Question about Dell W4201C 42 in. Plasma HDTV
I have a Dell TV and the screen has a green tint. I dont have a remote and ive tried to a adjust the colors from the tv but i cant find a way to fix it.
  • kenn green May 11, 2010
    try a factory reset. hit the menu button, go to setup, factory reset passcode 3355. then see what happens.
    New Friend:
  • 90 Answers
You need to get a remote. order one from ebay there about $20 do a factory reset, and use code 3355. this will reset the unit back to original specs. if no go, use the rem to manually adj the color to ur satisfaction.
Posted on Apr 13, 2009
3 Suggested Answers
  • 304 Answers
SOURCE: whole tv has changed to be a very green tint. even
Go to the back of the tv and make sure all of the Component plugs are fully inserted and also on the source Ie: Cable Box or Sat Box,DVD Player.
Posted on Jul 18, 2009
  • 108 Answers
SOURCE: The TV works fine but the screen is green. Color
LCD television sets dos'nt have crt's, but ofcourses out of the RGB circuitry, R & B circuitry is'nt working or its not receiving the proper signals, that's the reason you see only green color,
If you are feeding the signal thru DMI/RGB cable from your set-top box, check for cable loose contact, cable wear-out, if you are feeding the signal thru coaxial cable its problem within the TV's circuitry.
Posted on Jul 29, 2010
I own a Quasar SP-3235 32" TV. It has a slight green tint after 10 years of use. How can I adjust the color screens on this set? Is it a function of the remote like Sony TVs or do I need to remove
I would open it first and look, a lot of those had both the screen and drive controls on the PCB at the end of the picture tube, at least look there first.
You are dead on in looking for the screen controls, if you find one it should only be a tiny adjustment due to age and the Crt changing a bit.
Dec 13, 2012 | Quasar SP-3235 32" TV
My Philips magnavox 64 inch big screen tv has a green tint to it and i cant adjust with any of the color or tint options..
have the glycol ethelyne changed in your color guns, couple hundred bucks. i tried it myself and ruined my tv
Mar 27, 2010 | Philips Magnavox 9P6034C 60" Rear...
Magenta Color
Here is something that may help from the toshiba.com website under your model number television. Q. Why are people on my screen green?
Models: 32HL17, 37HL17, 42HL17, 42HL167, 47HL167, 52HL167, 42HL167, 42LX177, 46LX177, 52LX177, 57LX177
REF:FAQLCD00107
If the problem is not the connections, try adjusting the tint on your television. A high tint setting will usually create a green
image on the screen where as a low tint will create a more red hue. In order to access your television's tint:
1. Press the “MENU” button on your remote control and use the LEFT or RIGHT arrow keys and select the
VIDEO menu.
2. Then use the UP and DOWN arrow keys to highlight PICTURE SETTINGS and press the "ENTER" button on
your remote.
3. Next use the UP and DOWN arrow keys to highlight TINT then use the LEFT or RIGHT arrow keys to adjust the
TINT. If the picture is too green the tint will need to be lowered.
4. Once you have adjusted the tint to your liking, use the DOWN arrow key to highlight DONE and press ENTER. The toshiba customer service telephone number is : 1-800-631-3811. I hope this helps you with your problem.
Feb 01, 2009 | Toshiba 42HL167 42 in. LCD Television
Green Tint On Xbox Monopoly Game
have you tested with another game?
maybe you are running a EURO game...the colors go crazy....it´s normal...try a usa version...
Dec 05, 2008 | Microsoft Xbox 360 Console
Samsung txh1970 tv screen has green tint
I encountered the same problem with a color computer monitor several years ago. Everything went green. The repair techies told me that's a sign that the power supply is going bad. You will not be able to adjust the color. You will have to either fix it or replace it. Hope this isn't a common problem with this model Samsung TV.
Dec 01, 2008 | Samsung TXH1970 TV
Red tint on screen
Good Day,
Try resetting the TV by unplugging from wall outlet for 3 to5 minutes then plug back in. If no fixya take front grill off and panel and adjust the screen controls, turn color off adjust for Black & White Picture. Good Luck, big IRISH.
Sep 13, 2008 | Hitachi 53UWX10B 53" Rear Projection...
42 inch hitachi projection tv. green tint told it might be color wheel
sounds like your picture color tube may have went if the tv can not be adjusted with the remote or on the tv itself did you try every color or picture button on the remote and the tv itseff and if it is old i would get a new one if not have it fixed , sincerely john
Aug 01, 2008 | Televison & Video
Green tint I can't seem to fix
Hopefully someone on here has a manual and can tell you exactly where the tint controls are. Also need to try adjusting the color level, turn it clear down so you have a black and white picture.
Is the picture still green over the screen with the color control
set clear down to black and white? If it does, you might
have an issue with the green gun going out or problem in the
circuitry to it.
By the way, the best way to adjust the picture settings on a
tv are to first turn the color control clear down, then adjust
brightness and contrast for best black and white picture, then
bring up the color level to where it should be and adjust the
tint for best red/green ratio.
May 20, 2008 | Mitsubishi CS-27205 TV
Picture has green tint
use menu on remote adjust tint to center
Mar 23, 2008 | Philips 9P5034C 50" Rear Projection...
Cant locate or adjust the the TV color
All the controls should be accesed thru the on screen menu,your remote should have a menu or display button and if you press it on the screen of the tv you should see a list of different options ,I am not familiar with the kind of menu that your set has but I know the color adjustment should be in the same screen that allows you to change the brightness,shapness,tint,color and contrast,the more you use the menu and become familiar with it the easiest it will be to use.Let us know if you need more information.
Nov 06, 2006 | Sony KV-32S26 32" TV
Dell W4201C 42 in. Plasma HDTV Logo
178 people viewed this question
Top Dell Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
CoppellTVRepair.com
Are you a Dell Televison and Video Expert? Answer questions, earn points and help others
