Or all signals (e.g. 1080i, 720p, 1080p, etc.)? And which ports are affected - side HDMI, rear component, etc.?
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)... their first visit allowed my TV to accept signals in the rear HDMI ports (all signals worked well), but then I couldn't get a signal processed via the side HDMI port. At first, just 1080p would not display (caused the OPC/power green light blinking), and after a few days, any signal hitting that port would cause the error lights to come on. But as I said, eventually, a new side board resolved that issue.
Sep 11, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Green spot like a spotlight on the screen
Take the offer,even they charge u it will still cheaper than the repair shop and quicker too,because they have the parts with them they don't have to trouble shoot like the shop,if the prob.the shop never seen it before.
Jun 24, 2009 | Panasonic PT-44LCX65 Television
Power button is green - no blinks / no picture / no sound
Unplug it from the wall, wait 2 minutes and plug it back in. if problem still exists, its probably the main pcb.
Jun 19, 2008 | Dynex 32 in. LCD Flat-Panel HDTV
Insignia 42" LCD Flat-Panel HDTV Logo
87 people viewed this question
Top Insignia Televison & Video Experts
Dave Naylor
Dave Naylor
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
