I'm replacing my mother board in a Averatec 6200 series Laptop. But, I forgot where the Black and Grey Wires from the Monitor connect to the mother board. So. I'm trying to get that info.. via a schematic or photo. If you can Help that would be great as I'm so far, out of luck finding any info. on the subject. The mother Board is a Model MS-10041 Ver. 1 with an AMD Processor.
Probably these wire nowhere connected if you have no wireless lan adapter. Usually these two wires join to built-in antenna in screen.
Can you post some foto or picture of your connector on the wire in to this forum. If you have wireless lan you must to connect build antenna in screen on to wireless lan controller (your controller may be build on the moterboard or be connected wia micro-PCI slot)
What type join on the end of the wire?
These two wires go together or separately one from the other?
like this ?
I have a wireless lan. The question was where do the grey and black wires from the monitor go on the mother board. I don't know how else to describe the problem I'm dealing with than that. Thanks For Trying but can you be a little more forthcoming with a solution. Thank You!!!
The ends are like the battery charger type that have a single post inside and are very small (ie.. approx. 1/16th of an inch). They are gold in color and connect seperately on the board but, I do remember they were approx. 1 inch apart somewhere near the middle of the board. I just can't find where. I assumed there would be a hollow post on the board but If there is I can't find it. I just can't believe I made a rookie mistake like this. Thanks For the help so far.
