Question about Motorola Cell Phones
Is there a way disable smart key on the outside of the motorola razr v9m phone? Settings change from Vibrate to Silent often so I miss my calls
    Problem Solver:
  • 14 Answers
Try to find "personalize" setting of some kind, and then change the smart key to perform something else, so it doesn't go set silent mode. I am not familiar with your phone, but on RAZR v3 smart key activates camera. However you can change it to do something else. The steps would be different for your phone I assume, but if you need an example of the general steps, there are videos on www.HandBookLive.com under Electronics category on Motorola RAZR v3 and there is a chapter on "Chaging Shortcuts"
Hope it gives you some ideas
Posted on Mar 06, 2009
My iphne 3 will only vibrate but not ring
If you're missing incoming phone calls due to your iPhone not ringing, you may have accidentally switched the ringer to vibrate or silent, according to Apple. The switch on the left side of the iPhone turns off the ringer and usually sets your phone to vibrate mode, but if your iPhone's vibrate setting is also disabled the phone will instead be set to silent mode. When in the phone's sound settings vibrate mode can be enabled, and the ringer volume of your phone is adjustable.
Read more: My iPhone Will Not Ring ' eHow.com http://www.ehow.com/how_7384812_iphone-not-ring.html#ixzz22OJOMZGR
Aug 02, 2012 | Apple iPhone 3G
I have a motorola razr v3 that i hear fine out of but others cant hear me
You will have to get your cellphone repaired that is the only solution to fix this problem.IF it is under warranty then please get it replaced.
You can try taking the phone apart if you want and clean and reattached the connections to the speaker in the phone.
Good luck,
Please don't forget to rate the solution.
Mar 30, 2008 | Motorola Mobility RAZR V3
I have the ring tone set to vibrate & the phone does not vibrate. this just recently happened. Use to work fine before.
The vibe motor is inside the phone and can be replaced at a service center. Hopefully the unit has no physical or liquid damage.
Mar 24, 2011 | Motorola Mobility RAZR V3
Change Ringtone Automatically when charging
The BlackBerry gives few profiles to choose from; e.g. Normal, Loud, Quiet, Vibrate.... my recommendation would be to configure each profile separately and just enable/disable the profile you like when you enter/exit your car...
The phone itself is not capable to switching the profile on its own once it is plugged in to your car charger...
Hope this was helpful...
Nov 10, 2009 | RIM BlackBerry Curve 8310 Smartphone
How do i turn my phone to silent mode?
To place the handset in Silent / Vibrate Mode
Step 1
To place the handset in Silent / Vibrate Only Mode, hold down the pound key (#) for about 2 seconds. To exit Silent / Vibrate Mode, perform the same action while in Silent / Vibrate Only Mode. You will see a confirmation message for Silent / Vibrate Only Mode, each time you enter or exit Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent Vibrate Only Mode.
Step 2
While in standby mode, press the volume key, located on the left side of the handset, then select either “Vibrate Only", “Alarm Only” or “All Sounds Off”. To disable perform the same action while in Silent / Vibrate Mode.
The SCH-U470 (Juke) handset will vibrate rather than ring when you receive a phone call, message or alert while in Silent / Vibrate Only Mode.
Jun 08, 2009 | Samsung SCH-U470 Juke Cellular Phone
Need to set razr phone to mute. How??
On the side you have a up and down keys open the phone, and keep pushing the down key on the side of the phone. this is where you adjust the ringer but alos puts it in vibrate, or silent mode
Jan 26, 2009 | Verizon Communications Motorola MOTORAZR2...
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Bluetooth does not ring for certain calls
have u checked ur settings of the blue tooth I think the settings might be off and I request you to switch it on and try once again
Jul 14, 2008 | Motorola Mobility RAZR V3
Motorola Razr 3a cell phone
menu,media,ringtones, and now change the miss call alert to silent
Ringer turns off when I don't want it to!
To the best of my knowledge there is no way to disable the feature...Sorry...
Oct 11, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
234 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
