Question about Canon PIXMA MP470 All-in-One Printer
Installed new ink & it says "Print head is not installed" -
I just purchased ink for my Canon Printer MP470 and I got the #40 black and #41 Color, which is what it said to use - but when I installed them, the printer keeps saying "print head is not installed - install the print head". I have removed them and re installed them but it still says that. Can you help me? The printer is new.
  • Anonymous Mar 14, 2014
    what do i do
  • 685 Answers
Try to unplug it and plug it back in
Posted on Mar 04, 2009
Does the canon pixma ip1200 need both the black and the colour cartridges in to print ?
You need both cartridges. It is a paradox that you need both cartridges to even scan on the mfp,s
May 10, 2014 | Canon PIXMA iP1200 Photo Printer
How do you print a document using color ink? I am out of black ink.
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with black ink missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with black ink missing even if you aren't using it. That's the case with your Canon printer.
If you allow a color to go empty, the residual ink in the head could clog and become permanently blocked. You would never be able to print that color again. So always replace ink cartridges as soon as they are empty.
Jan 05, 2011 | Canon PIXMA MP160 All-In-One InkJet...
Black color will not print. Installed a new black
Ink is a lubricant for the print heads. Some color ink is used even if you only print in black or vice-versa. If you printed with a color missing, you could destroy that print head from the friction of running without ink to lubricate it. That's why most printers won't allow you to print with a color missing even if you aren't using it.
Leaving your printer on takes very little power. Every so often the printer sends a signal to cycle the ink in the heads so it doesn't clog. If you turn your printer off, the next time you turn it on it will do a cleaning which wastes a lot of ink. The excess ink is soaked up by the waste pad beneath the printer. When the waste pad is full, the printer stops working. Unless you want to spend more than the cost of the printer or waste a lot of time on a messy cleanup you will end up throwing the printer out. So shutting it off actually shortens its life.
If you leave the printer off for extended periods of time, the ink in the heads will clog and you will have to throw the printer away. Someone I know with a Canon (though this can happen with any inkjet) had to have the heads replaced twice within the first few months before the Canon tech told her to stop turning it off. Since then it has worked perfectly for over a year.
How to clear blocked print heads:
-leave the printer on for a day
-run several head cleanings and print the nozzle check pattern
-if that doesn't fix it, remove the cartridge(s) from the blocked head and drop alcohol where the ink enters the printer.
-reinsert the cartridges
-run one head cleaning
-wait about an hour then run some head cleanings.
-dip the print heads in Isopropyl Alcohol overnight, which you can buy from chemist
-if that still doesn't work, your heads may be clogged to the point where they need repair or replacement, which will probably cost more than a new printer.
Dec 06, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I put blue ink in a black cartridge and from then
Hi, you shouldn't have done that, because the color cartridge and black cartridge are not of the same make, what you need to do now is to change the cartridge, get a new cartridge to replace to troubleshoot,let see if it will print.
Compliments and wish you best of luck.
Jan 02, 2010 | Canon PIXMA iP1600 Printer
Can't load printer ink cartridges...
Are you using the right cartridges? They should be:
  • PG-40 BLACK (Black Ink Tank)
  • CL-41 Color (Color Ink Tank)
Also check this CANON FAQ:
How do I install the ink cartridge(s)?
Sep 07, 2009 | Canon PIXMA MP190 All-In-One InkJet...
HAving trouble printing
Check and make sure you did buy the right one first.
Apr 23, 2009 | Canon PIXMA MX310 All-In-One Printer
Do I have to install a color cartirdge (CL-41)?
Some will allow printing with just black & others will not. You may need to put a color cartridge in to print. Check your owners manual or canon website to make sure but if you do need a color cartridge you can buy a generic brand that works with your printer to save some $$. Hope this helps.
Feb 18, 2009 | Canon PIXMA MP160 All-In-One InkJet...
CANON S9000 won't print in black
Here's what just fixed mine... I was having the same issue...
Mac:
Go to System Preferences
Open Print & Fax
Select your printer and open Print Queue
Click Utility
Select your printer & click Maintenance
Select the "Deep Cleaning"
That worked for my black ink!
Aug 09, 2008 | Office Equipment & Supplies
Canon printer mp160 error msg 16 (e16) after replace catridge
try this PRESS STOP BUTTON FOR 5 SEC CAN FIX THIS PROBLEM
after that will adicated light alarm blinking them you can print if can't try turn off printer and turn on again.
Apr 17, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Balck ink not working
The printing head have some dryed black ink inside.
Look at Canon i550 section in this website. I have posted several answers on how to clean the print head.
Feb 09, 2008 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA MP470 All-in-One Printer Logo
740 people viewed this question
old marine
old marine
