Question about HP Compaq nc6000 Notebook
I have a compaq nc6000 just got it today. I cannot access my wireless router at home or at work. I have a second (older nc6000 that I am using now that is fine -connects at home and at work. What do I need to do? Thank you for any help you can give me.
  • gela51 Mar 04, 2009
    The router is fine. I tried to set up the connection and it would not connect.
  • 173 Answers
In the Control Panel, Click Wireless Network Setup Wizard, just click next, next, CLICK setup up a new wireless network: TYPE your NETWORK NAME (SSID):******* CLICK Automatically assign a network key. next just FINISH.
Posted on Mar 04, 2009
  • 44 Answers
Hi!
Make sure the internal wireless card is turned on! Then try refreshing available networks. Good luck, I hope this is helpful!!
  • 423 Answers
It may sound too simple, but most laptops have a manual switch that turns the nic card on and off. It saves battery power. It's on the outside of your laptop somewhere, usually on the front. Check see if you didn't just overlook that.
Rob
  • HP Master
  • 6,487 Answers
If this computer is running Vista , right click the computer icon on the bottom right hand and select Open network and sharing center and then click on Manage wireless network and remove if there's any network listed there tne click OK and close all the window, Now right click the computer icon and select connect to a network and select your wireless network and click on connect..
if this is XP, right click the wireless icon on teh bottom right hand select View available wireelss network and then click on change the Order of prefered networks and then remove all network listed there , cick OK and close everything.. Now right click the wireless icon and select View available wireless network and select your network and click on connect....
  • 744 Answers
  • Prakash Ram
    Prakash Ram Mar 04, 2009
    hii
    For the wireless settings;
    1. Make sure your machine is set to obtain an IP and DNS settings
    automatically and;
    2. Your wireless key is appropriately set with the key you configured
    in the router. (depending on your ISP, your wireless key may also be
    printed on the bottom of the router)
    Under "Under network & sharing center", click "Manage Wireless
    Network", and configure the wireless settings (including the wireless
    authentication method and key) that is appropriate for your router...
    thank u!!
  • HP Master
  • 19,396 Answers
Ensure that you have a wireless adapter installed.
    Brigadier General:
  • 8,619 Answers
Hi
Which OS(vista/xp) are you using?What is the make and model of your router? Have you setup the connection between your new compaq and the router by going into wireless settings in control panel.
  • Rylee Smith
    Rylee Smith Mar 04, 2009
    Try using a static ip on it. Look at the mac address used on the router, is it binded to a single mac address(you can see this in the settings of your router)
    After you have checked this, go to WiFi(wireless) networks option in your control panel and click on "Configure" and you will be able to see your network's SSID in the "Available Networks."
    Now enter your network's SSID and WEP key. And, now click on "Start," then choose "Connect To" and "Wireless Network Connection."
    Your computer should now be able to access the WiFi network if the WiFi network is connected to the Internet.
    Please ask for further clarifications.
    Thanks
    Rylee
Compaq nc6000 wifi connection very unstable
There are a few things that can cause you to lose wireless connection with your wireless router. 1. Weak signal strength, check the signal strength on your wireless card. If it is weak move the wireless router away from brick or concrete walls and if possible locate the wireless router higher up. 2. Have you secured your wireless router from people near your from unauthorized access? i.e. change the default password, setup encryption use WPA2 or WPA, change the default SSID, and turn off SSID broadcast, and for added protection, enable MAC address filtering which allows only the MAC address/es of your wireless card/s to connect to your wireless router. 3. You could be getting interference from electrical sources such as air conditioners, arc welders, washing machines etc. If so, the power supply to the wireless routers and computers etc should be connected to a surge protection power board, better still connect your computer equipment to an UPS (Uninterrupted Power Supply). 4. Check the channels of the wireless routers and access points in your area and change the broadcast channel on your wireless router to an unused channel or one that is currently used but has the weakest signal strength. This will minimize interference with your wireless router from other wireless routers and access points in your area.
Dec 07, 2012 | HP Compaq nc6000 Notebook
Wireless connection problems
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Apr 19, 2012 | HP Compaq nc6000 Notebook
How do I activate the wireless connection on a compaq nc6000 if the quick launce button doesn't work?
hi, first you have to switch on the wireless on the compaq with the switch located on the side panel of by using function keys.Let me know
Dec 25, 2010 | Computers & Internet
How do I get the internet on this laptop? I have a wireless router at my home and am not connecting. It is saying network cable unplugged.
Look like you had Win XP.Go to services and look for Wireless Zero Comm. and select START.
If you need more help come back.Post / thumbs / testimonial are welcome!
Nov 28, 2010 | HP Compaq nc6000 Notebook
Hey can anyone help me, my Compaq nc6000 won't connect to wireless networks it says something about a smart card.
Access the router by means of an ethernet cable and log into the router. Go into the wireless setting of the router and select WPA-AES as the security protocol and select a password. Then go into your wireless settings on the notebook and do the same.
Mar 06, 2010 | HP Compaq nc6000 Notebook
Compaq NC 6000 on XP SP3 - Ethernet Drivers & Wireless Drivers
Limited connectivity means your pc not able to connect to the preffered network.................
wi-fi also not working....................
there is a problem with your router not from pc.
Apr 05, 2009 | HP Compaq nc6000 Notebook
Compaq nc6000 laptop wireless connection
Wireless connection? If so, make sure the wireless device is enabled on the newer one. If it's a red light, the wireless device may be faulty. If so, just get an external USB wireless device and use that. Check to see that the same lights are on with both PCs.
Mar 04, 2009 | HP Compaq nc6000 Notebook
My neighbor's signal
If your neighbors know that your using their router, you might ask them to reset it. If they moved it, this could cause the weakening of the signal, walls drastically decrease a wireless signal. You might also refresh your wireless card by uninstalling the wireless drivers and reinstalling them.
Aug 05, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
27 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
