Control locked on ghw920 can u help me unlock
Theres abutton off the end of the control panle( youll need to lok closely) but marked "control lock hold for 3 secs"
Posted on Mar 04, 2009
Mar 23, 2017 | 2006 Chevrolet Monte Carlo
on Feb 01, 2010 | Whirlpool GEW9250 Electric Dryer
Driver door lock switch
Front passenger door lock switch
Door lock actuators in each of the doors
Door lock system fuse into the BCM (BCM D 25A fuse)
Door Lock Operation
When the BCM detects a transition of either of the door lock switches to the LOCK position, it switches the door lock actuator lock control circuit to voltage. Since the lock actuator unlock control circuits are at ground potential within the BCM, the door lock actuator motors transition to the Lock position.
Driver Door Unlock Operation
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the driver door lock actuator unlock control circuit to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the LF door lock actuator motor transitions to the Unlock position.
The driver door lock actuator unlock control circuit is a dedicated control circuit used only for the driver door lock actuator motor. This is done so that the driver door may be unlocked by itself using a keyless entry transmitter or an automatic door unlock function (if programmed).
Passenger Door Unlock Operation
When the BCM detects a transition of either of the door lock switches to the UNLOCK position, it switches the door lock actuator unlock control circuits to voltage. Since the door lock actuator lock control circuit is at ground potential within the BCM, the passenger door lock actuator motors transition to the Unlock position.
The door lock actuator unlock control circuits are dedicated control circuits used only for the passenger door lock actuator motors. This is done so that the driver door may be unlocked seperate from the passenger doors using a keyless entry transmitter or an automatic door unlock function (if programmed). This video on testing computer controlled door locks on a Subaru , doesn't matter . test yours same way > The BCM controls your door locks .
Are all of the power door locks inoperative from both door lock switches?
Oct 12, 2016 | 2005 Buick Rendezvous
DTC B3133 All Door Unlock Circuit High
Your
Aug 10, 2016 | Cars & Trucks
I appreciate your post, Billy!
I understand that the lock control will not unlock on your Frigidaire range. I noticed that you have disconnected the electricity and the range is still not unlocking. I would recommend holding down the clear/cancel button for at least 15 seconds. If that does not unlock your range I would suggest that it could be a possible issue with your door lock or control panel. For any repairs to be completed I would recommend having a professional technician out to complete a diagnosis. This will help you avoid any unnecessary part purchases. Hopefully this information is helpful. -Matt
Mar 08, 2015 | Electrolux Kitchen Ranges
May 26, 2014 | Samsung Galaxy Ace GT-S5830
Jan 11, 2011 | Whirlpool GEW9250 Electric Dryer
Jan 18, 2010 | 2003 Honda Civic
Mar 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jul 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Apr 20, 2018 | Whirlpool Washing Machines
41 people viewed this question
