Question about Samsung CLX-2160N All-In-One Printer
CLX-2160N Paper Jam?
I have printed off 1 page with this new printer and it says paper jam already! there is no paper jam, it will not feed the paper for some reason
My printer Samsung CLX-2160 give me the message "paper jam", but I checked a lot of times inside and there is no paper. What's the real problem? How can I solve?
Posted on Sep 07, 2010
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
I have a Samsung CLX-3160FN, and after every page
it is most likely that the fuser actuater arm is not sitting back to the sensor properly. open the back door you will be able to see the fuser, on your right hand side you should be able to see a fliper that sit in between a sensor. try to adjust the fliper flag and see if it works.
if it still continue to give you the same error. try remove the fuser four screw 2 side on each. adjust the flag again and fix it back. it should work and double check for any lose small pices of paper jam in the printer.
May 15, 2010 | Samsung CLX-3160 All-In-One Laser Printer
CLX 2160 - paperjam
There is probably a jam in the paper feed area. Pull the paper tray out and stick your hand in to find and remove any paper stuck there. Then reinstall the paper tray and open and close the front door of the printer. The jam should be cleared.
If it is still showing paper jam, pull the tray out again and look to make sure you didn't miss any paper, then check the other areas of the printer (starting with the exit area) for paper.
Oct 24, 2009 | Samsung CLX-2160N All-In-One Printer
Paper jam after 1 page prints
fuser paper out sensor faulty.req new fuser.
Jun 20, 2009 | Samsung CLX-3175FN Color Laser All-in-One...
CLX-3160FN Paper Jam when there is no paper jam.
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 07, 2009 | Samsung CLX 3160fn All-In-One Printer
Samsung 6210 paper jam
open access(load area) check feed roller take a q tip and use rubbing alcohol and clean photo eye that detects paper be sure all jammed paper is removed
most jams are at the exit and there may be some paper obstructing that area
insert card stock through the paper path
insert ine
Dec 30, 2008 | Nikon COOLPRINT Thermal Printer
HP 6200 without telling it to print, feeds and jams continually
I already encounter that problem lately. when you print your documents, the only response of the printer is paper jam. feed and jam.
try this tip if acceptable of your situation now.
only to do is copy your documents by edit button and then select all or highlight all that your going to print and then right to copy
and then, open a new documents page set up if needed.
and then print it without saving your file because that already save.
Dec 05, 2008 | HP Officejet 6200 All-In-One InkJet...
Samsung CLX-2160N All-In-One Printer Logo
1,152 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
