Question about Liquid Video E15LCD1 15"
No sound from my new monitor
Just bought a new monitor that has the speakers mounted on it and now, after unplugging the old speakers there's no sound. How do I fix this?
  • 60 Answers
Just check the problem area
first go to sound setting by click on sond icon on task bar and set the speaker on.
if not get possitive result then chech sond by using head phone make sure sound drivers working properly or not if not then reinstall the sound driver
Posted on Mar 04, 2009
Speaker in the Monitor?
It looks like there are no speakers according to:
http://support.acer.com/acerpanam/monitor/0000/Acer/X193/X193sp2.shtml
You should be able to use any external speakers to your system. The question is looks and power. You will likely have to buy speakers that have power in order to get enough volume.
Most speakers that come with monitors are of very, very low quality. You now have the option of buying good speakers (if you want to pay for them). If you are in a hurry you can likely pick up cheap speakers at the drugstore or Walmart. Another option is headphones.
Good luck finding the right sound.
May 24, 2010 | Acer X193W LCD Monitor
Dimension 8400 PC Desktop: Where do I connect the monitor mounted speakers to...
you connect the monitor's speaker lead to the speaker jack or line out jack on the sound card.
May 03, 2010 | Computers & Internet
Compaq JBL Platinum Series Speakers not working on Windows Vista
change the audio and sound device setting in the control panel. try to change the speaker setup
Oct 05, 2009 | HP JBL Platinum Computer Speakers
No sound through external speakers
Although some monitors have built in speakers, most people have stand alone speakers. If the old monitor had built in speakers and now it is unplugged you won't hear sound. Even if the speaker cable is still plugged into the sound output on the back of your computer, the monitor must be plugged into an electrical outlet to have power.
I'd recommend buying a new set of external speakers if this is the situation.
If you never had speakers built into the monitor then normally changing monitors would make no difference whatever. The only explanation that makes sense under those conditions is that in the process of replacing the monitor, you dislodged the speaker jack from the sound output on the back of the computer.
Make sure your external speakers have electrical power plugged in, the power is on (green light on at least one speaker lights up) and the volume on the speakers is at least half way up.
Unplug the speaker from whatever hole it is plugged into and plug it firmly back in and test sound.
If still no sound other than some static on the speakers, try every single hole on the back of the computer that the jack will fit properly and test for sound.
Let me know if you have further questions.
Honest1abe
Jan 10, 2009 | Acer Computers & Internet
No speaker hook up on new moniter
If your old monitor was a Compaq, it had slots for the speakers to hang on and provided the power for the speakers. The speakers still got their input from a cable that plugged into the computer sound output jack. If those speakers are the style Compaq supplied when I worked at a Compaq service shop, they originally came with metal stands that fit into slots on the back so you could stand them up on their own, and a 12-volt power adapter so you could use them without the monitor. If you don't have those pieces, you can buy a suitable power adapter (12 volts DC at 1 amp) at Radio Shack but the speaker stands are hard to find. You could try eBay, or just make a holder of some kind. (A friend of mine used those little wooden stands you can buy to display plates to hold her speakers when she got a new monitor. They worked out pretty well.)
Or you can replace the speakers. A new set would have everything you need. But those Compaq speakers sounded pretty good, so if they're still working you might want to keep them.
Dec 22, 2008 | HP Compaq Computer Speakers
No sound on new LG Flatiron Monitor
You need to get a set of powered computer speakers!
I always found that stand alone speakers are much better than the ones in the monitor.
Jerry G.
Apr 30, 2008 | LG Flatron L1919S LCD Monitor
MY MONITOR SPEAKERS
as you say that old speaker is working from the same tower means your computer is ok.
the problem is in speaker only.
plz chk that while shifting some wire must have broken or loose or speaker not connected properly.
ultimately chk connection.
Oct 17, 2007 | Gateway FPD2275W LCD Monitor
No audio from lcd monitor (viewsonic) after disconnecting my speakers. (New monitor has built-in speakers)
make sure you hook up the third gree socket on back of monitor to PC that was my problem and solution to my model monitor LCD
Sep 17, 2007 | Liquid Video E15LCD1 15"
Cannot hook eq to my receiver
The speakers will not sound right. You dont have two tape monitors on this receiver? You can simply use the tape otput to the EQ input, and then the Tape monitor input to the EQ output leads. Good Luck
Jun 09, 2007 | Bose 901 VI Main / Stereo Speaker
Liquid Video E15LCD1 15" Logo
106 people viewed this question
Top Liquid Video Computers & Internet Experts
Rommel Balcita
Mark Gough
Are you a Liquid Video Computer and Internet Expert? Answer questions, earn points and help others
