Question about Magic Stitch Mechanical Sewing Machine
Singer Stitch Sew Quick stitches not connecting
I just bought theĀ Singer Stitch Sew Quick and I can not make the stitches underneath connect together. I just get a row of unconnected loops. How do I fix this? Adjusting the tension doesn't seem to work.
What way are we supposed to put in the replacement needle in a singer stitch sew quick machine? The loop stitch isn't looping
The needle should be inserted so that the flat side faces the front of the Sew Quick. (The flat side should face the set screw that secures the needle in the Sew Quick.) See figure 11 (on page 2) of the manual. One link to the manual is currently: http://www.hayneedle.com/images/PDF/MICL002.pdf . Make sure that you are using the DHx1 needle.
If the stitches still aren't looping, make sure that you have threaded the needle and bobbin correctly. The thread should start at the back of the needle and be pulled to the front.
I hope this helps.
Aug 17, 2016 | Singer Sewing Machines
What is the difference in the length of the needle on a "handy stitch" as opposed to the "stitch sew quick machine?
Check your manual for the "System" of needle
a normal sewing machine needle has a "System" or dimension
called 15x1 or 705 H. That indicates the length, the circumference
etc. If the needle you received with the machine is the same length as the above system then you should be ok. Also most often the needle package for most machines will be labeled "Universal"
Aug 04, 2014 | Singer Handy Stitch Hand Held Portable...
I have a brand new singer stitch sew quick machine, apparently the machine works, when i use a cloth to try stitching it does not make any stitches
Have you tried Alans Alterations at the MID WALES SEWING CENTRE they have a huge presence on ebay.They should be able to help you,or point you in the right direction.
Apr 03, 2014 | Singer Stitch Sew Quick Sewing Machine
I'm trying to get my mother's Singer Touch & Sew Deluxe 645 to sew a straight stitch. I don't want to buy a manual since the machine rarely gets used and I have limited time to "fix"
Not much information to go on. What do you mean it won't sew a straight stitch. It just won't sew a straight line? It won't form a stitch? What?
Dec 12, 2012 | Singer Sewing Machines
I brought a new "Singer
Why not just return it and get another one? Most reviews are bad on this product, and say do not buy it, too much trouble.
Oct 31, 2010 | Singer Stitch Sew Quick Sewing Machine
Magic Stitch Mechanical Sewing Machine Logo
351 people viewed this question
Top Magic Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Magic Sewing Machine Expert? Answer questions, earn points and help others
