Question about Kodak EASYSHARE 5100 All-In-One Printer
The paper is not feeding into the printer straight. And sometimes jams. The paper jamed when I tried to print onthe back side of a sheet of paper.
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 17 Answers
If its an inkjet printer then please mark that the catridges are able to free scroll on the carraige and if they fail then remove the catridges take a clean piece of cotton clean the foil which connects the catridge to the circuit , this worked for my HP 3940,
Posted on Mar 04, 2009
Printer jams when duplexing
Most printer jambs are caused by a couple of things. Have you tried different paper? Sometimes paper that is curled, or if the humidity is too low, the paper will hold a static charge and cause paper feed problems. The other is worn or dirty feed rollers, try cleaning the feed rollers with isopropyl (rubbing) alcohol.
Nov 02, 2014 | Canon Imageclass D420 All-in-one Laser...
The paper jams coming out of the tray in the first set of feed dogs. Sometimes if i am printing more that one page the first sheet jame in the final set of feed dogs. I have to open back and pull sheet...
clean all the paths of the paper. maybe there are some paths are causing the jam. check also all gears on the path. check also the separator pad if it is worn out.
Jul 02, 2010 | Office Equipment & Supplies
Paper feed catches on right side
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this, is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 21, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Paper jam
Jan 10, 2009 | Brother Multi-Function Center MFC-240C...
Jamming paper
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Dec 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
Paper is jamed
I have a HP697c and sometimes it grabs more than one sheet and gets jammed. I take hold of the trailing edge and pull hard and slowly till it comes back out. Then I remove and straighten the feed pile and try again.
Nov 07, 2008 | HP DeskJet 920c InkJet Printer
Hp psc 1315 paper jam
. Switch off the printer and disconnect the power supply. Allow any residual charge inside the all-in-one printer to dissipate before putting your hands or any metal tools inside the chassis.
2.
Pin down the exact location of the jam. The 3 hot spots for a jam are before a sheet completely leaves the paper tray, anywhere between the feed tray and print carriage or between the print carriage and output tray.
3.
Take off the front paper tray if the sheet jammed while still in the front area of the printer. If here, you should be able to see most of the paper.
4.
Pull the sheet with both hands and steady pressure. Do not tug as you might rip the paper, leaving a piece deeper inside the machine.
5.
Open the back panel to reach paper jammed between the feed-tray area and print carriage. Carefully remove the jammed paper.
6.
Use the carriage access door to get at a jam further inside the printer. You may need to remove the print carriage to get to the jam.
7.
Replace all parts and return any access panels to their closed and locked positions. Plug your printer back in and flip the power switch.
Jun 18, 2008 | HP PSC 1315 All-In-One InkJet Printer
My epson cs7800
I had the same problem and found a small spring was loose and interfering with the paper. The Spring was on the right side as you look at the printer, near the bottom of the paper feeder. I took it out and it works fine, for now.
Jun 15, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Paper Jam on
most printers are pretty cheap now so replacement is always an option....on the other hand, I will spend countless hours trying to figure out what is wrong first. Remove all paper first, open printer and check for pieces of torn paper or debris, if you have a can of air you can blow out the insides to clean. Put 3 or 4 sheets of paper in, print a test page and watch carefully how paper advances...is it straight or crooked when being loaded? Is printer trying to pull more than 1 sheet at a time? Good luck
May 14, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Kodak EASYSHARE 5100 All-In-One Printer Logo
67 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
