Question about ASUS Eee PC 900 Notebook
Linux wireless wont connect.
I have an eee pc 900 with Linux. Sometimes I can't connect to a wireless service. It will start connecting, but the connetion status will stall at Pending.... and will stay there for hours and hours until I give up. I tried deleting the connection and trying again, but that didn't work. How can I get this to connect?
  • dyrtiegerl Mar 07, 2009
    i have to stand on my head to get a connection on my eee pc 900. leniux sucx! lol. i have another notebook runs off xp does just fine.
  • Anonymous Apr 11, 2009
    My sister and I just each purchased an ASUS notebook today. Mine runs on XP, and hers runs on Linux. Right away i was online, but she still cannot connect. The conection status just says "pending".
I cannot connect to the internet on my Acer EeePC 900. When I select my network it says limited or no connection. I tried uninstalling and reinstalling but it still wont work. I have windows XP. Its...
If you are connecting via wireless, the reason is usually because your router has lost its internet connection. Try switching the wireless router off, waiting 10 seconds and switching it on again. Can you explain how you are trying to connect and if you can use any other computer successfully, etc.
Jan 02, 2010 | ASUS Eee PC 900 Notebook
I cannot download anything on my pc linux eeepc 900
How are you connected to the internet?
I will take a wild guess and assume you think you are connected by wi-fi, if that's the case and you are using KDE or GNOME (likely) in the bottom of the right of the screen there's an icon which looks a bit like a screwdriver going into something, click on it and select the wireless network you want to connect to.
Oct 08, 2009 | ASUS Eee PC 900 Notebook
Re: the Asus Eee PC 900 Notebook with a Linux operating system and am unable to connect. It will detect my wireless router (Cradlepoint MBR1000 using Verizon USB720). I upgraded to the Verizon USB 760...
what version of linux are you using? If it's one that came preinstalled with the laptop I suggest looking at Ubuntu netbook edition, *very* capable OS, if that can't handle it nothing will.
Aug 02, 2009 | ASUS Eee PC 900 PC Notebook
My asus eee mini laptop with linux
Hi Clappers
You must go to setting>network>LAN & configure ip & dns then try
Harry
Jun 27, 2009 | ASUS Eee PC 900 Notebook
ASUS EEE PC 900 wireless lan doesn't appear on network connection
please if u have a switch for the wifi connection on your laptop please put it on and should see the wifi on your taskbar also please check in controll panel then go to my network connections and see the wifi resides there if yes just right click and enable if not ther check device manager and check for nework devices if the wifi is enable and installed ...if not please installed by right clicking on it and using reinstall..
please let me know what happens
thanks
Jan 24, 2009 | ASUS Eee PC 900 Notebook
Eee PC 900 has problem with wireless connection
Hi terryandy,
I am using the Eee PC from Taiwan also. It is running good.
Based on your scenario, have you tried changing another new router?
Your description of having "out of range" is highly probable due to router hardware failure.
Try replacing the router and update us again.
Thank you.
Jan 06, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
try to change the password to wpa personal in router and then try it on lappy
Dec 17, 2008 | ASUS Eee 4G Notebook
Wireless connection
Some ideas...
I found that sometimes I have to "disable" the wireless service, and then "re-enable" wireless before it will show available wireless connections.
After that, just use your normal connection settings - passwords, security type, etc.
As well, at times, if I use the "Wireless Connections" Icon in the "Internet" page to log in, I have to re-type the password in. If I use the "Network Connections" icon in the toolbar at bottom, it seems to remember my password and logs in faster.
Linux quirks? I dunno. Hope this helps.
Edwin
Nov 20, 2008 | ASUS Eee 4G Notebook
I am not able to connect this with internet.
If you would like to use wireless inernet, you have to have an access point nearby and that you know the authentication like the WEP or the WPA key, and you can get that from the network admin. click start > connect to > wireless network connection , then click on View wireless networks. click on the network you want to connect to, then click on connect. You should be able to connect after entering the passkey, or it automatically connects if the access point is unsecured.
Sep 26, 2008 | ASUS Eee PC 900 16G Notebook
Wireless mobile service connect to eee pc 8 GB?
If this has been solved then please rate to show that you have the solution.
Thanks,
Mowcius
May 23, 2008 | ASUS Eee 4G Notebook
ASUS Eee PC 900 Notebook Logo
329 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
