Question about NorStar Meridian M7310 Phone
M7310 - 3 phone set system - line 3 on one set does no ring tone
I have attempted Feature *6 to get line a line 3 ring tone with out success any other idea'/ s
  • 192 Answers
Feature * 6 is for the ring tone of the set, it doesn't change the cadence (ring tone) on a line...
The only way to change the ring tone on a line... it would require everyone that has that number to change.
You need to go into the programming
-> look for LINE and enter
-> put in 003 for line 3 and enter
-> under TRUNK/LINE DATA find DISTINCT RING and change
-> REL to end programming...
Now that line 3 will ring differently. But it will ring differently on everyone's sets that has line 3 on their phone
Posted on Mar 20, 2009
  • ynotphone
    ynotphone Mar 20, 2009
    After reading more into this, do you mean that the line is not ringing on your phone?
    That is different programming...
Hi just got a alcatel 2036x cheap phone but cant change ring tones can i do it on this cheap phone thanks
go into settings, ring tones , and change it there , can only change to those listed,
Oct 03, 2016 | Alcatel Cell Phones
Phone line doesn't ring
First, lets get rid of the static. Try Feature #86. This will turn off background music. When a music source is not attached you get static.
Enter programming by using Feature XXX66344 password 266344. The display should show "Terminals&Sets" press the top right button with an indicator in the display. The display should show "Show set: ____ enter the extension number that you want to check or program. The display will show ***:name. Press the top right button three times. The display will show Show Line:____ with options to Scan or List. If you select Scan it will show the lines assigned to that phone. If you select List it will start with the first line in your phone system showing one of four states 1- Unassigned, 2- Ring Only, 3- Appear&Ring, 4- Appear only. Change the selection on the line by using the CHNG soft button. This is where line assignments are changed from the four states for each extension.
The only other thing that will keep an extension from ringing is "Do Not Disturb" or DND. Feature 85 and #85 will turn this feature on and Off.
Jan 31, 2014 | NorStar Meridian M7310 Phone
Can not send or receive faxes. Have successfully performed and passed the 6 components of the HP Fax test. Can hear dial tone when attempting to fax.
Dial from printer to your mobile phone sense the ring then send the fax sense the fax tone if fax tone not hearing you replace formatter ...
Sep 08, 2011 | HP Officejet 5610 All-In-One InkJet...
Hi, Can any body help us? We have a M7324 on a Norstar Compact with two line pools, Pool A is on Line 1,2,3 and Pool B on Line 4,5. We want to add another line on Pool B so I tried configuring Line 6 which...
On the cross connect do you have a CO connected to that line. That is most likely the cause of no dial tone. If you don not know how to check that call a phone system expert to connect and verify your system.
Feb 15, 2011 | NorStar M7324 Telephone
3rd line - no ring tone on one of a 3 set phone system
Yes, as you noticed FEATURE *6 only changes the ring tone on the set...
You have to go into system programming to make this change...
-> First you need to know the extension on the set, you can find this by doing FEATURE *0 and press the Intercom button.
-> Get into programming and you'll see TERMINALS&SETS and enter
-> type in extension that is giving you problems
-> hit next till you see LINE ACCESS and enter
-> the you'll see LINE ASSIGNMENT and enter
-> type in the line 003
-> and press change to APPR&RING
-> hit next and RLS to back out of programming
Mar 04, 2009 | NorStar Meridian M7310 Phone
I would like Line 6 on Norstar System to Ring Different
Normal 0 To Change your Ring Type:
1. Press the Feature button, then * 6
2. Press the number keys 1 – 4 to hear the different ring types
3. Press the OK softkey when you hear your desired ring
Jan 15, 2009 | NorStar M7310 Corded Phone
Just set up another line for the phone to have a 4th line
You need to programm the system for the 4th line.
Do all of your phones ring?
If so, the easiest way is to tell the system it now has 4 lines instead of 3. BUT, by doing this, you will erase the button immediately after the line 3 button. This is the easiest way, if you have some phones that are set not to ring, then do NOT follow these instructions.
From extension 10 or 11
Feature 00
Left intercom
Left intercom
#104
pres 04
press feature 00
Sep 11, 2008 | Lucent PARTNER18 Corded Phone
How do I ajust the ringer.
Hi adititeres,
Is the phone part of a phone system? If it is that feature is programmed in the phone system itself. Do you have voice mail service on the line? Or is this a voice mail service in the phone? If it is on the line, call your dial tone provider to have the number of rings changed. If it is on the phone itself, your user manual will have it. Please let me know if you have any addtional questions.
Kay
Jackson Communications
Aug 01, 2008 | RCA 25423RE1 Phone
Lucent Partner-18 business phone
Feature 00
LEFT Intercom twice
#209
enter the line number (01, 02, 03, 04, etc)
Press the Keypad for the ring style you want (1-8)
Feature 00 when done.
If this does not work, your release of Partner system is too old....
Jun 18, 2008 | Lucent PARTNER18 Corded Phone
No dial tone
The feature you are looking for is called "prime line" or "Line preference" but not "ringing line preference". It is not usually on by default on a multi-line business phone system. Your system can do this but I suspect it's a system programming feature and not something you can set yourself. You would have to have the phone system administrator make the change. Or you may pay an installation company to make programming changes?
Jun 01, 2007 | Mitel Superset 4015 Corded Phone
NorStar Meridian M7310 Phone Logo
1,271 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Shehu Pro
Shehu Pro
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
