Question about BUSlink MUSICA MP3-PBD128 128 MB MP3 Player
Downloading buslink mp3player with flash drive
Ops windows xp on new comp. cant download any thing i think i fallowed directions ?????nothing working
0 characters
1 Points
Coby MP-200 wont register on windows xp
This is a flash device and it comes with a USB extension cable, try not using the extension cable and plugging the unit directly into one of the REAR usb ports on your computer. This should make the device show up as a 'Removable Disk' drive under 'My Computer'.
Aug 14, 2008 | Coby MP-C883 MP3 Player
Computer still won't recognize the files Sansa c250
go to my computer > click on hardware tab >
click on device manager button > in the is next screen on the bottom should have>>universal serial bus controllers
(write these down just in case it cant find them)
right click on them and uninstall
reboot let windows reinstall them
Also told Microsoft hotfix causes this problem try uninstalling the last hotfix
If that doesn't fix it try the USB cable
Feb 11, 2008 | SanDisk Sansa E280 MP3 Player
Downloading music onto a mp3player
I think I fugured it out. I think this should set the thing up for you. Turn the unit on. Push the button in and hold for the count of three. Wait as you count to two then push the buton in quickly. The screen should display a different "MUSIC" sign. Now the tiny file type in the upper left of the screen should say "mp3". Now make sure you are loading mp3 files. Be sure the unit is ON when you connect it to the USB port. Drag and drop files onto the mp3 player. I got it to accept 5 songs so far. I am working with Windows xp. Hope it helped!
Dec 25, 2007 | Nextar MA933A MP3 Player
Can't download songs
J Garcia
hi guys, i had the same problem and the solution is simple. we are all upgrading and what we should do is downgrade. the specifications say that it works with XP but it might not work in most instantces as i can see. the solution is runninng windows 2000 it picks it up as a flash drive and u only dump ur files in the music folder. to charge the player it has to be in a windows 2000 operating system.
take care hope it helped me
Dec 17, 2007 | SanDisk Sansa Clip MP3 Player
Delstar 1036 problem
The CD contains drivers for Win 88 and ME not for XP. The manual is for those who have Chinese as their first language and want to learn bad English :) . Seriously though, on XP all you need to do is insert the player into a USB port, using the supplied cable if you wish or directly. Double click on "My Computer" which should show all of your drives including the MP3player. Double click on it to open it in a new window. Now you can drag music files (MP3, WMA, etc) into this window in order to load them into the player. When you are done make sure safely remove the player by clicking on the little green arrow in the lower right side of the screen and clicking on safely remove the device.
Dec 03, 2007 | Delstar DS 31024 MP3 Player
Plug the MP3 player into your computer. It works just like a flash drive. Visit "My Computer". You should have a new drive letter in there, sometimes labeled as Removable Disk. All you need to do now is just to transfer your MP3 files into this drive by drag-n-drop or cut-n-paste, just like transferring files from one folder to another. Think of it as a flash drive or floppy disk. Same concept.
Mar 12, 2007 | BUSlink MUSICA MP3-PBD128 128 MB MP3...
How do i download music to my bean?
cuando le voy a pasar la musica, y desconecto el walkman bean sale en la pantalla not invalide como ago para solucionar el problema
Aug 26, 2006 | Sony Walkman Bean NW-E307 MP3 Player
My BUSlink MP3 player is flashing "Hello"
Have you checked the battery voltage? make sure its in the original capacity. Go to Control panel>Performance and maintenance> System> Hardware> Device manager> Universal Serial Bus Controller, click on the + sign to see the list of installed devices. If your player is connected, it should be listed there with a yellow flag (the yellow flag indicates that although the connection is there, it is not working properly). Right click on it>Properties>Troubleshoot. See if the troubleshooter can help. And you can format it there.
Jun 19, 2006 | BUSlink MP3-SK512 (512 MB) MP3 Player
MP3 & Digital Media Players Logo
19 people viewed this question
Top BUSlink MP3 & Digital Media Players Experts
Gyula Lacz
Are you a BUSlink MP3 and Digital Media Player Expert? Answer questions, earn points and help others
