Question about McCulloch Garden
I just baught an old pro mac 850 in good shape last year. i cut 4 loads with it but i could never get it to idle or wind out like it should. where should i start my tunning. this saw has been modified for ''hot saw'' competition.
Need to check the boot between the tank an the carb if its slightly cracked or the bolts r out it wont tune right ,, the boot will detereate after a while
Posted on Mar 28, 2009
Tip
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP...
MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file.
And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro.
Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac.
Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac.
Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos.
Step 2. Choose Apple ProRes codec for Final Cut Pro.
Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.)
Step 3. Merge Canon MXF files. (Optional)
Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output.
Step 4. Convert MXF to Apple ProRes MOV for Final Cut.
Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio.
After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
on Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut...
How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Final Cut Pro is a professional and all in one video editing, compositing and special effects package for the Macintosh. The software logs and captures video onto a hard drive (internal or external), where it can be edited and processed.
If you are a Kodak video fan and you want to give professional editing to your Kodak videos, Final Cut Pro is the best choice for you. However, Final Cut Pro can edit any QuickTime compatible file format including DV, HDV, MOV, MPEG-4. That is to say, in order to edit your Kodak video with Final Cut Pro, you have to convert Kodak videos to the supported formats by Final Cut Pro with Kodak video to Final Cut Pro Converter for Mac.
Tips:
Kodak records the video files with mov files (i.e. Quicktime files) does not mean they are perfect for editing in FCP. The fact is, all of the small video cams, including the Kodak Zi8 Cams, records highly compressed codecs that are known as delivery codecs, not editing codecs. You need one third-party software to convert HD mov files to some formats like DV, HDV , MPEG-4 that FCP is happy to edit.
Kodak video to Final Cut Pro Converter for Mac is one simple-to-use solution with the minimum amount of buttons and a small menu for converting Kodak video (Kodak Zx1, Kodak zi6, Kodak Zi8 and Kodak PLAYSPORT) to DV, HDV, MPEG-4, etc., for importing Kodak videos to Final Cut Pro. Besides, it is also an easy-to-use editing tool that assist you for making personalized video. You can trim the video to a certain length to convert, adjust video aspect ration by using crop function, add special effect like Gray, Emboss, Old film into video to make it more artistic, join several files or set the video output parameters. All this can be done with a few mouse clicks.
Part one: How to import Kodak video to Final Cut Pro and edit Kodak video with Final Cut Pro?
Step 1:Free download and install Mac Kodak video to Final Cut Pro Converter
Download Kodak Video to Final Cut Pro Converter For Mac and double click the downloaded . dmg files to install. A user-friendly interface will pop up.
Step 2:Load Kodak video files
First: Connect Kodak camcorder to computer and transfer mov files to iMac, Mac book.
Second: Hit the File button on the top left panel or click "Add Video" button to select Kodak MOV files to this converter.
Step 3:Select the output format and destination
Click the downward arrow beside Settings to choose the proper Final Cut Pro format from the drop-down list. And then click Browse button to specify the output location.
Tips: Select DV, HDV or MOV format for FCP in the pull-up list next to Profile field. And then click Browse button to specify the output location.
Step 4:Start the conversion
After all the necessary setting has been done, hit the "Start" button to start converting. Click the Open button to select the converted DV, HDV files to Final Cut Pro for further editing upon completion.
Part Two: Import Kodak videos to Final Cut Pro and edit Kodak video in Final Cut Pro.
Step 1:Import Kodak videos to Final Cut Pro
Launch Final Cut Pro and click "Import"-"Files" and then select the converted Kodak files. Find the file in the resources list for the project and drag the file into the Timeline, and then save the project.
Step 2:Edit Kodak video in Final Cut Pro
Apple's Final Cut Pro Software is an all in one video editing, compositing, and special effects package for the Macintosh. The following steps will show you how to use the Timeline:
One: Edit video and audio timing
There are three tracks on the Timeline, one for video and the other two for audio. And you can cut the video and audio tracks all at once in the same place.
Choose the razor blade tool in your menu, and click the times that you want to split it. You can also set input and output times on the Viewer window. Final Cut Pro also allows you to layer video tracks on top of each other.
Two: Add transitions
For Kodak videos, you might want to use simple and non-distracting transitions. Then you can just select Fade Out or Cross-Fade transitions.
