Question about OEM Systems Car Audio & Video
No power getting to my radio i am in the middle of putting in a new radio and there is no power getting threw the harness
    Novelist:
  • 110 Answers
What type of vehicle do you have? check the fuses in the box or box's. what type of radio are you installing and are you using the aftermarket wire harness that plugs directly into the factory chassis harness? sorry about all the questions but this will really help me solve your issue. thank you and let me know
Posted on Mar 04, 2009
It's a 95 ford explorer and we bought a wiring harness for the new radio, the old radio worked fine and everything. We hooked up the new radio to the wiring harness and it powered on and everything, b
try hooking the radio power wires to the battery! To '' TEST'' twist red and yellow put on the poss. blk. on neg. ! take a speaker and test speaker wire out put! if don't work output is blown out! but will still work with rca jacks hook to small amp ! this to pull sound out of your radio for sure!!
Dec 27, 2012 | Cars & Trucks
My daughter has a 98 olds 88 i removed the stock stereo and put in a pioneer cd player but i didnt see any wire on the stereo side for the elec. antenna i was wondering how i can wire it to work
Most aftermarket pioneer cd/radio decks have the electrical connector for the antenna that I've seen.
Is this a cd only deck, or does it have radio functions?
Did you use a new harness wiring adapter to get the pioneer radio to work with the old harness?
There should be a color coded set of wires for the power antenna on that. And, then the Pioneer radio should have wires that were labeled for the power antenna.
Oct 08, 2010 | 1998 Oldsmobile 88
My factory radio went out in my car...so i had a new one put it in. After the guy installed the radio we noticed that my park lights and dash lights werent working. We checked the fuses and they were all...
I really hope that this guy bought a wiring kit to put in the aftermarket radio, because this could be simple. Your stock radio runs the dash and parking lights threw it's display and that needs to be looped with the new radio. On the aftermarket, there is a orange wire that does this. Since the stock wiring is different with every make and model of auto out there, you need to buy the wiring kit that plugs into the car's harness and matches in color to the harness of the new radio. Putting together the orange wires will give you back your lights. If this person cut the orginal plugs off of the car and wired it direct to the car, you may want to see if the plugs can be put back on and the wiring kit installed or you going to be going through a nightmare of figuring out what wire is what on the car side. Those wiring kits that plug into the car and wire up to the radio are cheap and can be bought at Wal Mart for about 20 to 25 dollars. Good luck
Aug 09, 2009 | 1999 Honda Accord
Up grade 1988 camry radio
Yes, you can.  This is a standard "DIN" opening.  Width and height are specified; but not depth.  The plastic empty space tray immediately below the radio - actually make this a "2 Din space"
If you are electrically savy - carefully remove the black trim bezel (two hidden fasteners in the middle section and a couple at the bottom; and a hidden white plastic tab buried way in the back at the bottom - need a long screwdriver to release - accessed only after removing the ash-tray...
I am not aware of any pre-existing wire harness adapter...
Electrically savy - get the above out -  and then measure the available depth.  You can get several molex connectors from Radio Shack, and cut the current wires - and put connectors on them - so that you can reconnect the original factory radio easily.  Unplug those, and make molex fittings going to the wiring for your new radio connecting to the molex you put on the factory wiring.
I'm currently looking at putting in a satellite navigation radio with screen, dvd player, etc. into my 1988 Camry which I've owned since new.  Only new car we ever bought....  Good luck.
Mar 28, 2009 | 1988 Toyota Camry
My radio wont turn on
Use a voltmeter or a circuit tester. 2-5 bucks anywhere worldwide.
Test the power wire from the radios wire harness for power.
If It shows power then you fried your radio.
If It shows no power from the Harness. Hopefully you just cooked the radio harness. Splice the power wire off of the radio harness and test It for power cross your fingers thats as deep as you have to go Into electrical system.
Test the radio power wire that goes to your radios harness for electric current.
When you find the power the garbage will present Itself.
Before any of the above check all of your fuses.
One thing Is for sure you def blew something.
Good Luck
Mar 22, 2009 | 1996 Ford Explorer
Radio won't work
With your new radio harness hooked up do you have power on the orange or yellow wire all the time and power on the red with the key on?
Mar 21, 2009 | 1996 Dodge Intrepid
How to turn radio on
the only way to listen to the radio is to click the middle button with a key on it then unlock it and put in on manual then u HAVE to plug in your headphones tolisten to the radio. by the way can u help where to download free games for the same mp4? thanks have a great day
Feb 23, 2009 | Digital Mind Corporation iQ Sound...
Problems with car audio
you should plug in the new harness and meter the wires to make sure there is power on two of the wires one will always be powered for memory the other should be powered when ignition is on if both test ok then check the in line fuse links on the radio wire harness I hope this helps good luck....
Jan 10, 2009 | Sony Xplod CD Player w/MP3 Playback...
Car Audio & Video Logo
37 people viewed this question
Top OEM Systems Car Audio & Video Experts
xxxxxx xxx
miles
miles
SuperN0va
SuperN0va
Are you an OEM Systems Car Audio and Video Expert? Answer questions, earn points and help others
