Question about Roper RAS8244KQ Top Load Washer
Roper RAS7233KQ0 NO SPIN
Hi I have a roper RAS7233KQ0 TOP LOAD Masher and all of a suden it started make a noise and it not spining it is trying but it like the breks are hung up and all it does is a really slow motion move
Hi I have a roper RAS7233KQ0 washer and all of a sudden it started make a noise and is not spinning. The agitator is trying to move but makes a grinding sound and is a really slow to move and there is only a grinding noise when in the spin cycle.
I don't think it;s the electrovalves because the washers fills and drains normally and I dont think it has a hyperstatic hose, it has normal hot fill, cold fill and drain hoses, but nothing hyper-static and the load size is specified on the controlled panel. This problem appers to be with the drive motor.
Posted on Jun 27, 2010
Chek the water elctrovalvles and replace it , this most be 1 solution another will the hyperstatic hose or sensor of load size
Posted on Mar 06, 2010
Washer wont spin or agitate. it does drain. will spin if you help it by spining it an quick close the door.
Check lid switch.
If that is not it then its probably the trans coupling
Go here for instructions.
Good luck
http://www.applianceaid.com/procedures.html
Please vote for me if this was helpful
Leo Ponder
imufo2
Aug 15, 2011 | Roper RAS6233KQ Top Load Washer
Tub will not spin on spin cycle makes grinding noise when it tries to spin motor is trying to spin it
could be broken motor coupling. after checking and this is ok go on and check brake wich is on top of transmission.
Oct 10, 2009 | Roper RAS6233KQ Top Load Washer
My roper top load washing machine will not spin.
Hi There,
You need a new timer. Hope this helps and thank you for using FixYa!
Mar 28, 2009 | Roper RAS8445KQ Top Load Washer
I have a top load Roper washer that won't spin.Any ideas?
That sounds like a bad drum bearing, check and eventually replace the drum bearing.
Dec 28, 2008 | Roper RAS8445KQ Top Load Washer
Washer makes loud knocking noise
I think that the drum bearings have gone on the machine..
To open the door and spin the empty drum quickly by hand and you should hear the noise or say a less amplifed one.. You can also move the inner drum up and down to see if there is something wrong with it..
Sep 28, 2008 | Roper RAS6233KQ Top Load Washer
Whining on spin cycle
There could be something in the pump .If you can tip the machine back and remove the belt try to spin the pump pulley by hand if you hear the noise that's it if not call for service.
Jun 25, 2008 | Roper RAB2121KW Top Load Washer
Roper RAS8244KQ Top Load Washer Logo
404 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
