Question about General Electric WHDVH660H Front Load Washer
Push start different sound water may start may not start pause
Start button flashes washer won,t start noticed water in bottom carraige why found boot seal between drum and front load door torn near door latch area thinking some electrical part wet damaged causing no normal washer cycle. LED-d says door locked but you can open front loader door.not normal
    Scholar:
  • 87 Answers
I would check to make sure the connectors to that door lock are all connected. If they are it's probably the lock/switch mechanism itself. Wow I just checked and they are about $120. The p/n is wh10x10006 You can google around for the best price. Good luck!
Posted on Mar 04, 2009
Start light flashing,rince light on.machine will not start cycle
Hello. I really need the make/model number to help you accurately. However, from the symptoms you're describing, it sounds like the drain pump is jammed. A lot of dishwashers turn on the drain pump first to remove any stagnant water sitting in the bottom of the pump. Then, fresh water is let into the tub, fills to the proper amount, then the main pump starts. The lights flashing are an error code--different combinations of buttons flashing mean different things. On some models, a button light will flash a certain number of times, pause, then flash another number of times. This is a binary code telling the user what is malfunctioning. That's why I need the model number and any other info to help diagnose the issue. Thanks!
Sep 18, 2015 | Dishwashers
Bosch Nexxt 100 series washer wfmc1001uc
According to the manual, you have to:
1. Turn program selector to "off"
2. Turn selector to Drain or Spin
3. Press the start / pause
Wait until program ends.
Open door.
or
Press "start / pause" until the start / pause light flashes.
Jan 10, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Error code 1000 on blomberg washer
We found a way to reset the computer and solved the problem.
1. Press and hold pause turn off machine and turn back on holding pause all the while.
2. This should reset the computer. All lights will light up on LCD display.
3. Release pause button. Turn off machine, turn back on and begin a new wash cycle.
woo hoo!
Apr 08, 2013 | Blomberg WM87120 24" Front-Load Washer...
Duet Sport Whirlpool front loading washer is stopping before cycle is finished with a variety of error codes from F21 5d etc. Will run fine for several loads then back to not finishing. Have unplugged it...
First check your washer plug to see if the connections are tightly screwed. Next check your filter if you haven't for long.
Remove the 3 screws at the bottom of the front panel under the washer door. Your filter door will be light brown. If you find a hose there it is to drain out excess water (water that could not be drained by your pump) After you hv drained unscrew the cap and remove all the junk inside. Have a large plastic bag to catch junk and water. Refit carefully after cleaning out. If not solved, something shd be blocking your pump, check this out
How abt a nice rating for the free help? Thnks
May 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Can't get washer to start again after pushing pause/cancel button
sounds like central control unit problem, you can check for diagnostic mode operation by setting (door closed) drain/spin, no spin, pressing prewash 4 times in 5 secs pressing prewash again will advance through diagnostic cycle. replacing user interface may also be necessary
Apr 25, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have whirlpool duet ghw9100lq does not start only flashing
select pause/cancel twice if it still does not unlock. It is not unlocking because of water still in the system, run the drain spin cycle manually if that does not work you will have to clean out the lint trap and the water left inside will drain on your floor. To clean the lint trap. there is a panel at the bottom front of the washer. along the bottom of the washer there are three torx type screws to remove the panel these will be above the drawer unit if you purcased the stand. remove the panel by lifting from the bottom. then in the center you will see a plastic cap. twist the cap to remove. this is your lint filter. it pulls out and has a cup shaped piece attached to it pay attention to how it comes out im not sure if you can put it in wrong. clean the area out. there may be some water to spill out depending on how much is clogged in your system. replace the cap once you have cleaned it out this should help with your problems.
Mar 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Motor or motor controller bad?
usually frigidaire option select / pause cancel enters diagnostic mode. tech sheet on bottom by motor control. access from rear panel. has test procedure for motor control.
Mar 13, 2009 | Frigidaire ATF6000ES Front Load Washer
F20 CODE Whirlpool Duet Sport Washer wfw8300sw00
Hi!
“F20” on display
(Water Inlet Problem—no water or insufficient
water supply) Select PAUSE/CANCEL twice to cancel the cycle
Unplug washer or disconnect power. Check the following: Are water faucets completely turned on?
Are screens at inlet hose connection to washer
clogged? Are water inlet hoses kinked? Are water inlet hoses frozen?
Do rate the solution.
Thanks
Rylee
Feb 08, 2009 | Whirlpool WFW8300SW
FTF2140ES0 Frigidaire Washer Won't Start
Yes - often times the plastic breaks from slamming the door.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 12, 2009 | Washing Machines
We purchased a GE front load washer in December 2007. Recently the boot had to be repaired. Now the machine is pausing when it gets to the rinse and spin or drain cycles. The pause light starts to flash. ...
ok Problem is not finding out the meaning of the pause button flashing but.......
you need to contact GE directly as this machine is under warranty.
Follow this link. GE APPLIANCE
If they do not help I will just contact me
Jun 05, 2008 | GE Washing Machines
General Electric WHDVH660H Front Load Washer Logo
150 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
