Question about Mitsubishi WD62627 62" HDTV
Half of screen will go black, system reset restores OK??????
Every so often the screen will go black on one side. Left side this time, not sure if its always that side or not. I do a system reset and it solves problem until next time. Do I have bigger problems brewing? It has done this occasionally from the time the TV was new. The TV is about 4 years old now. I'd say that I have had to reset it 2-3 times a year.
Thanks! Dale
    President:
  • Mitsubishi Master
  • 1,779 Answers
Yes you do my friend, if it's new please return it for an exchange or whatever you decide. If it's out of warranty have a svc.ctr look at it. It sounds like a corrupted ee-prom. Sometimes a firmware update can rectify some cases.
Posted on Mar 04, 2009
Display half of screen
screen back light on the other side is busted which need replacement.
Jul 14, 2012 | Computers & Internet
Virus (HELP!!!)
Besides using AVG also use Malwarebytes Anti-Malware.
The free version,
http://download.cnet.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Left-click on the green rectangle to the left, with Download Now, in it.
(Also has - CNET Secure Download)
Burn it to a CD disk. Install it in the affected computer.
While running Malwarebytes you may see pop up after pop up.
So many in fact that that the Malwarebytes screen may be covered enough, that you cannot see if it is still running.
It is. DO NOT click on anything. You will just slow Malwarebytes down.
You may see pop ups that seem to be genuine Microsoft articles. If you look they are. There are also pop ups that emulate them, and they come from the virus.
You don't want to click on the virus ones, and there is no need to click on the genuine articles. It will not do any good clicking on the genuine ones.
When finished close all windows, go back to your desktop screen.
See if you have administrative capabilities.
Click on Control Panel.
(WinXP: Click on Start, then Control Panel
Win Vista, and Win 7: Click on the Windows logo button, then on Control Panel )
Go to System Restore, and Turn It OFF.
(Click on Control Panel > Performance and Maintenance { Category View } > System Restore { Upper left side }
Then click on System Restore Settings at the middle/left side.
Now click in the empty small square box to the left of -
Turn off System Restore on all drives.
{ Puts a green checkmark in the small box }
Lastly, click on Apply at the bottom left, then click on OK.
To turn System Restore back on, go back to this window.
Click in the small square box again. It removes the green checkmark.
{Don't forget to click on Apply, and OK again)
Run Malwarebytes one more time. You may wish to then run AVG.
Once done go back to System Restore (Settings), and turn it back on.
Also make sure you create a Restore Point.
(It's on the first screen to the upper right - Create a restore point.
{Click on the date in the calendar}
Regards,
joecoolvette
Jan 27, 2012 | Dell Computers & Internet
Half screen is blank 42lg20 or 42lg50 when
This is likely to be the T-con board. If the entire screen glows but you have no picture on the second half of the screen then it is the main board, not the backlight inverter. If the screen is half picture and half gray it is the T-con board.
Replacement of one of the above will fix the issue.
Please rate if this helped :)
Mar 07, 2011 | LG 42LC2D 42 in. LCD HDTV
Problem with TV image, sound is OK. My Panasonic Plasma TV is a TH-42PX6U starting from the middle of the screen, the left side does not have any image, it is divided in two, with half been white and...
if you ask me the panel its dead to lose the half of the screen means no addressing logic board dead or in the most of the cases panel :( i`m not sure but if you add some images :D with signal is it the same ?
Sep 22, 2010 | Panasonic TH-42PX60U Television
Decora 6124H Timer
Leviton 6124 timer instructions:
Timer comes with plastic protector over display >> remove protector to see display.
Large button is manual override.
After timer is wired, push override to make sure Load turns ON and OFF.
Timer has 3 small buttons located below manual override used for programming
Display is divided into 24-hours with am times on left and pm on right.
24 Hour day is divided into 1/2 Hour segments
Each 1/2 hour must be set for ON or OFF
Start by pushing left-side event-cursor-advance-button and it scrolls down each 1/2 Hour.
Once you arrive at 1/2 hour > make decision if you want timer ON or OFF for that half hour.
Press event-set-reset-button in center to set ON-OFF for that 1/2 hour.
Press center event-set-reset-button and solid black rectangle fills in for that half hour.
Solid black rectangle means timer ON for that 1/2 Hour.
Once solid square is selected, press event-cursor-advance-button and cursor advances again and starts filling in black rectangles for each 1/2 Hour period.
Keep filling in black rectangles for all times you want timer ON.
When you reach 1/2 Hour period you want timer OFF, then press center event-set-reset-button so that no black rectangle is visible for that 1/2 hour.
No black rectangle means timer is OFF for that half hour.
To set current time, use right-side time-advance-button.
Press and hold time-advance and time cursor advances down through the am and then pm hours.
Stop cursor at current time, and timer is ready.
Jan 04, 2010 | Leviton 6124H 24 Hour LCD Programmable...
One half black verticle screen
Manufacturer Philips Part Number 932224850682 Description LCD DISPLAThis part is no longer available
Aug 20, 2009 | Philips 42PFL5603D - 42 IN. LCD HDTV
Need to restore to factory default but my lappy gives me a blank black screen with a blinking underscore on the top left of the screen.
There might be one step you could try to restore the system to factory specifications. When you turn the laptop on, and you see the Acer splash screen, press the Alt-F10 keys together at the same time, and this should hopefully bring the Acer eRecovery system up, provided that your computer has the built-in recovery partition. If it asks for a password, try using the default of "000000". If that doesn't work, then a password has been entered into the system, and there is no way to reset it, however there is a way to find out what the password is, however it does require the use of the Ubuntu Operating System (which is free to download, here)
May 10, 2009 | Acer Aspire 5050-3242 Notebook
T30 always comes up with record-ready display screen
T30 defaults to an opening display screen based on where you were when you last used the device. When leaving from the record folder and record mode, you will always open with the record-ready screen. If you left your T30 while in the music folder playing a music file, you will be returned to that.
This record-ready display screen has a numeric and bar time line. The numeric values of the line are in hrs:min:seconds. This line is also split: the right half of the line indicates the total amount of available recording time, while the left half indicates your time as you record. If you compare the values of the right and left sides of the numeric bar while you are recording, you will see that the right side is diminishing as the left side increases in numeric value. When you complete your recording and save your track, the right side will now indicate the new total time (the amount your screen first displayed LESS the time value of the track just recorded).
When you are playing a music file, if you watch the time display, you will see the numeric information changing in the same way. The left side indicates how may hrs:min:seconds your track has played while the right side indicates the total time value for that file and will be correspondingly decreasing while you play your music file.
So in the short, you don't need to worry much about your display screen unless you open in the wrong folder or you need more recording time than is available. Then it has a message for you.
Nov 06, 2008 | iRiver T30 MP3 Player
T3302
Click Start (bottom left of your screen), right click My Computer, in the drop down menu select properties. Whe the window opend in the top left tab, select System Restore.
Make sure the little "Turn Off System Restore" box is not checked.
What operating system are you using?
What version of Norton are you using? and is it a paid for version or a trial version?
Jul 23, 2008 | E-Machines eMachines Desktop PC
Mitsubishi WD62627 62" HDTV Logo
125 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
