Question about RTO Bodyguard T200 Treadmill
Treadbelt not alligned
Theres a little gap on the right side of the belt. How do i move the belt a little to the right. I lost my manual. Thank you for your help.
  • 256 Answers
Hi, Most all treadmills use the same type of belt tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Posted on Mar 04, 2009
How do I center the Keys Fitness Health Trainer 502T treadbelt? thank you.
there are two bolts at the end of the treadmill.one on each side. usually an allen head. tighen clockwise the side that the belt is closest to about a full turn. turn on treadmill about 2mph. watch belt run. it will take 20 seconds to adjust. with unit running adjust till centered.only go 1/4 to1/2 turn at a time and let it adjust
Oct 16, 2014 | Exercise & Fitness
Walking belt not properly aligned
There are two holes on each side of the back covers of the treadmill. They have the adjustment bolts in them for the rear roller and It will require an Allen wrench to adjust it. If you tighten one of the bolts it causes the belt to move away from that side. So if it's the left side of the belt that's moving close to the rail then tighten the left side and vise versa for right. Turn the unit on and set the speed to about 3. Tighten the side that the belt closer to the side rail about a quarter turn. Be patient and give it a minute to settle after you adjust it. Repeat until the belt has moved back to center. If it moves too far just back it off a bit.
Jan 07, 2014 | Precor Treadmill Belt 9.10, 9.2 Treadbelt...
Tread on Vitamaster moved to the right... How do I center it again?
If belt moves to the right then tighten the right side bolt at end of treadbelt.
Feb 09, 2011 | Exercise & Fitness
My treadbelt keeps sliding to the side....tearing the belt. It destroyed the one side and is now sliding to the other..getting hung up. tried tightening the belt...but doesnt seem to help. would a new...
Hello , you need the adjust the two rear tension bolts/screws. If they keep loosening up, their is a update kit that has a larger head and had locking serations on the back. You can order these from iconservice.com
Hope this helps
Feb 05, 2011 | Treadmill Doctor Proform Crosswalk Plus...
The treadmill seems to work fine at first then the belt kinda sticks. It like stops and goes. Electrical seems fine
It's possible that your treadbelt needs lubrication, or simply adjusting. Here is a tutorial on adjusting your treadbelt:
Here is one link to purchase a lube kit, there are probably many others online also:
Should you actually need to purchase a new treadbelt, I would try to identify which specific model of the Proform 530 you have from this list and then in the parts list for that treadmill scroll down to "Treadbelt"
Oct 14, 2010 | Proform 530 Treadmill Walking Belt
If I stand on the belt it stops moving
Unplug unit remove motor shroud so you can see the drive belt, plug in unit then start it you will be able to see whether the drive belt or running is actually causing the problem.If it is the running belt then turn both rear roller adjustment bolts clockwise in equal quarter turn increments until treadbelt stops slipping. NOTE: Be sure to run on treadbelt to ensure that the treadbelt does not slip while under load. Use 1/4" allen wrench
If the drive belt is slipping then to adjust the belt you must loosen the adjusting bolt on the motor frame then hold the motor by hand applied tension to belt then tight bolt you should be able to twist the drive belt no more then 45 degrees if you can repeat adjusting process.
Mar 13, 2010 | Proform 760 CrossTrainer Treadmill
GE side by side doors are not alligned
here is a diagram of the doors and the hinge area. Without seeing myself I can only gusess.
you box could be twiked or not level. The hinge at the bottom could be bent. There top hinge sometimes can have an ajustment that moves the top of the door left and right wich will raise the door a littel. to see if this has an ajustment you will need to remove the top cover of the top hinge and loosen the bolts a little and move the door left and right, if it does have someone hold the door where you want and tighten.
Jan 11, 2010 | GE GSS22SGM Side by Side Refrigerator
Need to set the head gap on a Genicom 3870. Lost my manual.
If it has a manual adjust, open the top cover and on the right side will be a slide for different head adjustments, it wll be numbered 1-6, 6 being right against the paper which causes smears. Move to around 3. If it has auto adjust (you can tell this when you power up the display will show "adjusting gap" then press off line, the press program, move to head adjust, press enter, press enter again then use the arrows up and down to move to your type of printing, 2part, 3 part ect.
Mar 13, 2009 | Tally Genicom 3810S Printer
Treadmill adjustment general lines?
"The best treadmills are those that provide you easy access to belt tracking. But, even the best treadmills with the most easily accessible belt tracking are also susceptible to stretch slightly under initial use. That is why it is important that you adjust the tread belt every so often to keep it away from stretching. Most manufacturers include the Allen wrench (a tool consisting of a hexagonal head and an L-shaped bar) in the package when you buy a treadmill from them. Use it to tighten both the belt adjustment screws clockwise. If your manufacturer did not supply you with an Allen wrench, use another of the right size. A ¼ turn, clockwise should tighten treadbelt if it has loosened. The screws for belt adjustment are usually located at the rear end of the treadmill. Some belts do require looser running than others so don’t be surprised if your treadbelt is a little loose even when you haven’t actually used it. Check the user’s guide before making adjustments just to make sure that whatever you are doing is correct. Moreover, be sure to keep the belt running at a low speed of around 3 mph when adjusting the belt tracking. This is the ideal speed when making any adjustments with the screws. Maintaining your treadmill is necessary to upkeep it's performance and looks. A little bit of adjustment here and there can make your treadmill a life long companion. "
Dec 01, 2008 | Endurance TF3i Folding Treadmill
RTO Bodyguard T200 Treadmill Logo
197 people viewed this question
Top RTO Exercise & Fitness Experts
Jax Planet
Jax Planet
Peter
Peter
Are you a RTO Exercise and Fitnes Expert? Answer questions, earn points and help others