Three: Export video
Once you are finished with editing your video, click on File and point to Export, then you will see a list of options of how you can export the edited file. For example, if you want to publish your video to the web, you can click on "Export using QuickTime Conversion". When you see the naming dialog box, input the name you prefer and at the bottom, select "MPEG-4" at the bottom, and then select "Broadband-High" under the format setting. And now click on Save.
on Sep 17, 2010 | Computers & Internet
How do you wind replacement line to the Poulan Pro String Trimmer?
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Jun 28, 2009 | Poulan Pro Pp125 25cc Gas Straight Shaft...
Video files on MyBook 1TB hard drive lag
So, if you move the file that won't load onto your laptop it then loads? If so can you plug it into another mac and see if it works on that one (if it works it an issue with your macs firwire ports and an os re-install may be needed or your card has been damaged) or can you try another hardrive with your mac (if this works you need to reformat your mybook)? I've bined a HD this year already, not good.
Jun 23, 2009 | Western Digital My Book Essential Edition...
Tip
How to Export Movie from Final Cut Pro (FCP) to FLV? After editing your own...
After editing your own movies on Final Cut Pro or Final Cut Express, you may want to put them on your website for presenting your introduction or promoting your services/products. For users with the older version of FCP, FCE or iMovie, it is easy to export FLV by choosing File > Export > Using QuickTime Conversion. However, if you could not find Flash FLV as output format from FCP/FCE/iMovie, you may need a FCP to FLV converter to get Flash videos.
Aunsoft Video Converter for Mac is the best FCP to FLV converter for you to handle videos on iMac/MacBook Pro with Snow Leopard or Leopard. The Mac FCP to FLV converter supports loading .3gp, .m4v, .avi, .dv, .flc, .mp4 videos from FCP/FCE/iMovie and converts FCP movies to FLV as short film. Below are the steps to export Final Cut Pro movie to FLV with Aunsoft Video Converter for Mac.
Step 1. Load Final Cut Pro movies to Aunsoft Video Converter for Mac.
After exporting movies from Final Cut Pro, run Aunsoft Video Converter for Mac as the Mac FCP to FLV converter, and click the "Add" button to load FCP short films for conversion.
Step 2. Choose FLV output format.
Click the "Format" option and choose Flash Video > FLV-Flash Video Format(*.flv) as output format. This format is compatible to most machines.
Step 3. Transcode FCP movies to FLV.
Click the "Convert" button under the preview window, and the Mac FCP to FLV converter starts converting Final Cut Pro movies to FLV for playing on webpage.
Tips:
1. After converting Final Cut Pro movies to FLV, you need Flash players to navigate the video playback on webpage. You can use free web players like JW player, Moyea PlayBox player and Flow player to present your short films on website.
2. You can set the video resolution of the FLV videos by clicking the "Settings" before conversion.
3. The above step-by-step guide with Aunsoft Video Converter for Mac also works for the movies exported from Final Cut Express and iMovie. In other words, you can also convert FCE movies to FLV, iMovie videos to FLV on Mac OS X.
on Jul 22, 2010 | Cell Phones
Acts like it isn't getting fuel or is misfiring... started suddenly according to my daughter
First check that the timing is set propperly, that all ignition wires are in good shape(not arcing) and connected properly, distributor cap not cracked, fuel pressure, air mass and or oxygen sensors are ok. The last two may have to be done by a pro depending on your experience.
Jun 01, 2009 | 1987 Volvo 240
Pro mac 850 super cc rateing and fuel mix
ProMac 850 is 82cc capacity motor & Fuel mix is 25:1 - especially now that we only have unleaded... best to use BP Ultra 98 octane as these saws were designed to run on Super leaded fuel. I used to own a 797 Super (123cc motor)
Terry B
Apr 03, 2009 | McCulloch Garden
Not able to down load video from my Panasonic videto Mac Pro 3.1
Basically mac does not like USB, it is bad and uses burst of information not suitable to video so FCP kinda ignores the option. It works ok for the transfer of non-realtime info. Can you not use DV to FW. Loads of people are having this issue as MAC have dropped it with the new MacBook to in my opinion force people to buy MBP.
Feb 01, 2009 | Genius VideoCAM Eye Web Camera
Agitator Dogs
Nothing is manufactured to last these days. What brand of dogs are you using ? FSP is the original brand and should be used. Also, check the inside of the agitator. Are the gear teeth in good shape ? It only take one bad tooth to destroy the dogs.
Dec 12, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Garden Logo
95 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
