Samsung Transform Ultra Logo
A
Anonymous Posted on Mar 30, 2013
How to change font on samsung transform ultra
Icons, print, etc too small
3 Related Answers
Anonymous
  • Posted on Nov 14, 2008
SOURCE: how can i change my font size back to large on recived msgs on a samsung f480?
When viewing the message, use the volume button to increase or decrease as required!
Anonymous
  • 23 Answers
  • Posted on May 23, 2009
SOURCE: Can I enlarge the text message font on a samsung X820?
before you start typing, go to options -> and something like 'text style' ?
while you can't change the font, you can type with text that has been struckthrough, underlined, bold, italics, and you can also select 3 text sizes.
hope this helps.
Anonymous
  • Posted on Jan 09, 2011
SOURCE: samsung s5620 msg font size how to small
You have to open a message in your inbox and use the volume key to make it smaller or larger. Hope this helped you.
1helpful
How do I get larger print size on label. Print starts half way down. Change font size but just jumps back to 12. Looks huge on computer but small when I print, thank you. Eileen
Click the Settings icon , click Print, then select a larger printout size in the Scale setting. ... Change font size: Click the Settings icon , click Options,
4helpful
Samsung transform ultra "charging" while not on charger
I had the same problem and eventually my phone just wouldn't charge at all. I took an old tooth brush n was cleanin the charging port with it then id blow it out n repeat and honestly after bout a half hour of doing this it is now finally charging.
1helpful
Hi i have a samsung preston icon and my text message writeing is small how do i make it bigger
Go to Settings > Display and Light > Font Type, you should be able to change the size, colour and font here...
1helpful
I have a photosmart 4650...when I print from a web page, the print is so small I cant read it. How do I change the font size?
Best Answer -
That entirely depends on what you are printing. A printerwill only produce what it is given.
If you are printing your own document then you change the font in the documentbefore printing or select the font before you start.
However I suspect the reason you are asking this is because you are printing apdf document from the internet. In which case the font is fixed.
If so, then you will have to copy and paste the document in to a word processorlike Word, highlight it all and the increase the font. You will then have toreformat the whole document as the increased font will throw the orginalformatting all out of line.
When you have straightened it all up then print it off.
ALTERNATIVELY, if you are printing on ordinary web page then you need to follow the below instruction
Instructions
1. 1 Go to theweb page that you want to print and right-click it. Click "PrintPreview." If you want to print part of the page, highlight the contentthat you want to print and right-click the selection. Click "PrintPreview." 2. 2 Click the "Page Setup" icon located onthe top of the Print Preview window to launch the Page Setup dialog box. Click"Change Font." 3. 3 Select the font you want to use in the"Size" window. If you want to change the font type, make yourselection in the "Font" window. Click "OK" to save thechanges and click "OK" again. 4. 4 Turn on your printer if it is not on. Click the"Print" icon on the Print Preview window to print your web page.
I HAVE A 19' MONITOR FROM SAMSUNG
If the fonts are too small ..just see the resolution maybe is too high and thats why ..being a 19' monitor you should use it at 1024 x 768 resolution to be accesible with big fonts ..and still not too big..and the luminosity and contrast have to be adjusted from the monitor itself in order not to affect all the stuff you get out from the computer ...when you Modify it from the video card you change all that will run on the computer and all its properties..
So ..if it is not a issue with the resolution ...just encrease the font size from right click on the desktop and choose properties..there on the appearance you will have settings for all...just go to the advance settings inside..and you can modify the font for each bar ..for the icons..and the icons itself ans still use a high resolution ..
also you can change all fonts to a bigger value by going into the desktop properties and instead of going to the appearance go to settings ..(the last one in the right ) and there click advanced and change the DPI from 96 normal ...choose custom ..and add a percentage to encrease the fonts and icons as well all at once and the fonts too ...
For the fonts use on the browser the settings are made from the internet options ..in the browser itself..
70helpful
2answers
Tocco Lite - received text messages font size to small
When you're reading the text, use the volume button on the left of the phone to increase or decrease the font size.
17helpful
2answers
Samsung tocco, the font in the text too small how do i enlarge it
i think you can increase the font size when messaging by pressing the volume.goodlock
My Garmap wont work on my Vodafone S8300V. Garmap has told me to take my phone to Samsung for testing. Should this not be for Vodacom to do as I have just signed a two year contract
Hi Can you please help me to change my cellphone's font.When I received a message the font is very small.How do I get it bigger.Please Help. Thank you so much.Greetings Andri.
[email protected]
2answers
Print out is too small
To resolve this, try the following actions:
* Check the default fonts within Microsoft Windows.
* Select your entire document and set it to a larger font.
* Make sure all your fonts are loaded properly.
* Change the resolution to quick print at 600 dpi. To do so:
1. Click Start, Settings, Printers.
2. Right click the Lexmark printer icon and choose Properties.
3. Choose the Document/Quality tab and set the resolution to 600 dpi quick print/draft.
* Change the Spool Data Format to RAW. To do this:
3. Select the Details tab and click Spool Settings.
4. In the Spool Settings screen, set the Spool Data Format to RAW.
5. Click OK and then Apply.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
