Question about HP Pavilion dv6000z Notebook
Why does my Hp Pavilion dv6000 keep freezing on me?
I can be on the computer for a few minutes and then my computer freezes up...
Thanks!!!
araiza_v@yahoo.com
  • 46 Answers
Lockups are USUALLY related to memory problems. You could have incorrect (wrong type of or too much) or defective memory. You should see what memory is installed (in a compartment on the bottom of the notebook). and see if it's correct, first. Go to www.crucial.com and use the Memory Advisor Tool. If your memory is the right kind, and there are two modules, remove one at a time to see if that fixes the problem. If so, replace the one that is out when the notebook works okay. If neither solves the problem, try borrowing a module..
Memory CAN be damaged by voltage spikes. If you are not using a surge protector with your notebook, you need to be doing so. Single-socket models are available.
Posted on Mar 04, 2009
Hp pavilion laptop keeps freezing
HP laptops have been having problems with the fan not cooling sufficiently sounds like the processor is getting hot could be a number of things just be sure you hear fan and you are not using the laptop on a soft surface such as a sofa, blanket etc...
Jan 01, 2014 | HP Pavilion dv6000z Notebook
I am using an HP ProBook 4510s. My touch pad keeps freezing on me. Sometimes it will work for a few minutes and then freeze and sometimes the computer boots up with the message No Mouse detected. Any...
I have a 4510s and had this problem before.
Part of the problem was synaptics driver was freezing, Driver Synaptics software upgrade may help if that is part of your problem.
Have you opened the notebook to upgrade or remove the HDD for any reason?
If so, you should make sure the plastic of the palmrest (which houses the touchpad mouse) has been correctly fitted back in place. It may also help to remove the palmrest and ensure the flexible cable is correctly inserted in the ZIF connector.
I also notice there are some contact points from the PC to the underside of the trackpad, it may pay to clean those with metho to make sure the electrical connection is good.
Sep 09, 2010 | Computers & Internet
Hp pavillion dv2000 freezes always but at different times-sometimes i can be on for a few minutes other times maybe 30 minutes before it freezes up it has been sent to hp 2 or 3 times and they cant find...
It is also important to remove the suspicious applications and programs in the computer to avoid Windows freezing. In this type of infection not only your Windows registry gets corrupted and needs massive repair but also there is virus based penetration in the Windows set up. In this situation it is recommended to conduct a virus scan as well.However, if your Windows freezes up, the best solution is to repair the computer registry.use registry cleaner reg in out
Aug 16, 2010 | HP Pavilion dv2000t Notebook
Display and Boot problem with HP Pavilion DV2125NR
It is normal for the bottom to get hot. The fan should keep it cool enough to run, but it sounds like perhaps your fan is not working very well anymore and should be replaced.
Does the computer act up at all when cool? If not, the first thing I would try is replacing the fan and examining the fan and heatsink assembly for proper installation, perhaps replace the heatsink compound with some Arctic Silver while you have it open.
Jul 10, 2009 | HP Pavilion dv2000t Notebook
Hp dv6000 freezes
ok
when you power up the computer press F8 key then enter in safemode.
Then go to start menu then run type in run "chkdsk /r"
then press "y"
then restart computer then it fix error on harddisk.wait until it load windows .
Ifyou stillface problem then your computer is virus infected scan your computer in safemode with good antivirus.
Jun 23, 2009 | HP Pavilion dv6000z Notebook
Hp laptop froze
I understand that notebooks boots into safemode, but when you are trying to reinstall the OS it is freezing, let me assist you in this regard.
As the notebook is frezing while installing the OS, first we need to check the Harddrive.
In DV6000 notebooks, there will be option to do Harddrive selft test.
1 Restart the notebook
2. At HP logo screen keep pressing the F10 key to open BIOS.
3. In the BIOS you can find the Diagnose Tab. (Select it)
4. Under that click on harddrive self test.
If the test pass, you need another set of recovery disks to Restore notebook to factory settings.
If the test fails, then you need to replace the harddrive.
If the notebook is under warranty, then you will get new harddrive from HP.
Aug 11, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion DV6000 with Vista
These are well known for VRAM failure and HP extended the warrany for an extra year regarding this model. If they refuse to repair free contact us back..
Jul 10, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion dv6000
hi
Dude very simple, uninstall the graphic drivers completely and reinstall them.
do give me feedback
bye
yasir sardar
Feb 27, 2008 | HP Pavilion Notebook
HP Pavilion dv6000z Notebook Logo
1,533 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
