Question about HP Compaq nc6000 Notebook
Compaq nc6000 laptop wireless connection
I have two nc6000 laptops. One I bought 1 year ago - no connection problems. The one I just bought won't connect here at home or at work. My older laptop connects both places. What am I doing wrong or what do I need to get?
  • Chris Hingee
    Chris Hingee May 11, 2010
    Is the network configuration the one that is not working configured the same as the one that is working?
  • 46 Answers
Wireless connection? If so, make sure the wireless device is enabled on the newer one. If it's a red light, the wireless device may be faulty. If so, just get an external USB wireless device and use that. Check to see that the same lights are on with both PCs.
Posted on Mar 04, 2009
What the solution of laptop hp compaq nc6000 when turn on won't start up
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/original-hp-compaq-nc6000-ac-adapter-65w-cord.html
http://www.chargerbuy.com/replacement-hp-compaq-nc6000-ac-adapter-18-5v-3-5a.html
Nov 13, 2012 | HP Compaq nc6000 Notebook
Hit escape as you turn on the pc. Continue hitting the button until the startup screen shows. Also Try Hitting Contol alt delete all at once and hold down until startup screen shows. Be sure you have absolutley no usb ports being used during startup
Wireless connection problems
If you get a 'Limited connectivity" on you wirelessconnection on your laptop, it means that the wireless card on your laptopprobably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and thenclick Repair.
This will force the wireless router to issue a IP address to the wireless cardon the laptop.
Apr 19, 2012 | HP Compaq nc6000 Notebook
How to connect wifi with compaq nc6000. I dont know is there a inbuilt wifi card. how to see it. also marked wireles button doesnt give any response. pls give me quick answer
Unofrtunatly with compaq as well as several other brands of laptops these buttons were notorious for failing and need servicing to be fixed. the best solution for this problem is to simply purchase a USB wireless adapter from a site like newegg.com
Jun 26, 2011 | HP Compaq nc6000 Notebook
My Hp compaq nc6000 with Windows XP used to have a good wireless connection, but now it has a very low signal and I cannot connect to the internet. It does connect to the internet with an ethernet cable. I...
Make sure that the antenna on your wireless router is not damaged or pointed the wrong way (down or the the side). Also if you look under the cover under your laptop make sure that the wireless antenna is properly plugged in to your laptop's radio. I have seen a few loose ones here and there.
Jul 28, 2010 | HP Compaq nc6000 Notebook
Just bought this laptop - cannot get the Wireless
If wireless card is listed in device manager under network adapters-that means you dont have to install it. If you running on vista, go to control panel and find ssomething like wireless contol manager or wireless assistant and see if its not disabled there. may also be disabled in bios settings. on windows xp-check if windows has possibility to manage wireless networks or its blocked by third party software. for example i use bt voyager wireless card and its managed by bt software. built in cards are likely managed by windows. type services.msc in run box and see if wireless zero configuration service is enabled.
Oct 21, 2009 | HP Compaq nc6000 Notebook
My HP NC6000 network cards aren't working now but device manager says it's working properly. When I connect wireless can't find any network and same for the wire network connection. I just got back from a...
try uninstalling the wireless driver wit the wired & reinstalling them if problem persist...backup ur files & do a clean installation of your Operating system
Oct 17, 2009 | HP Compaq nc6000 Notebook
How do I ascertain if my nc6000 has a wireless modem
normally, laptops have an internall integrated wireless modem. All you should have to do, is enable the wireless, by pressing Function F6 or going into the network connections window and enabling the Wireless form there.
Apr 14, 2008 | HP Compaq nc6000 Notebook
OS has got corrupted and not able to reinstall it
depending on where you bought it, it should have 2 to 3 years warranty... just turn over your laptop and look for serial numbers... those numbers can help you in searching the compaq site for your warranty...
rate me if this helps...
Jan 20, 2008 | HP Compaq nc6000 Notebook
HP Compaq nc6000 Notebook Logo
471 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
